  3. Stabile Controller
Stabile Controller
mqttopenhabserial
9 Posts 4 Posters 5.4k Views 1 Watching
  • C
    C
    C.r.a.z.y.
    I waste my weeks with openhab
    **My main problem is losing connections with nodes. I tried serial / mqtt binding but same result (Openhab 1.6.2 / 1.7.0).
    Please can anyone advice a Stabile Software which really works with MySensors?
    • FrancoisF
      FrancoisF
      Francois
      Hi I am using PiDome although it's still in alfa stage it is really easy to setup as it integrated nicely with MySensor nodes and it just works. I try OpenHab and never get it to work right with MySensor maybe it is just to complex to setup and to do rule for automatic for me it is to complex
      C 1 Reply Last reply
      • FrancoisF Francois
        C
        C
        C.r.a.z.y.
        @Francois I tried it but didn't like UI, not too hard to install and plugin dev-John is very helpful. I didn't use piDome long time to test all nodes. How many devices do you have in your system?
        JohnJ 1 Reply Last reply
        • FrancoisF
          FrancoisF
          Francois
          @C.r.a.z.y. I have 10 nodes running at this stage and it is very fast. What in the gui don't you like?
          • C C.r.a.z.y.
            JohnJ
            JohnJ
            John
            @C.r.a.z.y. All input is welcome! There is an user who is running 51 devices quite stable as far as i know.
            P.S.
            When the rpc api is released it is possible to build an UI interface yourself ;).
            • JohnJ John
              P.S.
              C
              C
              C.r.a.z.y.
              @John Hi John, custom UI will be awesome!
              Do you have raspberry image file i want to start quickly:)
              • C C.r.a.z.y.
                JohnJ
                JohnJ
                John
                @C.r.a.z.y.
                Unfortunately no, also it is still in alpha with builds made sometimes multiple times a day. PiDome is update safe, so stopping, overwriting, starting will handle all update tasks internally.
                When stables are hitting the net we will be creating images. Until then: https://pidome.wordpress.com/server/server-installation/
                  marceloaqno
                  Code Contributor
                  @C.r.a.z.y. What is the hardware of your gateway? Could you give more info about it?
                  • C
                    C
                    C.r.a.z.y.
                    @celonunes generally raspberry pi with serial usb but also you can see some mqtt logs. Same problem with mac os with serial usb.
                    I also tried rpi uart pins for serial bu there is no logs for it.
                    Maybe someone gives his Openhab dir i can understand better problem isnt related with hardware
