  3. 💬 AC-DC double solid state relay module
hlk-pm01solid state relaylight switchlightacdc
226 Posts 67 Posters 165.4k Views 65 Watching
  • tonnerre33T
    tonnerre33T
    tonnerre33
    Yes, it's 5x5cm.
    For information, i can't place this pcb in my wall box.
    I'll search other wall box this week in order to find a greater box..
    If someone want just to test the PCB i can sell one PCB if you are in france ;)
    I have ordered 10 boards but i don't think use everything.
    Nca78N br0wnB 2 Replies Last reply
    • tonnerre33T tonnerre33
      Yes, it's 5x5cm.
      Nca78N
      Nca78N
      Same here if you are in Vietnam or asia, just pay postage and I can send you :p
      I have 20 as first order from Seeed took too long to arrive I thought it was lost, so I ordered again from PCBWay. Then received both orders.
      @tonnerre33 what is the space available in your wall box ? Would a 43*45mm pcb fit ? Only one relay/switch on my future board but phase + neutral in and phase + neutral out so no need to have additionnal connectors. No SMD, safe distance between tracks + milling. And 0.1'' tracks for load so it should be ok without reinforcing the tracks with solder.
      tonnerre33T 1 Reply Last reply
        Yes, it's 5x5cm.
        br0wnB
        br0wnB
        br0wn
        @tonnerre33 Thanks buddy,
        do you know if dirtypcb are still operational? because i've seen in their website that they want to migrate to another website "dangerousprototype"
        did anyone order from them lately?
        Nca78N 1 Reply Last reply
        • br0wnB br0wn
          Nca78N
          Nca78N
          @br0wn dev.dangerousprototypes.com is supposed to be a test site only, dirtypcb is still functional.
          br0wnB 1 Reply Last reply
          • Nca78N Nca78
            br0wnB
            br0wnB
            br0wn
            @Nca78
            Merci ^^
            • Nca78N Nca78
              tonnerre33T
              tonnerre33T
              tonnerre33
              wrote on last edited by tonnerre33
              #126
              @Nca78
              I have searched others wall box today but nothing fit (box from france).
              A 43x45mm pcb will fit well.
              I tried the pcb of the roller-shutter-node (45x46mm) and the wall box fits well.
              What do you mean by "no additionnal connectors" ? Will can use physical switches ?
              • mr_constM mr_const
                @Achim looks like a mistake in BOM (maybe that aliexpress listing has changed). Project uses same relay, but 5V version is needed.
                JonnyDev13J
                JonnyDev13J
                JonnyDev13
                Uggh, I just received 20 of the 12v ones yesterday that I purchased from the BOM link. Is it safe to say that these will absolutely not work, or is there some way to adapt them with a step-up converter or something?
                  @Nca78
                  Nca78N
                  Nca78N
                  @tonnerre33 said:
                  @Nca78
                  I mean that with my future PCB you have neutral and phase in, and neutral and phase out. No need to have an extra wire from "phase in" to go to the input of the relay + a connector to connect "neutral" in to "neutral out" (that is not available on the board). At the moment with the board I installed, I have to use a wago connector for neutral which takes some extra space.
                  • br0wnB
                    br0wnB
                    br0wn
                    @Nca78 , would this module work as a roller shutter if the motor is not drawing more than 2A (the maximum current that this SSR relay can withstand is 2A) ?
                    • tonnerre33T
                      tonnerre33T
                      tonnerre33
                      Nca78 has already answered :
                      @Nca78 said:
                      @tonnerre33 said:
                      can we install this module in a wall ?
                      Can we command shutters ?
                      For the wall, that's the idea of keeping the 50*50mm size :)
                      For the shutters technically yes, but there are (at least) 2 problems :
                      • if you have the 2 relays on at the same time = 2 directions you will probably kill the motor, there is no hardware protection on this board to avoid that (one of the relays must have power only when the other one is in off state). This can be done in software so it's not blocking.
                      • if you want to be able to control the level/percentage of closing, you need to measure time from min to max position, to do that you need to measure current (when motor stop consuming current it means shutter has reached it's 0% or 100% position). But there is no current sensor on this board, so you either need to implement a manual calibration process (that will lose precision over time) or use only manual control.
                      I am planning to test it when I have some time, and when I receive the PCB.
                      • Y_samY
                        Y_samY
                        Y_sam
                        Looking to do something similar, Thanks for the contribution.
