  3. RPI Gateway: Connect to Controller and MQTT broker with different IP addresses
6 Posts 2 Posters 2.2k Views 2 Watching
  • R
    R
    rjgmba
    Hi all,
    I am trying to use a RPI as mysensors' gateway for both MQTT as well as RFM69 and connected to network using ethernet. As controller I am using HomeAssistant. Is it possible to run a MQTT broker like mosquito on this gateway / or on a device other than the controller?
    It looks like the assumption is that the MQTT broker is on the same device as the Controller:
    https://www.mysensors.org/apidocs/group__RaspberryPiGateway.html:
    MySensors options:
    --my-controller-url-address=<URL>
                                Controller or MQTT broker url.
    --my-controller-ip-address=<IP>
                                Controller or MQTT broker ip.
    But maybe I misunderstand.
    I was trying to use the following:
    ./configure --my-gateway=ethernet --my-controller-ip-address=<HomeAssistant IP>  --my-transport=rfm69 --my-rfm69-frequency=433 --my-is-rfm69hw --my-gateway=mqtt --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1
    Where <HomeAssistant IP> is 192.168.XX.AA in my picture
    But that doesn't allow me to specify the MQTT broker on a different device than the Controller/Home Assistant...
    Perhaps I got this all wrong?
    • R rjgmba
      Hi all,
      MySensors options:
      --my-gateway=ethernet means a TCP connection between the gateway and the controller. Only one my-gateway option should be specified. If you want to use mqtt, use only --my-gateway=mqtt
      Set --my-controller-ip-address to the ip if the mqtt broker.
      See the MQTT section on https://www.mysensors.org/build/raspberry#configure for more information.
      R 1 Reply Last reply
        R
        R
        rjgmba
        @mfalkvidd Many thanks for your quick and helpful reply! Could I ask you two more clarifying questions:
        • So if define the rpi as a mqtt gateway, can I see this mqtt GW still as my GW for my RFM69 sensors?
        • Or do I need to split out the ethernet GW for my RFM69 sensors from the mqtt GW?
        • R rjgmba
          @rjgmba yes it will still be gw for your rfm69 sensors, the picture to the left is correct.
          • R
            R
            rjgmba
            Thanks for clarifying, @mfalkvidd, so that means that I won't use the Ethernet GW, but only the MQTT GW configuration, changing it to
            ./configure --my-gateway=mqtt --my-controller-ip-address=192.168.X.BB --my-transport=rfm69 --my-rfm69-frequency=433 --my-is-rfm69hw --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mymqttgateway1
            Where <MQTT / MySensors GW IP address> is the MySensors RPI IP address.
            But that also means that in Home-Assistant I will need to change the configuration yaml file and take out the Ethernet GW reference:
            So from
            mysensors:
              gateways:
                - device: '192.168.X.BB'
                  persistence_file: 'mysensors3.json'
                  tcp_port: 5003
                - device: mqtt
                  persistence_file: 'mysensors1.json'
                  topic_in_prefix: 'mysensors-out'
                  topic_out_prefix: 'mysensors-in'
              optimistic: false
              persistence: true
              retain: true
              version: '2.0'
            to
            mysensors:
              gateways:
                - device: mqtt
              optimistic: false
              persistence: true
              retain: true
              version: '2.0'
            But how will Home-Assistant now know what the IP address is for the MySensors RPI gateway?
            Apologies if I completely missing something obvious....
            • R rjgmba
              So from
              mysensors:
                gateways:
                    tcp_port: 5003
                  - device: mqtt
                optimistic: false
                persistence: true
                retain: true
                version: '2.0'
              to
              mysensors:
                gateways:
                  - device: mqtt
                optimistic: false
                persistence: true
                retain: true
                version: '2.0'
              @rjgmba Home Assistant should connect to the mosquitto broker
