  3. Wemos d1 mini : gateway error .
13 Posts 2 Posters 1.2k Views 2 Watching
  • David MarlingeD
    David MarlingeD
    David Marlinge
    this is the first time I'm trying to work with mysensors.
    So I have a wemos d1 mini and a nrf24L01.
    I upload gateway8266 sketch on the wemos card.
    I setup an ip adress (192.168.1.111) gateway 192.168.1.1 and submask : 255.255.255.0.
    But it does work, I can't reach the adress.
    If I plug the wemos on my computer, and launch the serial monitor in arduino IDE, I get this .
    09:15:10.888 -> f`f⸮⸮ff⸮⸮⸮20389 TSM:FAIL:RE-INIT
    09:15:10.888 -> 20413 TSM:INIT
    09:15:10.935 -> 20433 !TSM:INIT:TSP FAIL
    09:15:10.935 -> 20459 TSM:FAIL:CNT=3
    09:15:10.983 -> 20481 TSM:FAIL:DIS
    09:15:10.983 -> 20501 TSF:TDI:TSL
    What do I have to do ?
    Thank you
    PS : i tried with another wemos and same issue.
    • David MarlingeD David Marlinge
      Thank you
      Welcome to the forum @David-Marlinge
      !TSM:INIT:TSP FAIL
      This means that the wemos was unable to initialize the nrf24 radio. Double-check the wiring. If you can't find anything wrong, post multiple photos of the wiring and we'll help check. Plase also post the entire sketch (with wifi namn/password removed).
      If you haven't already, see https://forum.mysensors.org/topic/666/read-this-first-it-could-save-you-a-lot-of-time/ for how to efficiently troubleshoot.
      • David MarlingeD
        David MarlingeD
        David Marlinge
        Oh, I will check the wiring ...
        I taught It means that it can't connect to wifi ...
        So it's normal that I can't ping the wemos ...
        For the sketch I just upload the example sketch for esp8266gateway..
         * Version 1.0 - Henrik Ekblad
         * Contribution by Ivo Pullens (ESP8266 support)
         * The EthernetGateway sends data received from sensors to the WiFi link.
         * VERA CONFIGURATION:
         * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
         * E.g. If you want to use the default values in this sketch enter: 192.168.178.66:5003
         * LED purposes:
         * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
         * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
         * - ERR (red) - fast blink on error during transmission error or receive crc error
         * See https://www.mysensors.org/build/connect_radio for wiring instructions.
         * If you are using a "barebone" ESP8266, see
         * https://www.mysensors.org/build/esp8266_gateway#wiring-for-barebone-esp8266
         * Inclusion mode button:
         * - Connect GPIO5 (=D1) via switch to GND ('inclusion switch')
        #define MY_BAUD_RATE 9600
        #define MY_RADIO_RF24
        //#define MY_RADIO_RFM95
        #define MY_GATEWAY_ESP8266
        #define MY_WIFI_SSID "xxxx"
        #define MY_WIFI_PASSWORD "xxxxxx"
        // Enable UDP communication
        //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
        #define MY_HOSTNAME "ESP8266_GW"
        #define MY_IP_ADDRESS 192,168,1,112
        #define MY_IP_GATEWAY_ADDRESS 192,168,1,1
        #define MY_PORT 5003
        //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
        // Enable inclusion mode
        //#define MY_INCLUSION_MODE_BUTTON_PIN D1
        // Set blinking period
        //#define MY_DEFAULT_LED_BLINK_PERIOD 300
        // Flash leds on rx/tx/err
        // Led pins used if blinking feature is enabled above
           * LED purposes:
          @David-Marlinge test it is normal, if there is a problem with the nrf24. A gateway is (usually) not useful if it can’t talk to any nodes, so it will block if initialization fails.
          • David MarlingeD
            David MarlingeD
            David Marlinge
            Now the wiring check.
            I have a nrf24l01 with antenna, and nothing is written on the board ...
            Does someone have a wiring diagram for that nrf module ?
            Thank you.
              Thank you.
              @David-Marlinge could you expand on what you mean by "nothing is written on the board". Which board?
              The wiring is available at https://www.mysensors.org/build/connect_radio#nrf24l01+-&-esp8266
              • David MarlingeD
                David MarlingeD
                David Marlinge
                nothing is written on the nrf24L01 board ...
                I send a picture ...
                  @David-Marlinge the nrf24 chip is not a board in the Arduino board meaning. Nothing can be written to it. It must be connected to a microcontroller to be useful.
                  • David MarlingeD
                    David MarlingeD
                    David Marlinge
                    If it's the same wiring, I connect like your link, but it does not work.
                    Now I can ping the wifi adress even if the nrf24l01 is not plugin ... In fact It doesn't take the adress I give in the sketch ....
                    • David MarlingeD
                      David MarlingeD
                      David Marlinge
                      What I want to say, is that nothing is written on the pin ... So How can I be sure where the gnd, vcc and so on are ???
                        @David-Marlinge I see. Sorry for misunderstanding.
                        The pinout is probably compatible with the smaller nrf24 (without PA). If you can, check with the vendor/store where you bought the nrf24.
                        • David MarlingeD
                          David MarlingeD
                          David Marlinge
                          I have already check, nothing is written on the store where i bought them ...
                          Is tha capacitor needed ? and Must the whole thing works connected on a PC usb ?
                          • David MarlingeD
                            David MarlingeD
                            David Marlinge
                            So I check the wiring. I think a wire was not well plugged.
                            Now it works.
                            I have such "sentences" :
                            11:52:22.169 -> 12496 GWT:TIN:CONNECTING...
                            11:52:22.499 -> scandone
                            11:52:23.204 -> 13525 GWT:TIN:CONNECTING...
                            11:52:23.204 -> 13555 GWT:TIN:IP: 192.168.1.111
                            11:52:23.251 -> 13588 MCO:BGN:STP
                            11:52:23.251 -> 13607 MCO:BGN:INIT OK,TSP=1
                            11:52:23.298 -> 13637 TSM:READY:NWD REQ
                            11:52:23.346 -> 13665 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                            11:52:23.535 -> pm open,type:2 0
