  3. LiPo Batteries
LiPo Batteries
4 Posts 1 Posters 2.7k Views 1 Watching
  • epierreE
    epierreE
    epierre
    I have just received 4000 mAh LiPo but they rate 0V and under LiPo from Adafruit (https://www.adafruit.com/products/390) they advertize as full (green light) but cannot hold the load charge.
    I'm trying to load it with a Li-Ion charger with a voltage control manually but I don't know if that will give anything for one loaded up to 3,980V has the same symptom as above...
    As a reference, I have a 2000mAh from Particle.Io that works well to load or support the load.
    any idea ?
    z-wave - Vera -> Domoticz
    • epierreE
      epierreE
      epierre
      @ceech the previous one I had were with your board, do you have some knowledge on this issue with batteries having pcm protection on ?
      • epierreE
        epierreE
        epierre
        still no luck even with a better one...
        • epierreE
          epierreE
          epierre
          found the issue, the polarity was wrong...
