  3. 3-in-1 Humidity Temp and Motion
motion3 in 1temphumidity
47 Posts 28 Posters 48.3k Views 22 Watching
  • B BulldogLowell
    @C4Vette you could just use a non-blocking method to read the temperature instead of the delay.
    The delay is method is in the library and used so that multiple reads to the sensor don't affect the reading (overheating the sensor).
    since SLEEP_TIME is 30s in the code above... I'd just read the temperature each time the sensor was awakened.
    you could just timestamp the last reading and check that at least the 2 seconds elapsed since the last reading before you take a new one (in the case that motion was detected.
    C Offline
    C Offline
    C4Vette
    @BulldogLowell
    Ok, thanks for explaining. I'm no programmer but trying to understand the code. So because there is also a sleep-periode, the earlier mentioned delay could be omitted? I do not fully understand how the motion interrupt is working but I replaced the 30 second sleep with a few lines using millis, as you implied so that the loop keeps on running to do other things.
    At the moment my sensor is a working combination of a LED-dimmer with a motion-sensor and now trying to add a DHT. This stuff is fun!
    Posted some photo's at http://forum.mysensors.org/topic/781/my-led-dimmer-motion-temp-hum-sensor
    • D Offline
      Dean
      Nice set up!
      • K Konrad Walsh
        I am wanted to share my 3-in-1 sensor in case its of use to anyone
        Its really just a combination of what's already available
        I used the following hardware:
        Arduino Nano LINK - Gave me both 3.3v and 5v output without having to mess with extra hardware(steppers)
        1 x Motion Sensor LINK
        1 x DHT22 LINK
        Connections is as all other guides except:
        Motion Sensor digital to Pin D3
        and the DHT to Pin D4
        Here is my code
        #include <DHT.h>
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        #define CHILD_ID_MOT 2   // Id of the sensor child
        #define HUMIDITY_SENSOR_DIGITAL_PIN 4
        DHT dht;
        float lastTemp;
        float lastHum;
        boolean metric = true;
        MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
          gw.begin();
          gw.sendSketchInfo("Humidity/Motion", "1.0");
          gw.present(CHILD_ID_MOT, S_MOTION);
          // Read digital motion value
          Serial.println(tripped);
          gw.send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
          if (isnan(temperature)) {
            lastTemp = temperature;
            if (!metric) {
            Serial.print("T: ");
            Serial.println(temperature);
          if (isnan(humidity)) {
              lastHum = humidity;
              Serial.print("H: ");
              Serial.println(humidity);
          gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
        If anyone wants more info please ask.. I will put up pictures or diagrams if needed
        M Offline
        M Offline
        mvader
        I'm having a problem with this build.
        i'm using the same hardware.
        I get nothing in the serial output screen.
        i am able to compile and load the code.
        when i measure on the 3.3 rail i get 3.8 (only when the radio is hooked up, i get 3.3 when nothing is hooked to the board)
        when i measure on the 5v rail, i get 4.7v when the motion and temp sensor are hooked up.
        I suspect my issues may be voltage related. although i'm not sure why i'm getting nothing on the serial monitor.
        since you said you didn't need any steppers, do you have any suggestions?
        thanks
        • K Konrad Walsh
          1 x DHT22 LINK
          Here is my code
          #include <DHT.h>
          DHT dht;
          float lastTemp;
          float lastHum;
            gw.begin();
              if (!metric) {
                lastHum = humidity;
          A Offline
          A Offline
          Anthony Straw
          @Konrad-Walsh my nano and pro mini on the way! double each! cant wait!! fed up all confused so have ard r3 n mega n nano n promini all tick tick!
          • D Offline
            djolafritte
            Works like a charm...
            Thanks for sharing :)
            • D Offline
              Dylano
              dear all.
              What battery u use?
              And what is the battery time?
              Domoticz, with a lot of working hardware, include mysensors :-)
              OpenPLI, RuneAudio, Solarmeter, etc......
              Not a great builder of software and hardware, more a user...
              Only i try to do my best :-(
              • V Offline
                V Offline
                viableoption
                Looks pretty sweet. How is it working comparing to existing products with the same features?
                • Łukasz KostrzewaŁ Offline
                  Łukasz Kostrzewa
                  Hi Konrad
                  Thx for great code. It works like charm but...
                  I have a question... It is possible to add to Your code one more (Door/Window) sensor?
                  Mayby You can post that code on this forum?
