  3. Help adding battery level to switch sketch
2 Posts 2 Posters 1.9k Views 1 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    I have a sketch witch is used to report when a button is switched:
    #include <MyTransportRFM69.h>
    #define SKETCH_NAME "BinSwSleepBat"
    #define SKETCH_VERSION "1-2"
    #define CHILD_ID 0
    MyTransportRFM69 transport;
    MySensor gw(transport);
    MySensor mys;
    MyMessage msg(CHILD_ID, V_TRIPPED); // Change to V_LIGHT if you use S_LIGHT in presentation below
    int sentValue=2;
      mys.begin();
      pinMode(BUTTON_PIN, INPUT);   // Setup the buttons
      digitalWrite(BUTTON_PIN, HIGH);   // Activate internal pull-ups
      mys.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
      mys.present(CHILD_ID, S_DOOR);
    void loop()  // Loop will iterate on changes on the BUTTON_PINs
      mys.sleep(50);  // Short delay to allow buttons to properly settle
      uint8_t val = digitalRead(BUTTON_PIN);
      if (val != sentValue) {  // If value has changed from last transmission, send the updated value
         mys.send(msg.set(val==HIGH ? 1 : 0));
         sentValue = val;
      mys.sleep(BUTTON_PIN-2, CHANGE, 0); // Sleep until something happens with the sensor
    I want to add the battery level sketch so that it sleep until button is switched as before but also reports battery-level every 120min
     * This is an example that demonstrates how to report the battery level for a sensor
     * Instructions for measuring battery capacity on A0 are available here:
     * http://www.mysensors.org/build/battery
    unsigned long SLEEP_TIME = 900000;  // sleep time between reads (seconds * 1000 milliseconds)
    int oldBatteryPcnt = 0;
       analogReference(INTERNAL1V1);
    #else
       analogReference(INTERNAL);
       gw.begin();
       gw.sendSketchInfo("Battery Meter", "1.0");
       // get the battery Voltage
       #ifdef DEBUG
       Serial.println(sensorValue);
       float batteryV  = sensorValue * 0.003363075;
       #ifdef DEBUG
       Serial.print(batteryV);
       Serial.println(" V");
       Serial.print(batteryPcnt);
       Serial.println(" %");
         // Power up radio after sleep
         oldBatteryPcnt = batteryPcnt;
       gw.sleep(SLEEP_TIME);
      Change to
      wakeUpReason = mys.sleep(BUTTON_PIN-2, CHANGE, SLEEP_TIME);
      See documentation on wakeUpReason if you only want to send battery value at wakeup.
