  3. No working window appaers after start.
8 Posts 3 Posters 1.2k Views 3 Watching
  • M Offline
    M Offline
    mslv129jdg
    I have successfully installed Mosquitto on a Raspberry Pi 3 B+ (Debian = stretch).
    Here is the result on the Raspberry :
         pi@raspberrypi:~ $ mosquitto -v
         1559603778: mosquitto version 1.6.2 starting
         1559603778: Using default config.
         1559603778: Opening ipv4 listen socket on port 1883.
         1559603778: Error: Address already in use
         pi@raspberrypi:~ $
    Apparently runs the program but no working window appears on the screen.
    What am I doing wrong?
    Jack DG
    • K Offline
      K Offline
      kimot
      @mslv129jdg said in No working window appaers after start.:
      I do not use Mosquito, but maybe it is already running automatically after RPI starts?
      • M Offline
        M Offline
        mslv129jdg
        Thank you for your efforts.
        Apparently it doesn't matter that the port is already in use.
        Can this help you?
        https://randomnerdtutorials.com/how-to-install-mosquitto-broker-on-raspberry-pi/
        I can't find a forum for Mosquitto users either.
        Greetings.
        JackDG
        K 1 Reply Last reply
        • M mslv129jdg
          Can this help you?
          Greetings.
          JackDG
          K Offline
          K Offline
          kimot
          @mslv129jdg
          mosquitto -v #start in verbose mode
          If your mosquito is already running, you cannot start it again.
          First stop it:
          sudo service mosquitto stop
          sudo systemctl stop mosquitto.service
          And then try your:
          mosquitto -v
          • M Offline
            M Offline
            mslv129jdg
            Tanks Kimot,
            I do what you says and this what happen not more.
            pi@raspberrypi:~ $ sudo service mosquitto stop
            pi@raspberrypi:~ $ sudo systemctl stop mosquitto.service
            1559686190: mosquitto version 1.6.2 starting
            1559686190: Using default config.
            1559686190: Opening ipv4 listen socket on port 1883.
            1559686190: Opening ipv6 listen socket on port 1883.
            franz-unixF 1 Reply Last reply
            • M mslv129jdg
              Tanks Kimot,
              franz-unixF Offline
              franz-unixF Offline
              franz-unix
              @mslv129jdg How do you have installed mosquitto? if you have installed it with the standard
              sudo apt install mosquitto mosquitto-clients
              then, the server starts automatically when you boot your Pi.
              Mosquitto is a server program so it is normal that you don't see any new window. See this if you want to know how to test your MQTT server.
              • M Offline
                M Offline
                mslv129jdg
                I just uninstall mosquitto... with sudo apt-get purge --remove mosquitto*
                The first time i install with :
                sudo wget http://repo.mosquitto.org/debian/mosquitto-repo.gpg.key
                sudo apt-key add mosquitto-repo.gpg.key
                cd /etc/apt/sources.list.d/
                sudo wget http://repo.mosquitto.org/debian/mosquitto-stretch.list
                sudo apt-get update
                sudo apt-get install mosquitto
                I look and study your link.
                • M Offline
                  M Offline
                  mslv129jdg
                  Eureka...eureka... Mosquitto works....
                  Thanks to your contributions I have achieved what I wanted step by step.... for which I thank you.
                  Indeed Mosquitto has worked in the beginning but I am expecting an opening window.
                  Meanwhile, I have successfully send a message from the terminal window 1 to 2.
                  Thanks to all who have taken the trouble to look at my question and send me a possible solution.
                  See you later.
                  JackDG
                  12.1k
