  3. S_RAIN
S_RAIN
15 Posts 3 Posters 7.1k Views 1 Watching
  • BulldogLowellB
    BulldogLowellB
    BulldogLowell
    wrote on last edited by BulldogLowell
    I cannot get this to present a sensor without disrupting the UI
    gw.sendSensorPresentation(1, S_RAIN);
    Anyone used this one yet?
      You are the pioneer!
      What do you mean by disrupting UI?
      • BulldogLowellB
        BulldogLowellB
        BulldogLowell
        it glitches out the UI and I can't seem to get it working.
        if I uncomment out the S_RAIN I get the attached.
        Comment it out, and the rest present fine
        #include <Sleep_n0m1.h>
        #include <EEPROM.h>
        #include <OneWire.h>
        #include <RF24.h>
        #include <Sensor.h>
        unsigned long SLEEP_TIME = 30; // Sleep time between reads (in seconds)
        OneWire oneWire(ONE_WIRE_BUS);
        Sensor gw;
        Sleep sleep;
        int numSensors=0;
        boolean metric;
        float rainLevel = 0.25;
        float tempSensor = 72.5;
        float pressure = 10000;
        float humidity = 50;
          sensors.begin();
          gw.begin();
          gw.sendSketchInfo("Rain Guage", "0.9a");
          gw.sendSensorPresentation(0, S_TEMP);
          //gw.sendSensorPresentation(1, S_RAIN);
          gw.sendSensorPresentation(2, S_BARO);
          gw.sendSensorPresentation(3, S_HUM);
          gw.sendSensorPresentation(4, S_MOTION);
          metric = gw.isMetricSystem();
          delay(2000);
          gw.sendVariable(0, V_TEMP, tempSensor,1);
          //gw.sendVariable(1, V_RAIN, ".25");
          gw.sendVariable(2, V_PRESSURE, "11000");
          gw.sendVariable(3, V_HUM, "45");
          gw.sendVariable(4, V_TRIPPED, 1);
        YveauxY 1 Reply Last reply
          #include <EEPROM.h>
          #include <RF24.h>
          #include <Sensor.h>
          Sensor gw;
          Sleep sleep;
          int numSensors=0;
          boolean metric;
            sensors.begin();
            gw.begin();
            delay(2000);
          YveauxY
          YveauxY
          @BulldogLowell I don't have any Vera experience, but could it have something to do with the value you sent for V_RAIN? Maybe try 0.25 or an integer value and see what happens.
          • YveauxY Yveaux
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            @Yveaux
            thanks, it doesn't present right even of I don't send it a value (i.e. comment out the gwsendVariable)
              You are the first to use these devices. Fragments of the MySensors Versa plugin came from from the RFXtrx-plugin (especially the list of devices).
              What happens if you upload the device-files from here?
              http://code.mios.com/trac/mios_rfxtrx/browser/trunk
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                that makes sense, you need the device vera-side.
                I tried that and it did the same thing.
                Where is the connection between the device(vera) and the S_RAIN variable in the sketch? Is it in the library files? at the gateway?
                  The connection is actually made in MySenosrs Vera plugin file:
                  https://github.com/mysensors/Vera/blob/master/L_Arduino.lua#L81
                  And this describes how it should be displayed:
                  http://code.mios.com/trac/mios_rfxtrx/browser/trunk/D_RainSensor1.json
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    @hek
                    perhaps there is a problem with the json or xml file on lolodomo's last edit?
                    I can check with him in the vera forum...
                      @hek
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      @BulldogLowell said:
                      @hek
                      I tried other sensor types which I had not had on Vera before and cannot seem to get any of them to work/display (e.g. S_WIND).
                      I must be missing a file vera-side, no?
                        Could be. Anything in vera log?
                          BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          @hek
                          Can you create a RAIN device?
                          the log is here. Note that Lua restarts over and over.
                          I confirmed with lolodomo that I need all three files D_RainSensor1.xml D_RainSensor1.json and S_RainSensor1.xml, which I installed.
