💬 AC-DC double solid state relay module
Hello.
I tried to upload my two boards ( arduino pro mini 8Mhz , 3,3 V ) modified sketches but returned to sketch Nca78 (with DS18B20), unfortunately, does not operate a physical switch. Sometimes phisical switch changes state in domoticz ( not every time ) but relays do not change state.
Switching on and switching off the lights of domoticz changes state relay without a problem.
What could be wrong ? -
@ludoarchi ![alt text]
That's where the biggest problem is on this board. I think the previous revision without the DS18 is safer, here there is less than 2mm creepage/clearance between main and low voltage traces and solder points, not enough :(
There's also problem of mixing both main/low voltage everywhere in the board like near the NRF24.
Hi
Noob questions sorry !
1/ Can i used it with 3way switches ?
2/ what are the pins 7 GND and 4 for ?
7 and 4 pins are mapped to 7 and 4 in/out of an arduino module. GND is for ground. These pins could be used to manually control relay state.
hi, great project. I have one idea, is it possible to add current and voltage measurement ?
Ordered all the components for this project but now i see there are 12 v solid state relays on the list?? mine is not working, does it not need to have 5V version??
one question to the SSR Relay. The Arduino works with 5V, the SSR in the BOM is a 12V type. Is this a mistake? According to the Datasheet of the relay, the 12V type has an operating range from 9,6v to 14,4V -
Hello all,
I have finished to assemble one of this board today.
You can see some pictures of my board here :
http://www.photorapide.com/albums/jordan/khreln/ac-dc-double-solid-state-relay-module.htmlIf you want more pictures, ask me ;)
The skecth works fine.
Thx for this project.
Hello all,
@tonnerre33
Avesome photogallery :smile:
whose sketch you used? because I have a problem with phisycal switches if I use sketch of Nca78 (I wrote about this earlier) -
I used the sketch of Nca78 (2 months ago) but i only command relays from jeedom.
I didn't test physical switch change because i don't have neutral wire in my switch box :( -
@tonnerre33
whose sketch you used? because I have a problem with phisycal switches if I use sketch of Nca78 (I wrote about this earlier)@okos said:
@tonnerre33
whose sketch you used? because I have a problem with phisycal switches if I use sketch of Nca78 (I wrote about this earlier)Sorry Okos I didn't notice the problem came from my sketch. I'm not using the physical switches at the moment (same reason than tonnerre33, no neutral wire where I have put it at the moment), but I will try to find some time next week to fix the sketch. I'll fix the temperature sending too as sometimes I have some tiny variations of temperature that generate a lot of message sending in a burst and it perturbates other sensors.
@tonnerre33
Just a quick question before i order the PCB, is it realy 4.6x5 cm? (thats what it says on the dirtypcb website, but when i mesure the PCB in the diptrace file, it shows a perfect 5x5 cm.
can you please explain? -
PCB is 5*5cm.
You will also have to include the antenna of the NRF24 that is outside the PCB area.
