  3. IR blaster for AC , TV etc.
ir blaster
17 Posts 6 Posters 9.7k Views 4 Watching
  • D Offline
    Dheeraj
    wrote on last edited by Dheeraj
    Any one tried using IR transmitter to send IR signal to AC with mini pro ( 328p ) as mysensor node. I know mini pro have limited ram / rom support.
    Note: AC remote send long IR signals which may not be completely captured by IR receivers connected to mini pro. may be one try on rasp pi but that's a last resort.
    Moshe LivneM 2 Replies Last reply
    • D Dheeraj
      Moshe LivneM Offline
      Moshe Livne
      @Dheeraj I am in the same boat. so far I was unable to replay ac codes. the ir blaster project should be able to do that.
      • K Offline
        K Offline
        kalle
        here is the link: http://forum.mysensors.org/topic/1402/ir-blaster-community-feedback-requested
        • D Dheeraj
          Moshe Livne
          @Dheeraj Just a note: Although this project looks promising it still remains to be seen if it can decode/encode the sequences and the software part of it (the learning, storing and retrieving) does not exists yet. So early days.... I do wish broadlinks rm2 would be open protocol. it has such a great library of codes. Oh well...
          D 1 Reply Last reply
          • Moshe LivneM Moshe Livne
            Dheeraj
            @Moshe-Livne the IR library i used is some how fails to decode and dump the AC IR signal received even after increasing the buffer size RAWBUF, not sure how broadlinks rm2 is working.. basically i used mini pro node as IR receiver/emitter .. the received IR hex codes ( bit, type NEC, etc ) are send to controller ( pimatic ) . Using pimatic Rules controlling electronic devices which sends IR hex code to node if rule is triggered.
            • D Dheeraj
              Moshe Livne
              @Dheeraj yes, I tried that as well with similar results. I even tried the more complicated irscrutinizer to no avail. I think I have zapped my IR reciever and waiting for replacement. It could record very long codes but I couldn't play them back. still working on it....
                Moshe Livne
                @Dheeraj Another option I am checking is getting one of the super cheap (3-4$) universal ac remote controls and hooking it to a sensor. The remotes were ordered and I'll probably get them in two weeks or so. It can be a good solution....
                B 1 Reply Last reply
                  B Offline
                  B Offline
                  blacey
                  Actually, that is a very creative approach. :+1: That said, I don't know if you guys saw it, but I posted a reply to your question about long IR codes on the forthcoming MySensors IR Blaster - http://forum.mysensors.org/topic/1402/ir-blaster-community-feedback-requested/63
                  Perhaps we can combine forces to ensure that the MySensors IR Blaster will meet your needs. Our goal is that it will be able to control devices that require recording and sending long IR codes and it looks like there is an Arduino solution - the IR Blaster Hardware will support it so it will just be a matter of adding it to the sketch/firmware.
                  • B blacey
                    Moshe Livne
                    @blacey Its not my idea - there are zillions of instructables and youtube videos of people who did it because of the problem of controlling AC is such a pain....
                    I will do my very best to make the IR blaster work with AC. Its a much neater solution. I must point out another PITA with controlling AC. as the wall units are stateless, the blaster can't actually know what is the actual setting on the AC. If someone manually changed the temperature or mode the blaster will override it, even if the programming only said "increase temp by 2 degrees for the night". Might be a need for another sensor by the AC that will also receive manual commands. this is so tricky....
                      B Offline
                      B Offline
                      blacey
                      @Moshe-Livne said:
                      @blacey I will do my very best to make the IR blaster work with AC. Its a much neater solution.
                      Excellent! :+1:
                      So, in other words, air conditioners don't support discrete IR codes? For example, instead of a single power-toggle code, there is a power-on code and a separate power-off code. Many televisions only have a single power-toggle button on the remote however the TV often supports discrete codes.
                      • R Offline
                        R Offline
                        rvendrame
                        Just to add my two cents, I also saw people using mechanical micro-servos to push the buttons at the AC unit, and light sensors (cheap LDR) to read the status LEDs.
                        http://www.ebay.com/itm/351185430530?rmvSB=true
                        Ugly but works.
                        ESP8266 GW + mySensors 2.3.2
                        Alexa / Google Home
                        • R rvendrame
                          Ugly but works.
                          Moshe Livne
                          @rvendrame I saw this as well - it is slightly insane IMHO. But opening and connecting to these 3$ remotes seems easy enough and its very cost effective. If you hide the whole thing in a nice oak box it even looks nice....
                          Anyway, learning from my last project, the infamous doorbell, that I thought would take 5 min max and it still manage not to work, lets just say I HOPE its easy....
                          • T Offline
                            T Offline
                            tbowmo
                            IR codes for AC's actually contains a lot of information, it's not just button presses (temperature up/down). But it's a "datagram" with complete settings, including temperature etc.
                            An example, my AC in the "mancave", if I block the IR signal and turn the heat up a couple of notches, and then unblock the IR again, then when I turn op the heat one notch more, the display on the AC unit jumps 3 notches up.. Which indicates to me, that it transmits a complete setup message, including temperatures, etc. to the AC unit.
                            • B blacey
                              Excellent! :+1:
                              Moshe Livne
                              @blacey its much much worse. Off is a discrete code. On on the other hand is a full device state. Mode, temp, fan, vane etc etc....
                                B Offline
                                B Offline
                                blacey
                                @Moshe-Livne and @tbowmo - good to know the difference from standard HT IR - clearly A/C control will be a steeper hill to climb but still should be doable. IR A/C units aren't popular where I live so I won't have access to one...
                                • T Offline
                                  T Offline
                                  tbowmo
                                  @blacey
                                  I have seen an arduino library somewhere to control different types of AC units, I even think it was mentioned on the forum,( half a year ago).
                                  • T tbowmo
                                    @blacey
                                    B Offline
                                    B Offline
                                    blacey
                                    wrote on last edited by blacey
                                    @tbowmo said:
                                    @blacey
                                    Indeed - this proves it is possible https://www.cooking-hacks.com/documentation/tutorials/control-hvac-infrared-devices-from-the-internet-with-ir-remote/ With a bit more legwork (e.g. https://github.com/r45635/HVAC-IR-Control), I am confident that IR Blaster will be able to support HVAC units. Heck (pun intended), it wouldn't be fun if there weren't any challenges ;)
                                    NOTE: Given that we plan to provide HVAC control in the IR Blaster, should we merge this discussion into the IR Blaster thread?
