  3. OTA updates on Arduino Nano
23 Posts 5 Posters 13.4k Views 4 Watching
  • R
    R
    rvweert
    Hey there,
    I read that it is possible to update firmware OTA using MYSBootloader.
    Is this also possible with Arduino Nano (clone)? I cannot find anywhere how to burn this bootloader, if possible. If not, what is the best alternative?
    Thanks a lot!
    Rene
    • OitzuO
      OitzuO
      Oitzu
      It's possibly. If you aren't very experienced the easiest way is probably to use the MYSController. It ships AFAIK with a precompiled bootloader.
      • tbowmoT
        tbowmoT
        tbowmo
        @rvweert
        You need to reporgram the bootloader in your nano. To do this, you need a ISP programmer attached to the nano.
        Use either another arduino (clone) with ISP software loaded, to program the target, or buy an avr-dragon, etc. programming device
        • R
          R
          rvweert
          Hey thanks for the advice.
          I actually programmed the MYSbootloader with another Arduino (ISP). Now the programmed Arduino isn't responding anymore. It does work again if I restore the original bootloader. Should I perhaps change something in the fuse settings?
          Thanks.
          Rene
          • OitzuO
            OitzuO
            Oitzu
            Thanks.
            Rene
            The MYSbootloader doesn't support flashing over Serial! Connect a radio to the nano, make sure it works, and then flash. After the reset of the nano you should see firmware requests in myscontroller.
            • R
              R
              rvweert
              wrote on last edited by rvweert
              Hi and thanks again;-)
              Ok I've got the bootloader and sketch on the node. I also see it in my gateway using MYSController. However when I try to reboot it just starts sending a lot of messages but doesn't reboot. Neither do I seem able to update the firmware, any clue?
              I also added the line 'boolean process();' to the start of the loop.
              Rene
              tekkaT 1 Reply Last reply
              • OitzuO
                OitzuO
                Oitzu
                Rene
                Hi!
                I've seen this behavour before on a relay node.. could you reset the node and look what it sends right after the reset?
                  mvader
                  mine does this as well.
                  It seems like (to me anyways)
                  that when i had everything on 1.4 it worked well.
                  but once i moved all my stuff over to the 1.5 lib, this stuff didn't play nice anymore.
                  hoping that once @tekka releases the new app, it will solve some of those issues.
                  • R rvweert
                    Rene
                    tekkaT
                    tekkaT
                    tekka
                    Rene
                    This is strange but not related to MYSbootloader since no fw config requests are received. The node seems to re-initiate over and over, but not reboot. Can you please upload the log file obtaind from MYScontroller to get some additional info. Are all your nodes updated with the same lib version?
                    • M mvader
                      tekkaT
                      tekkaT
                      tekka
                      wrote on last edited by tekka
                      Didn't you mention in one of your posts that some nodes were having different lib versions?
                      M 1 Reply Last reply
                      • tekkaT tekka
                        mvader
                        wrote on last edited by mvader
                        I have everything on 1.5 stable now.
                        but i do notice that i have to constantly disconnect / connect in MYSController
                        I know that the controller and nodes still work, because lights (in my house) turn on and off. but no data is displayed in the controller screen.. i have to D/C
                        same with firmware update. they go so far and then stop.. i have to D/C
                        i have a nano with MYSBootloader acting as a 433 bridge and repeater, it does that (above screen shot) all the time. I'm using the 1.1 v of the bootloader.
                        it felt like things worked much better on 1.4 lib with the MYSController.
                        • M mvader
                          tekkaT
                          tekkaT
                          tekka
                          @mvader are you using serial or tcp/ip to connect the gw? can you post the myscontroller log (ideally with debug on) when those things happen?
                          • R
                            R
                            rvweert
                            Hi Tekka,
                            Please see here my log:
                            MySensors_20151109-085110.log
                            Also yes, all my nodes are running the same version from git.
                            Cheers,
                            Rene
                            • OitzuO
                              OitzuO
                              Oitzu
                              @rvweert: i see no bootloader involved. Could you try to add an wdt_reset(); at the beginning of the setup() routine?
                              • R
                                R
                                rvweert
                                Hi Oitzu,
                                Just tried that, same result...
                                • R
                                  R
                                  rvweert
                                  No more news on this?;-)
                                  • OitzuO
                                    OitzuO
                                    Oitzu
                                    @rvweert out of ideas by simply looking at the logs.
                                    Maybe @tekka knows anything.
                                    Did you try to enable debug on the node and look at the nodes output?
                                    • OitzuO Oitzu
                                      tekkaT
                                      tekkaT
                                      tekka
                                      @rvweert I'll look into that in a little bit.
                                      • R rvweert
                                        Hi Tekka,
                                        Cheers,
                                        Rene
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @rvweert there is potentially an id conflict: was the node previously used as gateway? Anyhow, try clearing the eeprom with the ClearEepromConfig sketch and upload the log again.
                                        • R
                                          R
                                          rvweert
                                          Hey Tekka,
                                          Tried clearing both eeproms, still same problem. Actually tried two completely new nano's and same problem again...
                                          tekkaT 2 Replies Last reply
