  3. Where are the debug messages documented ?
debug
5 Posts 3 Posters 4.9k Views 2 Watching
  • J
    J
    joshmosh
    I am relatively new to MySensors and now trying to get my first sensor up. My serial gateway runs on an Arduino Uno, which is connected to a Raspbery Pi 2. So far, so good.
    I am now trying to prototype a temperature/humidity sensor with a DYPTH01.
    I get a bunch of debug output from the gateway and from the sensor (also on a Uno) , with quite a few of "fail", so I guess that something is wrong. Now I am trying to find out what is wrong ...K
    I have searched quite a bit, but I was not successful to find any documention on how to interpret the debug output. May I ask a kind soul to please point me to a description ? Or have I really browse through the source code of MySensors ?
    Any help is highly welcome. Thanks a bunch in advance.
    Cheers,
    Josh
    • rvendrameR
      rvendrameR
      rvendrame
      @joshmosh , if you enabled debug you should see messages going in and out on serial monitor.
      Message format is described here: http://www.mysensors.org/download/serial_api_14
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      • J
        J
        joshmosh
        @rvendrame
        Thank you very much for your reply. I know that part of the documentation quite well, since I have written a serial gateway emulator to send sensor data, which is collected locally on the Raspberry Pi to the controller (Domoticz). My question relates to the other stuff, which looks like 0-0-255-255 pt=7 c=3 etc. My guess is that this is the debug information, whereas the other stuff (0;0;3;9; as an example) is the serial gateway protocol. I would like to know the meaning of the debug messages, because I think these may be useful to help me in debugging my code.
        Thanks a lot again
        Josh
          http://forum.mysensors.org/topic/866/help-understanding-addressing-and-log-messages/2
          • J
            J
            joshmosh
            @hek: Ah, ok, thanks a lot ! That gives some clarification and will hopefully help to catch the bugs.
            Thank you !
            Josh
