  3. Sampling rate for sensor when combined
4 Posts 2 Posters 1.3k Views 2 Watching
    moskovskiy82
    I have combined Relay and MQ+DHT
    What i would like to do is set a sampling period for a sensor at say 5 seconds.
    Is this supposed to be done with millis? Can somebody help with the code sample?
    Let's presume for MQ as an exxample
    float mq_reading = analogRead(MQ_Pin);
      if (isnan(mq_reading))
          Serial.println("Failed mq_reading");
      else if (mq_reading != last_mq_reading)
        last_mq_reading = mq_reading;
        gw.send(msgMQ.set(mq_reading, 1));
        Serial.print("MQ: ");
        Serial.println(mq_reading);
    • sundberg84S
      Hi!
      Yes - im using millis() if i dont sleep the node (which seems overkill if you only wants 5 seconds).
      What you need to find out if you sensors have the possibility to read that fast. For the dht i think thats about when you just run the normal reading without delay in the loop.
        moskovskiy82
        Can you give a code example? Currently it reports every second almost
        • sundberg84S
          long previousMillis = 0;        // will store last time something happened
          long interval = 5000;           // interval at which to blink (milliseconds)
            if(currentMillis - previousMillis > interval) {
              // save the last time something happened
              previousMillis = currentMillis;
          Insert your code here...
          Note millis() does not work if you are using gw.sleep()
