  3. wireless serial communication
4 Posts 3 Posters 2.4k Views 1 Watching
  • N
    N
    niccodemi
    Everytime I want to modify / update sketch I have to either remove arduino from it's location and bring it over to PC or use laptop (if location permits). Would it be possible to use this module for serial communication (monitoring and uploading sketches)? Or is there any other alternative?
      Over the air firmware updates perhaps?
      • siklosiS
        siklosiS
        siklosi
        Mysbootloader ota update works great. Also modules you showed have only rx and tx pins so there is no easy way to reboot arduino and start fw upgrade.
        N 1 Reply Last reply
        • siklosiS siklosi
          N
          N
          niccodemi
          @siklosi thanks, so that means this module would be only good for serial monitor? Is it possible to do serial monitoring with mysbootloader / myscontroller? I am currently using serial gw with vera - if I am to use myscontroller do I have to disconnect it from vera and connect it with computer running myscontroller?
