  3. How to do resend when st=fail on a Repeater
5 Posts 3 Posters 2.3k Views 3 Watching
  • D
    D
    doblanch
    everything is in the title :-)
    I'm wondering how to increase reliability on bad RF transmission (big ceiling).
    I want to do a resend when st=fail.
    I do it already on my sensor, it's easy to code, as it's in the sketch directly.
    I'm wondering how to do it in the repetear ??? some ideas ???
    rvendrameR 1 Reply Last reply
    • D doblanch
      rvendrameR
      rvendrameR
      rvendrame
      @doblanch ,
      I see two ways of implementing it (despite I never tried):
      1. gw.send( msg ) returns false in case transmission fails.
      OR
      1. gw.send( msg, true ) will request an ack from controller, which should arrive back in few seconds if everything went well.
      In both cases, you have to write your own logic to retry.
      http://www.mysensors.org/download/sensor_api_15#the-full-api
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      D 1 Reply Last reply
      • rvendrameR rvendrame
        @doblanch ,
        OR
        D
        D
        doblanch
        @rvendrame Hello,
        yes, I use this already. But as you know in a repeater, the gw.send is not available as it's include in the process() function... I do nont have access to gw.send...
        • D doblanch
          @rvendrame Hello,
          rvendrameR
          rvendrameR
          rvendrame
          @doblanch , not sure if I understood. gw.process is used to listen to incoming radio messages, while gw.send is to transmit messages, and is present on every example sketch here. For example the 'Door/Window/Button' sensor:
            debouncer.update();
            // Get the update value
            int value = debouncer.read();
            if (value != oldValue) {
               // Send in the new value
               gw.send(msg.set(value==HIGH ? 1 : 0));
               oldValue = value;
          Alexa / Google Home
            http://forum.mysensors.org/topic/1424/resend-if-st-fail might be relevant
            http://forum.mysensors.org/topic/2189/serial-api-noack-when-sending-with-ack-failed started by @SiLeX has a longer discussion on resending
