  3. Receiver that creates details about data transmission errors
1 Posts 1 Posters 301 Views 1 Watching
  • alowhumA
    alowhumA
    alowhum
    Based on the example code by @mfalkvidd I created a USB serial receiver that outputs data about network errors.
    The top line shows the good transmissions, the bottom one shows the bad ones.
    Close-up
    I was surprised to see so many errors.
    • What could this be?
    • How could I find out what is causing this?
    Also, how can I understand these values? Does a transmission error mean that an incoming message failed? Or an outgoing message? How does MySensors determine what an error is? Does an error mean the transmissions totally failed? because in practize the network seems to be ok.
    For those interested, here's my full code:
    * The Candle receiver acts as the bridge between the Candle devices and the Candle Controller.
    * It only allows communication with other Candle devices that use the same encryption password as it uses itself.
    * When you install the Candle Manager, a random password is generated for you. If you ever want to change the encryption password used by your network, this can be done in the Candle Manager settings.
    * Be warned that you will have to re-create this receiver as well as all your devices, since they will all need to have new code with the new password in it.
    * If you have already installed the MySensors add-on, please temporarily disable it before creating this receiver. Otherwise the MySensors add-on may try to connect to it during the creation process, and thus disrupt it.
    * SETTINGS */
    // You can enable and disable the settings below by adding or removing double slashes ( // ) in front of a line.
    //#define RF_NANO                                     // RF-Nano. Enable this if you are using the RF-Nano Arduino, which has a built in radio. The Candle project uses the RF-Nano.
    #define SHOW_TRANSMISSION_DETAILS                   // Show transmission details. If you enable this, the receiver will show you details about how many good transmission are made, as well as any transmission errors. This is updated every 5 minutes.
    /* END OF SETTINGS
    // Enable MySensors debug output to the serial monitor, so you can check if the radio is working ok.
    //#define MY_DEBUG
    #ifdef RF_NANO
    // If you are using an RF-Nano, you have to switch CE and CS pins.
    #define MY_RF24_CS_PIN 9                            // Used by the MySensors library.
    #define MY_RF24_CE_PIN 10                           // Used by the MySensors library.
    #define MY_RADIO_RF24                               // MySensors supports multiple radio modules. Candle uses NRF24.
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    //#define MY_RF24_PA_LEVEL RF24_PA_MIN
    //#define MY_RF24_PA_LEVEL RF24_PA_HIGH
    #define MY_RF24_PA_LEVEL RF24_PA_MAX                // Sets the radio to transmit at maximum power, for optimum range.
    // Mysensors advanced security
    #define MY_ENCRYPTION_SIMPLE_PASSWD "changeme"      // The Candle Manager add-on will change this into the actual password your network uses.
    //#define MY_SECURITY_SIMPLE_PASSWD "changeme"      // Be aware, the length of the password has an effect on memory use.
    //#define MY_SIGNING_SOFT_RANDOMSEED_PIN A7         // Setting a pin to pickup random electromagnetic noise helps make encryption more secure.
    // Mysensors advanced settings
    //#define MY_RF24_CHANNEL 100                       // In EU the default channel 76 overlaps with wifi, so you could try using channel 100. But you will have to set this up on every device, and also on the controller. You can even try 115.
    //#define MY_RF24_DATARATE RF24_250KBPS             // Slower datarate increases the range, but the RF-Nano does not support this slow speed.
    #define MY_RF24_DATARATE RF24_1MBPS                 // This datarate is supported by pretty much all NRF24 radios, including the RF-Nano.
    #define MY_SPLASH_SCREEN_DISABLED                   // Saves a little memory.
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL                           // This is the main function of this code. It tells the MySensors library to turn this device into a gateway/receiver for MySensors network.
    #ifdef SHOW_TRANSMISSION_DETAILS
    // Report how often there are wireless communication issues
    #define MY_INDICATION_HANDLER
    unsigned int txOK = 0;                              // Good transmissions counter
    unsigned int txERR = 0;                             // Failed transmissions counter
    #define REPORT_INTERVAL 300000                      // Report every 5 minutes
    #define CHILD_ID_TX_OK 1                            // Child id for the counter of OK transmissions
    #define CHILD_ID_TX_ERR 2                           // Child id for the counter of failed transmissions
    #include <MySensors.h>                              // The MySensors library, which takes care of creating the wireless network.
    #include <avr/wdt.h>                                // The watchdog timer - if the device becomes unresponsive and doesn't periodically reset the timer, then it will automatically reset once the timer reaches 0.
    // Clock for the watchdog
    #define INTERVAL 500                                // Every second we reset the watchdog timer. If the device freezes, the watchdog will not be reset, and the device will reboot.
    #define RADIO_DELAY 100                             // Milliseconds of delay between sending transmissions, this keeps the radio module happy.
    unsigned long current_time = 0;
    MyMessage transmission_quality_message(CHILD_ID_TX_OK, V_CUSTOM);
    void indication(indication_t ind)
      switch (ind)
        case INDICATION_TX:
          txOK++;
          break;
        case INDICATION_ERR_TX:
          txERR++;
          break;
      sendSketchInfo(F("Candle receiver"), F("1.0"));
      present(CHILD_ID_TX_OK, S_CUSTOM, F("Good transmissions")); // Tell the controller about this property
      present(CHILD_ID_TX_ERR, S_CUSTOM,F("Bad transmissions")); // Tell the controller about this property
      //Serial.println(F("Hello, I am a Candle receiver"));
      send(transmission_quality_message.setSensor(CHILD_ID_TX_OK).set(txOK)); // Send the good transmissions value
      send(transmission_quality_message.setSensor(CHILD_ID_TX_ERR).set(txERR)); // Send the failed transmissions value
      wdt_enable(WDTO_2S);                              // Starts the watchdog timer. If it is not reset at least once every 2 seconds, then the entire device will automatically restart.
      static unsigned long previous_millis = 0;         // Used to run the internal clock
      current_time = millis();
      if( current_time - previous_millis >= INTERVAL ){ // Main loop, runs every second.
        previous_millis = current_time;                 // Store the current time as the previous measurement start time.
        wdt_reset();                                    // Reset the watchdog timer
        sendHeartbeat();                                // Tell the controller we're still connected.
      static unsigned long last_send = 0;
      if( current_time - last_send >= REPORT_INTERVAL ){
        txOK = 0;                                       // Reset the good transmissions counter back to 0
        txERR = 0;                                      // Reset the error transmissions counter back to 0
        last_send = current_time;                       // Remember the time when the transmissions was done.
