  3. No working window appaers after start.
8 Posts 3 Posters 1.3k Views 3 Watching
    mslv129jdg
    I have successfully installed Mosquitto on a Raspberry Pi 3 B+ (Debian = stretch).
    Here is the result on the Raspberry :
         pi@raspberrypi:~ $ mosquitto -v
         1559603778: mosquitto version 1.6.2 starting
         1559603778: Using default config.
         1559603778: Opening ipv4 listen socket on port 1883.
         1559603778: Error: Address already in use
         pi@raspberrypi:~ $
    Apparently runs the program but no working window appears on the screen.
    What am I doing wrong?
    Jack DG
    • K
      K
      kimot
      @mslv129jdg said in No working window appaers after start.:
      I do not use Mosquito, but maybe it is already running automatically after RPI starts?
        mslv129jdg
        Thank you for your efforts.
        Apparently it doesn't matter that the port is already in use.
        Can this help you?
        https://randomnerdtutorials.com/how-to-install-mosquitto-broker-on-raspberry-pi/
        I can't find a forum for Mosquitto users either.
        Greetings.
        JackDG
        K 1 Reply Last reply
        • M mslv129jdg
          Can this help you?
          Greetings.
          JackDG
          K
          K
          kimot
          @mslv129jdg
          mosquitto -v #start in verbose mode
          If your mosquito is already running, you cannot start it again.
          First stop it:
          sudo service mosquitto stop
          sudo systemctl stop mosquitto.service
          And then try your:
          mosquitto -v
            mslv129jdg
            Tanks Kimot,
            I do what you says and this what happen not more.
            pi@raspberrypi:~ $ sudo service mosquitto stop
            pi@raspberrypi:~ $ sudo systemctl stop mosquitto.service
            1559686190: mosquitto version 1.6.2 starting
            1559686190: Using default config.
            1559686190: Opening ipv4 listen socket on port 1883.
            1559686190: Opening ipv6 listen socket on port 1883.
            franz-unixF 1 Reply Last reply
            • M mslv129jdg
              Tanks Kimot,
              franz-unixF
              franz-unixF
              franz-unix
              @mslv129jdg How do you have installed mosquitto? if you have installed it with the standard
              sudo apt install mosquitto mosquitto-clients
              then, the server starts automatically when you boot your Pi.
              Mosquitto is a server program so it is normal that you don't see any new window. See this if you want to know how to test your MQTT server.
                mslv129jdg
                I just uninstall mosquitto... with sudo apt-get purge --remove mosquitto*
                The first time i install with :
                sudo wget http://repo.mosquitto.org/debian/mosquitto-repo.gpg.key
                sudo apt-key add mosquitto-repo.gpg.key
                cd /etc/apt/sources.list.d/
                sudo wget http://repo.mosquitto.org/debian/mosquitto-stretch.list
                sudo apt-get update
                sudo apt-get install mosquitto
                I look and study your link.
                  mslv129jdg
                  Eureka...eureka... Mosquitto works....
                  Thanks to your contributions I have achieved what I wanted step by step.... for which I thank you.
                  Indeed Mosquitto has worked in the beginning but I am expecting an opening window.
                  Meanwhile, I have successfully send a message from the terminal window 1 to 2.
                  Thanks to all who have taken the trouble to look at my question and send me a possible solution.
                  See you later.
                  JackDG