                          19655 root 0 Z [GetNetworkState]
                          19674 root 1676 R ps axf
                          03 06/08/14 7:37:00.955 LuaUPNP: starting bLogUPnP 0 <0x2ac9f000>
                          02 06/08/14 7:37:00.975 JobHandler_LuaUPnP::Run: pid 14768 didn't exit <0x2ac9f000>
                          02 06/08/14 7:37:01.168 UserData::LoadUserData previous: 0 from 1.5.622 <0x2ac9f000>
                          09 06/08/14 7:37:01.169 UserData::ParseRooms 1 Exterior <0x2ac9f000>
                          09 06/08/14 7:37:01.169 UserData::ParseRooms 2 Living Room <0x2ac9f000>
                          09 06/08/14 7:37:01.169 UserData::ParseRooms 3 Family Room <0x2ac9f000>
                          09 06/08/14 7:37:01.170 UserData::ParseRooms 4 PlayRoom <0x2ac9f000>
                          09 06/08/14 7:37:01.170 UserData::ParseRooms 5 Dining Room <0x2ac9f000>
                          09 06/08/14 7:37:01.170 UserData::ParseRooms 6 Hallway <0x2ac9f000>
                          03 06/08/14 7:37:01.247 UserData::LoadUserData BuildVersion: 1.5.622 SvnVersion: 7546 Model: 33 MiCasaVerde VeraLite flush: 0 changed: 0 resync: 9227 syncdevice:0 <0x2ac9f000>
                          01 06/08/14 7:37:01.582 Device_LuaUPnP::LoadDeviceDoc ixmlParseBufferEx /etc/cmh-ludl//D_RainSensor1.xml size 15875 ret 106 <0x2ac9f000>
                          01 06/08/14 7:37:01.583 JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 79/D_RainSensor1.xml so device 16 is offline <0x2ac9f000>
                          01 06/08/14 7:37:02.010 Device_LuaUPnP::CreateServices Aborting device 16 because the topmost device has no interface <0x2ac9f000>
                          01 06/08/14 7:37:02.010 JobHandler_LuaUPnP::CreateAllServices failed to create 16 <0x2ac9f000>
                          01 06/08/14 7:37:02.055 Device_LuaUPnP::CreateServices Aborting device 48 because the topmost device has no interface <0x2ac9f000>
                          01 06/08/14 7:37:02.056 JobHandler_LuaUPnP::CreateAllServices failed to create 48 <0x2ac9f000>
                          01 06/08/14 7:37:02.056 Device_LuaUPnP::CreateServices Aborting device 49 because the topmost device has no interface <0x2ac9f000>
                          01 06/08/14 7:37:02.056 JobHandler_LuaUPnP::CreateAllServices failed to create 49 <0x2ac9f000>
                          01 06/08/14 7:37:02.056 Device_LuaUPnP::CreateServices Aborting device 50 because the topmost device has no interface <0x2ac9f000>
                          01 06/08/14 7:37:02.056 JobHandler_LuaUPnP::CreateAllServices failed to create 50 <0x2ac9f000>
                          01 06/08/14 7:37:02.057 Device_LuaUPnP::CreateServices Aborting device 51 because the topmost device has no interface <0x2ac9f000>
                          01 06/08/14 7:37:02.057 JobHandler_LuaUPnP::CreateAllServices failed to create 51 <0x2ac9f000>
                          01 06/08/14 7:37:02.057 Device_LuaUPnP::CreateServices Aborting device 52 because the topmost device has no interface <0x2ac9f000>
                          01 06/08/14 7:37:02.057 JobHandler_LuaUPnP::CreateAllServices failed to create 52 <0x2ac9f000>
                          01 06/08/14 7:37:02.057 Device_LuaUPnP::CreateServices Aborting device 53 because the topmost device has no interface <0x2ac9f000>
                          01 06/08/14 7:37:02.058 JobHandler_LuaUPnP::CreateAllServices failed to create 53 <0x2ac9f000>
                          01 06/08/14 7:37:02.058 Device_LuaUPnP::CreateServices Aborting device 54 because the topmost device has no interface <0x2ac9f000>
                          01 06/08/14 7:37:02.058 JobHandler_LuaUPnP::CreateAllServices failed to create 54 <0x2ac9f000>
                          01 06/08/14 7:37:02.058 Device_LuaUPnP::CreateServices Aborting device 55 because the topmost device has no interface <0x2ac9f000>
                          01 06/08/14 7:37:02.059 JobHandler_LuaUPnP::CreateAllServices failed to create 55 <0x2ac9f000>
                          01 06/08/14 7:37:02.059 Device_LuaUPnP::CreateServices Aborting device 56 because the topmost device has no interface <0x2ac9f000>
                          01 06/08/14 7:37:02.059 JobHandler_LuaUPnP::CreateAllServices failed to create 56 <0x2ac9f000>
