💬 backup power auto-switch circuit
Sounds interesting. Please post the schematic as well.
@NeverDie of course, I'll add it now
@NeverDie I tried to add it, but it seems "kicad_sch" extension isn't supported now
@Abd-AlHaleem You have three options:
- Print it as a .pdf file. You can upload those; or,
- Compress the kicad file as a .rar file, but not a .zip file. That will also upload.
- Best option: Archive the kicad project (as a .zip file by default), and then compress that as a .rar file. That way you can upload the entire kicad project without it being rejected.
Thanks for posting the schematic. Just an observation, not a criticism: it looks as though the output voltage will sag down to the level of the logic-LOW threshold of your NOR gate before the battery voltage takes over. Depending on what the load is, maybe that's a non-issue. If, on the other hand, it turns out to be an issue, you could perhaps use a voltage divider to trigger the switch-over with less of a voltage drop seen at the load. In either case, I like the simplicity of the circuit.
@NeverDie
Based on my simulation and testing it's not a problem, yet I can look at it and check it's transient response.
Encapsulated transformers instead of traditional switching power supplies like Hi-Link
Hardware • 22 Feb 2017, 10:49 • robosensor 31 May 2017, 19:17 -
Voltage divider for radio
Hardware • 23 Jul 2016, 16:53 • CrankyCoder 24 Jul 2016, 20:02 -
Arduino Mini Pro 5v - how to power
Troubleshooting • 3 Sept 2014, 21:43 • ddluk 11 Sept 2014, 03:30 -
Multiple repeater nodes
Hardware • 18 Dec 2014, 14:12 • boozz 19 Dec 2014, 14:42 -
💬 6Gang30AmpsLatchRelayEspHomeReady
OpenHardware.io • 29 Nov 2022, 19:11 • openhardware.io 1 Dec 2022, 06:49 -
Static Node ID and other Unanswered Questions
Troubleshooting • 27 Dec 2014, 02:46 • A Former User 27 Dec 2014, 13:11 -
Low-cost WIFI modules as alternative
Hardware • 22 Oct 2014, 23:26 • Diego Baravalle 23 Oct 2014, 18:23