                  Best regards
                    Łukasz Kostrzewa
                    wrote on last edited by Łukasz Kostrzewa
                    #29
                    Hi to all
                    I changed a little Konrad sketch and add to 3in1 Humidity Temp and Motion one more sensor (Door\Window)
                    Here is my code:
                    #include <DHT.h>
                    #include <Bounce2.h>
                    #define CHILD_ID_DOOR 3
                    #define BUTTON_PIN_DOOR 2
                    Bounce debouncer = Bounce();
                    int oldValue=-1;
                    DHT dht;
                    float lastTemp;
                    float lastHum;
                    MyMessage msgDoor(CHILD_ID_DOOR,V_TRIPPED);
                    gw.begin();
                    pinMode(BUTTON_PIN_DOOR,INPUT);
                    digitalWrite(BUTTON_PIN_DOOR,HIGH);
                    debouncer.attach(BUTTON_PIN_DOOR);
                    debouncer.interval(5);
                    gw.sendSketchInfo("4in1", "1.0");
                    gw.present(CHILD_ID_DOOR, S_DOOR);
                    if (!metric) {
                    lastHum = humidity;
                    debouncer.update();
                    // Get the update value
                    int value = debouncer.read();
                    if (value != oldValue) {
                    // Send in the new value
                    gw.send(msgDoor.set(value==HIGH ? 1 : 0));
                    oldValue = value;
                    //gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
                    Now it is 4in1 :)
                      Łukasz Kostrzewa
                      This post is deleted!
                      • kurniawan77K Offline
                        kurniawan77
                        wrote on last edited by kurniawan77
                        #31
                        Has the 3in1 sketch been updated to 2.0 yet? I need some help with it, im not tot keen with coding...
                        R 1 Reply Last reply
                        • kurniawan77K kurniawan77
                          R Offline
                          R Offline
                          r-nox
                          @kurniawan77
                          This is HUM TEMP and PIR
                          This is what I'm using and it runs in mysensors 2.0
                          None battery powered. NO sleep mode and dirty code but it runs well enough for me right now.
                          If you add or fix anything please post it for everyone.
                          #include <DHT.h>
                          #define CHILD_ID_MOT 2 //me
                          #define DIGITAL_INPUT_SENSOR 2   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                          DHT dht;
                          float lastTemp;
                          float lastHum;
                          boolean metric = false;
                          unsigned long interval= 3000;//dht.getMinimumSamplingPeriod(); // the time we need to wait
                          unsigned long previousMillis=0; // millis() returns an unsigned long.
                          MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED); //me
                           // metric = getConfig().isMetric;
                            sendSketchInfo("3-1 Sensor", "1.0");
                            present(CHILD_ID_MOT, V_TRIPPED); //me
                          // only run loop if time has passed.
                          unsigned long currentMillis = millis(); // grab current time
                           // check if "interval" time has passed
                           if ((unsigned long)(currentMillis - previousMillis) >= interval) {
                                #ifdef MY_DEBUG
                                 Serial.print("Motion: ");
                            // Fetch temperatures from DHT sensor
                              if (!metric) {
                              #ifdef MY_DEBUG
                            // Fetch humidity from DHT sensor
                                lastHum = humidity;
                                #ifdef MY_DEBUG
                             // save the "current" time
                             previousMillis = millis();
                            //sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
                          • ikkeTI Offline
                            ikkeTI Offline
                            ikkeT
                            wrote on last edited by ikkeT
                            #33
                            My sample is here, unfortunately I didn't see this thread before starting it :)
                            It works for temp, humidity, door and motion, and interrupts for door and motion, otherwise sleeps the intervals:
                            https://github.com/ikke-t/sensebender
                            There is also pro-mini to code to monitor only door and motion.
                            This is also for 2.0 MySensors.
                            • McPostalM Offline
                              McPostalM Offline
                              McPostal
                              wrote on last edited by McPostal
                              #34
                              I combined Motion and Air Humidity and Sleep works. This is my first one and I'm pretty sure I have some unnecessary code in it.
