  3. PWM control
PWM control
16 Posts 4 Posters 1.5k Views 3 Watching
  • doodoovaneD
    doodoovaneD
    doodoovane
    Hello everyone,
    The aim here is to control the speed of a 5v fan with PWM of an arduino nano.
    I usualy do it with this code:
    const byte OC1A_PIN = 9;
    const byte OC1B_PIN = 10;
    const word PWM_FREQ_HZ = 25000; //Adjust this value to adjust the frequency
    const word TCNT1_TOP = 16000000/(2*PWM_FREQ_HZ);
    byte in = 0;
      pinMode(OC1A_PIN, OUTPUT);
      Serial.begin(9600);
      Serial.println("Demarage du PWM"); // so I can keep track of what is loaded
      // Clear Timer1 control and count registers
      TCCR1A = 0;
      TCCR1B = 0;
      TCNT1  = 0;
      // Set Timer1 configuration
      // COM1A(1:0) = 0b10   (Output A clear rising/set falling)
      // COM1B(1:0) = 0b00   (Output B normal operation)
      // WGM(13:10) = 0b1010 (Phase correct PWM)
      // ICNC1      = 0b0    (Input capture noise canceler disabled)
      // ICES1      = 0b0    (Input capture edge select disabled)
      // CS(12:10)  = 0b001  (Input clock select = clock/1)
      TCCR1A |= (1 << COM1A1) | (1 << WGM11);
      TCCR1B |= (1 << WGM13) | (1 << CS10);
      ICR1 = TCNT1_TOP;
    if (Serial.available()) {       // Check if there's data
        char buf[10];
        int in = Serial.readBytesUntil('\n', buf, sizeof buf - 1);
        buf[in]=0;
        in = atoi(buf);
        if (in > 100)
          in = 100;
        Serial.println(in);// Pass the value of "in" to the pin}
        setPwmDuty(in); //Change this value 0-100 to adjust duty cycle
    void setPwmDuty(byte duty) {
      OCR1A = (word) (duty*TCNT1_TOP)/100;
    Is it possible to do the same with mysensors?
    The next step of this would be to connect the arduino via USB and control it using domoticz.
    YveauxY 1 Reply Last reply
    • doodoovaneD doodoovane
      Hello everyone,
      byte in = 0;
        Serial.begin(9600);
        TCCR1A = 0;
        TCCR1B = 0;
        TCNT1  = 0;
        ICR1 = TCNT1_TOP;
          char buf[10];
          buf[in]=0;
          in = atoi(buf);
          if (in > 100)
            in = 100;
      YveauxY
      YveauxY
      @Dovane-Benattar ofcourse! All the initialization and pwm setting code should be copied to the mysensors sketch, and the serial reading could be replaced by mysensors message handling.
      • doodoovaneD
        doodoovaneD
        doodoovane
        Thanks Yveaux! I will give it a try like this
        • doodoovaneD
          doodoovaneD
          doodoovane
          @Yveaux thank you for your answer!
          * The ArduinoGateway prints data received from sensors on the serial link.
          * The gateway accepts input on serial which will be sent out on radio network.
          * The GW code is designed for Arduino Nano 328p / 16MHz
          * Wire connections (OPTIONAL):
          * - Inclusion button should be connected between digital pin 3 and GND
          * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
          * LEDs (OPTIONAL):
          * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
          * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
          * - ERR (red) - fast blink on error during transmission error or receive crc error
          #define MY_RADIO_RF24
          //#define MY_RADIO_NRF5_ESB
          //#define MY_RADIO_RFM95
          // Enable serial gateway
          #define MY_GATEWAY_SERIAL
          // Define a lower baud rate for Arduinos running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
          #if F_CPU == 8000000L
          #define MY_BAUD_RATE 38400
          // Enable inclusion mode
          // Set blinking period
          // Flash leds on rx/tx/err
          byte in = 0;
            Serial.begin(9600);
            Serial.print(0);
            TCCR1A = 0;
            TCCR1B = 0;
            TCNT1  = 0;
            ICR1 = TCNT1_TOP;
              char buf[10];
              buf[in]=0;
              in = atoi(buf);
              if (in >= 100)
                in = 100;
          Can you tell me if this could work? (I tried but it does not.. maybe I do something else wrong)
          • doodoovaneD
            doodoovaneD
            doodoovane
            Some news, it works now!
            I took some code for a dimmable LED here
            The only problem now is that the fan does a little sound it didn't with the first code.
            here is the code:
            * LEDs (OPTIONAL):
            //#define MY_RADIO_RF24
            #define SN "DimmableLED"
            #define SV "1.1"
            #define LED_PIN 9      // Arduino pin attached to MOSFET Gate pin
            #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
            static int16_t currentLevel = 0;  // Current dim level...