                          01 06/08/14 7:37:02.144 Device_LuaUPnP::CreateServices Aborting device 64 because the topmost device has no interface <0x2ac9f000>
                          01 06/08/14 7:37:02.144 JobHandler_LuaUPnP::CreateAllServices failed to create 64 <0x2ac9f000>
                          01 06/08/14 7:37:02.144 Device_LuaUPnP::CreateServices Aborting device 67 because the topmost device has no interface <0x2ac9f000>
                          01 06/08/14 7:37:02.144 JobHandler_LuaUPnP::CreateAllServices failed to create 67 <0x2ac9f000>
                          01 06/08/14 7:37:02.145 Device_LuaUPnP::CreateServices Aborting device 68 because the topmost device has no interface <0x2ac9f000>
                          01 06/08/14 7:37:02.145 JobHandler_LuaUPnP::CreateAllServices failed to create 68 <0x2ac9f000>
                          01 06/08/14 7:37:02.145 Device_LuaUPnP::CreateServices Aborting device 69 because the topmost device has no interface <0x2ac9f000>
                          01 06/08/14 7:37:02.145 JobHandler_LuaUPnP::CreateAllServices failed to create 69 <0x2ac9f000>
                          01 06/08/14 7:37:02.152 Device_LuaUPnP::CreateServices Aborting device 74 because the topmost device has no interface <0x2ac9f000>
                          01 06/08/14 7:37:02.152 JobHandler_LuaUPnP::CreateAllServices failed to create 74 <0x2ac9f000>
                          01 06/08/14 7:37:02.152 Device_LuaUPnP::CreateServices Aborting device 75 because the topmost device has no interface <0x2ac9f000>
                          01 06/08/14 7:37:02.152 JobHandler_LuaUPnP::CreateAllServices failed to create 75 <0x2ac9f000>
                          01 06/08/14 7:37:02.152 Device_LuaUPnP::CreateServices Aborting device 76 because the topmost device has no interface <0x2ac9f000>
                          01 06/08/14 7:37:02.153 JobHandler_LuaUPnP::CreateAllServices failed to create 76 <0x2ac9f000>
                          01 06/08/14 7:37:02.153 Device_LuaUPnP::CreateServices Aborting device 77 because the topmost device has no interface <0x2ac9f000>
                          01 06/08/14 7:37:02.153 JobHandler_LuaUPnP::CreateAllServices failed to create 77 <0x2ac9f000>
                          01 06/08/14 7:37:02.153 Device_LuaUPnP::CreateServices Aborting device 78 because the topmost device has no interface <0x2ac9f000>
                          01 06/08/14 7:37:02.154 JobHandler_LuaUPnP::CreateAllServices failed to create 78 <0x2ac9f000>
                          01 06/08/14 7:37:02.154 Device_LuaUPnP::CreateServices Aborting device 79 because the topmost device has no interface <0x2ac9f000>
                          01 06/08/14 7:37:02.154 JobHandler_LuaUPnP::CreateAllServices failed to create 79 <0x2ac9f000>
                          02 06/08/14 7:37:02.182 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x2ac9f000>
                          02 06/08/14 7:37:02.184 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x2ac9f000>
                          02 06/08/14 7:37:02.186 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x2ac9f000>
                          02 06/08/14 7:37:02.188 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x2ac9f000>
                          02 06/08/14 7:37:02.198 Device_Service::MatchupUpnpServices no upnp service for urn:upnp-org:serviceID:VContainer1 <0x2ac9f000>
                          • BulldogLowellB
                            BulldogLowellB
                            BulldogLowell
                            @hek
                            I think it would be most helpful if you could confirm you are able to create a S_RAIN device.
                            RainGuage.ino
                              It pops up for me... (just tried adding a device manually)
                              Did you download the device.files as a zip.file (you'll find the download-link at the bottom of the page) ? Looks like the rain-xml file is corrupt.. it can happen if you download them one-by-one.
                                BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                @hek
                                THANKS!!!
                                it was that simple....
