  3. Raspberry Pie 4, RFM69 - Noobie questions
1 Posts 1 Posters 417 Views 1 Watching
  • K
    K
    kiesel
    I hope it's ok to open these types of posts here.
    I would like to use openHab on an Raspberry Pie 4, I decided on a RFM69HCW (868MHz) transmitter because those seem to have a good range (Admittedly I don't need all that range because I life in a small flat, but it would be nice to be future-proof).
    I figured I could build good and cheap (battery driven) sensors with some Arduino Pro Minis, EasyPCBs and other RFM69 transmitters.
    Is this a good setup? Or should I change anything?
    About attaching the RFM69HCW to the RPi4: This is probably the easiest way to attach the RFm69 to the Pie, right?
    If I got the documentation here right then the mysensors library is all I need to run the RFM69 on the Pie, correct?
    Thanks for the help!
