  3. Need Advice on Sizing a 5V DC Motor
3 Posts 2 Posters 1.7k Views 1 Watching
  • Z
    Z
    zebmina
    Hi Experts!
    Are there any tutorials on how to size a 5V DC motor; what I mean by that is I need to lift/lower a 5Kg weight. The speed is not that important, but the ability to lift a relatively heavy weight is.
    I assume I need high torque, but have not figured out whether a particular motor is capable of lifting that type of weight.
    Any advice/directions I can get are greatly appreciated.
      With some kind of pulley system you should get enough power to lift 5kg.
      Z 1 Reply Last reply
        Z
        Z
        zebmina
        @hek : Many thanks! I can do the math to do a pulley system, but that is dependent on the size of the motor, yes? What would you think the minimum size of motor I should start with? Do I need to go to a 24VDC motor, or can I do something with 5VDC motor?
        Regards..