                        However, I'd be very concerned about using an SSR (solid state relay) vs a mechanical relay. Even in the "OFF" position there is typically a small potential/current leakage through an SSR. When using SSR nearly all applications use a secondary mechanical disconnect to truely isolate the load, for service etc. Thoughts?
                        • Y_samY Y_sam
                          Nca78N
                          Nca78N
                          @Y_sam said:
                          ... to truely isolate the load, for service etc. Thoughts?
                          For that, disconnect the fuse in your fuse box, it's the only safe way.
                          • Y_samY Y_sam
                            br0wnB
                            br0wnB
                            br0wn
                            @Y_sam,
                            Nca78 highlighetd two problems:
                            • The absence of mecanical interlock between the "up" and "down" relays, (you can use a soft interlock to prevent them from beign activated at the same time)
                            • The absence of a current sensor to know whether or not the shutter is fully open or fully closed : I am trying to add an ACS712, but in my case, i will know if its fully open/close if the current becomes relatively high, because the my roller shutter doesnt have limit switches and keeps running ...
                            • JonnyDev13J JonnyDev13
                              Nca78N
                              Nca78N
                              You cannot adapt them with a step-up converter, there's no space on the PCB for that. But you should test them with 5V, if you are lucky they might work. I'm using 5V relays with 3.3V without any problem. The "must switch off" value in datasheet (for the original, remember what you bought is a clone...) is 0.9V which should be ok (real switch off value will probably be closer to this than to 5V) but the "must switch on" value is 8.4V which is quite far away from the 5V. The only way you will know if it will reliably switch one with 5V is to give it a try.
                              @okos said:
                              Hello.
                              I tried to upload my two boards ( arduino pro mini 8Mhz , 3,3 V ) modified sketches but returned to sketch Nca78 (with DS18B20), unfortunately, does not operate a physical switch. Sometimes phisical switch changes state in domoticz ( not every time ) but relays do not change state.
                              Switching on and switching off the lights of domoticz changes state relay without a problem.
                              What could be wrong ?
                              Sorry I'm a bit short on free time at the moment, didn't have time to take a look at the sketch yet.
                              What you are saying is sometimes you change the physical switch position, it changes the status in domoticz, but the light status is not matching the status of the physical switch and the value of the switch in Domoticz ?
                              For example: light is off and domoticz says off. Then you push the switch and domoticz says the light is on. But in fact the light is still off ?
                              JonnyDev13J 1 Reply Last reply
                              • laster13L
                                laster13L
                                laster13
                                @tonnerre33, je suis également en France et je n'ai pas de neutre dans mes interrupteurs. Peux tu me dire comment tu as pu tester le pcb stp. Mon anglais est loin d être top desolé !!
                                • Nca78N Nca78
                                  @okos said:
                                  Hello.
                                  JonnyDev13J
                                  JonnyDev13J
                                  JonnyDev13
                                  @Nca78 Thanks for your thoughts. I will try testing it with 5v and see what happens.
                                  • laster13L laster13
                                    tonnerre33T
                                    tonnerre33T
                                    tonnerre33
                                    #137
                                    @laster13 hi, i have tried this pcb with my bedroom lamp. Indeed, these lamps are powered by electrical socket which include neutral wire.
                                    For the others lamps, i need to find how to command them without neutral wire ;)
                                    I am looking at this project but this is an smd project :
                                    https://www.openhardware.io/view/249/MDMSNode-Lighting
                                    @laster13 salut, en fait mes lampes de chambres sont sur prises commandées (donc accès au neutre), du coup j'utilise ce module pour ces lampes mais pour les autres bin il va falloir que je trouve autre chose ;)
                                    Je regarde un peu du coté de ce projet mais c'est du cms : voir le lien au dessus
                                      wrote on last edited by hek
                                      #138
                                      @laster13
                                      English please...
                                      • laster13L
                                        laster13L
                                        laster13
                                        I Will tried to speak english 😗.
                                        Thanks tonnerre33 for your help. Could you give me à shema of your installation in the bedroom ?
                                          tonnerre33T
                                          tonnerre33T
                                          tonnerre33
                                          #140
                                          @laster13
                                          Here is a schema of my installation without the node :
                                          http://electric.system.free.fr/schemas/schemas/schema-prise-commandee.jpg
                                          and one with the pcb :
                                          http://www.photorapide.com/images.php?photoName=2whnu7.png&photoId=935027
                                          Edit : and the node with connectors :
                                          http://www.photorapide.com/images.php?photoName=074tl3.jpg&photoId=935034
