  3. [Solved] Getting Arduino IDE error with Relay Actuator sketch
6 Posts 3 Posters 763 Views 1 Watching
    mrhutchinsonmn
    wrote on last edited by tekka
    https://www.mysensors.org/build/relay
    I am attempting to use the following sketch for a relay setup but getting the error below:
     * Version 1.0 - Henrik Ekblad
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define MY_REPEATER_FEATURE
    #define RELAY_PIN 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    void before()
      for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
        pinMode(pin, OUTPUT);
        present(sensor, S_BINARY);
      if (message.getType()==V_STATUS) {
        // Change relay state
        digitalWrite(message.getSensor()-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
        // Store state in eeprom
        saveState(message.getSensor(), message.getBool());
        // Write some debug info
        Serial.print(message.getSensor());
    wifi-enabled-relay:89:23: error: 'const class MyMessage' has no member named 'getSensor'; did you mean 'setSensor'?
                           setSensor
    tekkaT 1 Reply Last reply
    • nagelcN
      nagelcN
      nagelc
      That is weird. I can't see what is wrong. Especially since it compiled the one in digitalWrite.
      I just tried pasting your code into a sketch I was working on and it verified (different board and radio, but it doesn't seem like that should matter).
      Using Arduino 1.8.9
      • M mrhutchinsonmn
        void before()
                               setSensor
        tekkaT
        tekkaT
        tekka
        @mrhutchinsonmn Looks like your MySensors library is outdated, please update to 2.3.2
        M 1 Reply Last reply
        • tekkaT tekka
          mrhutchinsonmn
          @tekka Looks up to date to me.
          • M mrhutchinsonmn
            tekkaT
            tekkaT
            tekka
            @mrhutchinsonmn It compiles here, can you post the entire compilation log?
            • tekkaT tekka
              mrhutchinsonmn
              @tekka I moved the library and reinstalled. The sketch works now. Thank you for pointing me in the right direction!
