  3. Home Assistant
  4. Home Assistant errors with serial gateway
gateway
5 Posts 2 Posters 820 Views 2 Watching
  • K
    K
    KevinT
    I'm getting WARNING: Gateway /dev/ttyUSB0 not ready after 15.0 secs
    But serial data is getting through, as it shows up later in the log.
    2020-04-17 16:05:35 DEBUG (MainThread) [mysensors] Receiving 2;255;3;0;0;86
    2020-04-17 16:05:35 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 2 child 255
    2020-04-17 16:05:35 DEBUG (MainThread) [mysensors] Receiving 2;1;1;0;38;2.84
    2020-04-17 16:05:35 WARNING (MainThread) [mysensors] Child 1 is unknown
    Any idea why the gateway isn't getting set up correctly?
    Gateway is an Arduino mini, baudrate 38400. Using standard gateway sketch.
    Home Assistant is latest version, 32bit, running on PI 3B+.
    electrikE 1 Reply Last reply
    • K KevinT
      electrikE
      electrikE
      electrik
      @KevinT said in Home Assistant errors with serial gateway:
      This could be caused by incomplete presentation of your sketch. Does your sketch fulfill the requirements as for example shown here:
      https://www.home-assistant.io/integrations/sensor.mysensors/
      https://www.google.com/search?q=mysensors+home+assistant
      • K
        K
        KevinT
        Thanks.
        I was missing 2 things, the presentation of S_MULTIMETER, the battery voltage I also send out, and the initial value send in the main loop. (Funny, I had read these myself but ignored them thinking I had a timeout problem.)
        For the initial value send, I have 2 sensors, can I just read back the value of the last sensor sent, or do I have to verify all of them?
        (I am assuming this is just a step to ensure the controller is ready before continuing?)
        Also, though everything now works, I still get the timeout (not ready) on the serial port. Is this normal?
        Also, 2 strange warnings, node 0 (controller?) and node 1 (gateway) missing sketch names?
        2020-04-18 09:57:00 DEBUG (SyncWorker_16) [mysensors.persistence] Loading sensors from persistence file /config/mysensors1.pickle
        2020-04-18 09:57:00 DEBUG (SyncWorker_6) [mysensors.persistence] Saving sensors to persistence file /config/mysensors1.pickle
        **2020-04-18 09:57:00 DEBUG (MainThread) [homeassistant.components.mysensors.helpers] Node 1 is missing sketch name
        2020-04-18 09:57:00 DEBUG (MainThread) [homeassistant.components.mysensors.helpers] Node 0 is missing sketch name**
        2020-04-18 09:57:00 INFO (MainThread) [homeassistant.components.mysensors] Adding new devices: [<Entity Temperature Sensor 2 1: None>, <Entity Temperature Sensor 2 0: None>]
        2020-04-18 09:57:00 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Temperature Sensor 2 1: value_type 38, value = 2.85
        2020-04-18 09:57:01 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Temperature Sensor 2 0: value_type 0, value = 21.44
        2020-04-18 09:57:01 INFO (MainThread) [mysensors.gateway_serial] Trying to connect to /dev/ttyUSB0
        2020-04-18 09:57:01 INFO (MainThread) [mysensors] Connected to Serial<id=0x6b041470, open=True>(port='/dev/ttyUSB0', baudrate=38400, bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=False, rtscts=False, dsrdtr=False)
        2020-04-18 09:57:03 DEBUG (MainThread) [mysensors] Receiving 2;0;1;0;0;21.44
        2020-04-18 09:57:03 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 2 child 0
        2020-04-18 09:57:03 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Temperature Sensor 2 0: value_type 0, value = 21.44
        2020-04-18 09:57:10 DEBUG (SyncWorker_11) [mysensors.persistence] Saving sensors to persistence file /config/mysensors1.pickle
        **2020-04-18 09:57:16 WARNING (MainThread) [homeassistant.components.mysensors.gateway] Gateway /dev/ttyUSB0 not ready after 15.0 secs so continuing with setup**
        2020-04-18 09:57:35 DEBUG (MainThread) [mysensors] Receiving 2;0;1;0;0;21.44
        2020-04-18 09:57:35 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 2 child 0
        2020-04-18 09:57:35 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Temperature Sensor 2 0: value_type 0, value = 21.44
        2020-04-18 09:57:40 DEBUG (SyncWorker_2) [mysensors.persistence] Saving sensors to persistence file /config/mysensors1.pickle
        • electrikE
          electrikE
          electrik
          First, please use the code formatting for your posts. That makes it easier to read.
          I don't know about this timeout. How is the gateway working when you connect it to your PC?
          For the sketch name, does your sketch send it? Please post your sketch code
          • K
            K
            KevinT
            Hi electrik,
            Yes, my nodes send the sketch name within the presentation function.
            As for the gateway, I have not set up a sketch name, the example I found did not implement this, so I didn't think it
            was necessary?
            I manually named the gateway node in the configuration.yaml file, and the "missing sketch name" message no longer appears in the log. I guess, I'll add an entry for node 0 (controller) as well .
