  3. Help to identify Arduino pro mini clone components
4 Posts 3 Posters 796 Views 3 Watching
  • B
    B
    barrydou
    wrote on last edited by barrydou
    Hello
    I have some Arduino pro mini Chineese clones which are not exactly made like original. I know it's normal :)
    I m trying to recognize components but i m note sure.
    Here is a picture of the part or the card.
    I Hope the number i ve added are visible.
    So what is
    1: no Idea.
    2: a diode
    3: voltage regulator
    4: led indicating power on
    5: resistor for the led 4 ?
    6: "small" capacitor on vcc ?
    7: "Big" capacitor on raw pin ?
    8: "Big" capacitor on vcc ?
    9: "small" capacitor on rst pin ?
    10 : oscillator
    Without ?, I'm quite sure. With ? I'm not sure but don't see what else it could be, and no Idea => no Idea 🤣
    Thank you for your knowledge
    skywatchS YveauxY 2 Replies Last reply
    • B barrydou
      Hello
      So what is
      1: no Idea.
      2: a diode
      10 : oscillator
      skywatchS
      skywatchS
      skywatch
      @barrydou You got it right!
      1. Is a polyfuse that protects the module from overcurrent. It will go open circuit in the event of a current surge, but will 'self-heal' over a period of hours (some say to put in the freezer over night!).
      A search on the net will get you the circuit diagram as well, this might help.
      • B barrydou
        Hello
        So what is
        1: no Idea.
        2: a diode
        10 : oscillator
        YveauxY
        YveauxY
        @barrydou you seem right about the component types. If you doubt on their connection or use, just use a multimeter to trace signals
        • B
          B
          barrydou
          Thank you so much.
          I did not found any schematic for those boards. And the diode and polyfuse are not on the sparkfun design.
          The diode let me crazy when trying to verify and trace the signal with multimeter. I take a long time before understanding why my multimeter some times say connected, sometime say not connected. And this night, I tell myself : it's a diode :)
          Thank you again !