            MyMessage dimmerMsg(0, V_DIMMER);
            MyMessage lightMsg(0, V_LIGHT);
             request( 0, V_DIMMER );
             present( 0, S_DIMMER );
                sendSketchInfo(SN, SV);
                if (message.getType() == V_LIGHT || message.getType() == V_DIMMER) {
                    requestedLevel *= ( message.getType() == V_LIGHT ? 100 : 1 );
                    // Clip incoming level to valid range of 0 to 100
                    Serial.print( "Changing level to " );
                    Serial.print( ", from " );
                    Serial.println( currentLevel );
                    fadeToLevel( requestedLevel );
                    send(lightMsg.set(currentLevel > 0));
                    // hek comment: Is this really nessesary?
                    send( dimmerMsg.set(currentLevel) );
             *  This method provides a graceful fade up/down effect
            void fadeToLevel( int toLevel )
                int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
                while ( currentLevel != toLevel ) {
                    currentLevel += delta;
                    analogWrite( LED_PIN, (int)(currentLevel / 100. * 255) );
                    delay( FADE_DELAY );
            Do you have any idea why it does this?
            • scalzS
              scalzS
              wrote on last edited by scalz
              @doodoovane
              not sure if I get it, but the little sound could be generated by pwm freq.
              Note, your last sketch is not ideal:
              • don't send msg in receive(). it's better to update a variable, and check this variable in loop() for sending a msg, to avoid recursive call to receive()
              • Same for your fading function, it's better to call it from loop(). Receive() should finish as fast as possible.
              • don't use delay() in your fading function, it's a blocking function. It's better to do this async, in a non-blocking way, or use wait() as it can process received msg in background .
              mfalkviddM doodoovaneD 2 Replies Last reply
              • scalzS scalz
                @doodoovane
                @scalz the delay() and send() calls are from the MySensors example, my guess is that doodoovane just followed the example.
                • scalzS
                  scalzS
                  @mfalkvidd
                  yep I noticed that. I just provided a few feedbacks for his future sketches :)
                  • scalzS scalz
                    @doodoovane
                    doodoovaneD
                    doodoovaneD
                    doodoovane
                    @scalz that's what I thought but it doesn't make any sound with the first code I posted.
                    Something to do with the frequency maybe?
                    • doodoovaneD
                      doodoovaneD
                      doodoovane
                      This post is deleted!
                      • doodoovaneD
                        doodoovaneD
                        doodoovane
                        Me again!
                        So the problem seemed to be the frequency as I don't have sound anymore.
                        With a little hindsight, I looked back at @Yveaux's messages (here and on another post) and here is what I've tried.
                        * LEDs (OPTIONAL):
                        #include <TimerOne.h>
                        #define SV "1.1"
                         #define PWM_FREQ_HZ (25000)
                        #define PWM_CYCLE_US (1000000/PWM_FREQ_HZ)
                        Timer1.initialize(PWM_CYCLE_US);
                        Timer1.pwm(LED_PIN, 1023);
                                requestedLevel = requestedLevel >= 101 ? 100 : requestedLevel;
                        No more sound, but now Can't get it more than 99% in domoticz... The only way to get 100% is to turn it off and turn it back on. As long as you touch the slider, no more 100%...
                        Any clue of what can cause this?
                          Me again!
                          * LEDs (OPTIONAL):
                          #define SV "1.1"
                          YveauxY
                          YveauxY
                          @doodoovane why do you use analogwrite instead of Timer1.setPwmDuty?
                          Also, the fading should not be required for a fan.
                          Iirr the maximum duty value is 1023. Likely the fan won't be at its maximum speed then, only when you supply it a continuous high 'pulse'. Is that what you mean by 99%?
                          doodoovaneD 1 Reply Last reply
                          • YveauxY Yveaux
                            doodoovaneD
                            doodoovaneD
                            doodoovane
                            @Yveaux said in PWM control:
                            Timer1.setPwmDuty
                            I did but there must be something wrong with my code as the PWM doesn't work anymore.
                            Here is my try:
                            #define SN "Fan_PWM"
                            #define SV "1.3"
                                    Timer1.setPwmDuty(LED_PIN, requestedLevel);
                            What I mean by 99% is that the slider of the dimmer when pulled to 100% come back to 99% (as I can see in my switch log) in domoticz. And there is no "100%" input just like if I pulled the slider to 99%...
                            • doodoovaneD
                              doodoovaneD
                              doodoovane
                              Hello everyone,
                              I'm still stuck with my problem as I don't fin any solution.
                              Is there a way to say in the code "if level is at 100%, stop the PWM regulation (full power fan)" ?
                              Thank you for your help
                                Hello everyone,
                                @doodoovane you can change
                                to
                                requestedLevel = requestedLevel > 98 ? 100 : requestedLevel;
                                  to
                                  doodoovaneD
                                  doodoovaneD
                                  doodoovane
                                  @mfalkvidd said in PWM control:
                                  Thank You @mfalkvidd it works that way! Domoticz still showing me his 99% but at least the fan is going 100%.
                                  Thank you for your help, sometime thing can get easier :)
