  3. noob question Humidity sketch
4 Posts 2 Posters 1.8k Views 2 Watching
  • J
    J
    jeti
    is it correct, that the standard humidity sketch is only sending new values when there is a change?
    In my case, as the temp and humidity is constant, there can be hours without new reading ( Iam using DHT11)
    It would be great to get a short feedback if this is "how it should be" in the standard configuration?
    Does anybody has a sketch where every time all the data is send?
    thanks
    • T
      TimO
      Just change the following statement (line 41)
      to
      } else {
      and the same with line 54.
      • J
        J
        jeti
        thanks!
        is the reason for this saving of battery live? -> less sending?
        • T
          TimO
          Yes, I think that is the main reason. :-)