            I'm still getting the "USB0 not ready after 15.0 secs" at startup, but all seems to work regardless.
            I connected the gateway to my pc using mycontroller, it all works fine. Logs look normal.
            Here is the code for one of my nodes, a temperature node with Arduino mini & RFM69 radio, running on battery.
            #define MY_BAUD_RATE 38400
            //#define MY_RADIO_RF24
            #define MY_RADIO_RFM69
            #define MY_IS_RFM69HW
            #define MY_RFM69_FREQUENCY  RFM69_915MHZ
            #include <OneWire.h>
            #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
            #define ONE_WIRE_BUS 8 // Pin where dallas sensor is connected
            #define CHILD_ID_TEMP 0
            #define CHILD_ID_BATT 1
            // function protos
            void ReadBat(double& b, uint8_t& bPct);
            unsigned long SLEEP_TIME = 300000;    // Sleep time between reads (5min) (in milliseconds)
            const int BAT_V = A0;                 // battery voltage, AnaIn 0
            OneWire oneWire(ONE_WIRE_BUS);        // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
            DallasTemperature sensors(&oneWire);  // Pass the oneWire reference to Dallas Temperature.
            float lastTemperature;
            double bat, lastBat=0.0;
            uint8_t batPct;
            int numSensors=0;
            bool receivedConfig = false;
            bool metric = true;
            bool initialValuesSent = false;
            bool initialValTempSent = false;
            bool initialValBatSent = false;
            // Initialize message objects
            MyMessage msg(CHILD_ID_TEMP, V_TEMP);
            MyMessage msgBatt(CHILD_ID_BATT, V_VOLTAGE);
            void before()
              sensors.begin();
              Serial.print("Found ");
              Serial.print(sensors.getDeviceCount(), DEC);
              Serial.println(" temperature devices.");
            void presentation() {
              Serial.println("Sending presentation");
              sendSketchInfo("Temperature Sensor", "1.2");
              present(CHILD_ID_TEMP, S_TEMP, "Bed room Temperature");
              present(CHILD_ID_BATT, S_MULTIMETER, "Bed room node Voltage");
              int16_t conversionTime = 0;
              float temperature = 0;
              if (!initialValuesSent) {
                // Read in the battery voltage
                ReadBat(bat, batPct);
                // get temperature conversion time
                conversionTime = sensors.millisToWaitForConversion(sensors.getResolution());
                wait(conversionTime);
                // Fetch temperature
                temperature = sensors.getTempCByIndex(0);
                // send the temperature reading
                // set(float value, uint8_t decimals)
                send(msg.set(temperature, 2));
                Serial.println("Requesting initial Temp value from controller");
                request(CHILD_ID_TEMP, V_TEMP);
                wait(2000, C_SET, V_TEMP);
                // send bat voltage
                send(msgBatt.set(bat, 2));
                Serial.println("Requesting initial Batt value from controller");
                request(CHILD_ID_BATT, V_VOLTAGE);
                wait(2000, C_SET, V_VOLTAGE);
              else {
                // Fetch temperatures from Dallas sensors (non-blocking)
                sleep(conversionTime);
                // Read temperature and send to controller
                Serial.println("temperature: ");
                Serial.println(temperature);
                #if COMPARE_TEMP == 1
                if (lastTemperature != temperature && temperature != -127.00 && temperature != 85.00) {
                #else
                  lastTemperature=temperature;
                // Send in the new battery level
                sendBatteryLevel(batPct);
                // Save the battery level for next compare
                lastBat = bat;
                Serial.println("Sleep...");
                sleep(SLEEP_TIME);
              if (message.isAck()) {
              if (message.type == V_TEMP) {
                if (!initialValTempSent) {
                  Serial.println("Received initial temp value from controller");
                  initialValTempSent = true;
              else if (message.type == V_VOLTAGE) {
                if (!initialValBatSent) {
                  Serial.println("Received initial bat value from controller");
                  initialValBatSent = true;
              if (initialValTempSent && initialValBatSent)
                initialValuesSent = true;
            // b - battery voltage
            // bPct - battery percent
              long sumBat=0;
              int i;
              // take average over 64 readings
              for (i = 0; i < 64; ++i) {
                // read & sum battery voltage
                sumBat += analogRead(BAT_V);
              sumBat = sumBat >> 6;      // shift 6 -> divide by 64
              b = sumBat*3.3/1023.0;
              bPct = (uint8_t)(sumBat*100.0/1023.0);
            Here is the serial gateway sketch:
            #include <SoftwareSerial.h>
            SoftwareSerial softSerial(8, 9); // RX, TX
            #define MY_DEBUGDEVICE softSerial
            // You also need to create softSerial in setup()
            //#define MY_RADIO_NRF5_ESB
            //#define MY_RADIO_RFM95
            // Enable serial gateway
            #define MY_GATEWAY_SERIAL
            // Define a lower baud rate for Arduinos running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
            #if F_CPU == 8000000L
            // Enable inclusion mode
            // Set blinking period
            // Flash leds on rx/tx/err
              softSerial.begin(38400);