                               * Motion: Version 1.0 - Henrik Ekblad
                               * Humidity: Version 1.0: Henrik EKblad
                               * Combination of Motion Sensor example and Air Humidity example
                               * http://www.mysensors.org/build/motion
                               * https://www.mysensors.org/build/humidity
                              // Enable debug prints
                              #include <DHT.h>
                              float lastTemp;
                              float lastHum;
                              uint8_t nNoUpdatesTemp;
                              uint8_t nNoUpdatesHum;
                              unsigned long SLEEP_TIME = 60000; // Sleep time between reports (in milliseconds)
                              #define MOTION_INPUT_SENSOR 3   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                              #define DHT_INPUT_SENSOR 4     // The digital input of attached DHT sensor
                              #define SENSOR_TEMP_OFFSET 0
                              #define CHILD_ID_HUMID 0        // ID of the Humidity child
                              #define CHILD_ID_TEMP 1         // ID of the Tempurature child
                              #define CHILD_ID_MOTION1 2   // Id of the Motion sensor child
                              // Initialize motion message
                              MyMessage msgMotion(CHILD_ID_MOTION1, V_TRIPPED);
                              MyMessage msgHum(CHILD_ID_HUMID, V_HUM);
                              DHT dht;
                                sendSketchInfo("Motion Temp Humidity", "1.0");
                                present(CHILD_ID_MOTION1, S_MOTION);
                                present(CHILD_ID_TEMP, V_TEMP);
                                present(CHILD_ID_HUMID, V_HUM);
                              	pinMode(MOTION_INPUT_SENSOR, INPUT);      // sets the motion sensor digital pin as input
                                dht.setup(DHT_INPUT_SENSOR); // set data pin of DHT sensor
                              	bool tripped = digitalRead(MOTION_INPUT_SENSOR) == HIGH;
                              	send(msgMotion.set(tripped?"1":"0"));  // Send tripped value to gw
                                #ifdef MY_DEBUG
                              // DHT ****************************************************************************
                                dht.readSensor(true);
                                  // Reset no updates counter
                                  nNoUpdatesTemp = 0;
                                  #ifdef MY_DEBUG
                                } else {
                                  nNoUpdatesTemp++;
                                  lastHum = humidity;
                                  nNoUpdatesHum = 0;
                                  #ifdef MY_DEBUG
                                } else {
                                  nNoUpdatesHum++;
                              	// Sleep until interrupt comes in on motion sensor. Send update after (SLEEP_TIME) milliseconds has passed.
                              	sleep(digitalPinToInterrupt(MOTION_INPUT_SENSOR), CHANGE, SLEEP_TIME);
                              • ? Offline
                                ? Offline
                                A Former User
                                I did some work today getting this temp / humidity / motion combo sensor running. The main issue I ran into was that though the temp and humidity did not report their values to the GW unless there was a change in values or the max no update trigger was reached, the motion sensor would report it's state value each cycle. @McPostal you also should be seeing this in your code. While this is not an issue if you are powering with a AC adaptor, I am planning on using batteries down the road for these sensors so I do not want it to broadcast unless required.
                                I added some code to resolve this. I am still testing this out but in theory this code should allows the Motion sensor to sleep and only report on a state change or when the max no update trigger is reached.
                                 * Version 1.0: Henrik EKblad
                                //#define MY_DEBUG_VERBOSE_RF24
                                //#define MY_RS485
                                #include <DHT.h>
                                #define DHT_DATA_PIN 4
                                #define MOTION_DATA_PIN 3
                                #define CHILD_ID_MOTION 2
                                float lastTemp;
                                float lastHum;
                                bool lastMotion = false;
                                uint8_t nNoUpdatesMotion;
                                bool metric = true;
                                MyMessage msgMotion(CHILD_ID_MOTION, V_TRIPPED);
                                DHT dht;
                                  sendSketchInfo("Temp Humidity Motion", "1.1");
                                  present(CHILD_ID_MOTION, S_MOTION);
                                  pinMode(MOTION_DATA_PIN, INPUT);
                                  sleep(5000);
                                  presentation();
                                  bool tripped = digitalRead(MOTION_DATA_PIN) == HIGH;
                                  if (tripped || nNoUpdatesMotion == FORCE_UPDATE_N_READS) {
                                    lastMotion = tripped;
                                    nNoUpdatesMotion = 0;
                                  else if (lastMotion) {
                                  else {
                                    nNoUpdatesMotion++;
                                    if (!metric) {
                                    nNoUpdatesTemp = 0;
                                    #ifdef MY_DEBUG
                                  } else {
                                    nNoUpdatesTemp++;
                                    lastHum = humidity;
                                    nNoUpdatesHum = 0;
                                    #ifdef MY_DEBUG
                                  } else {
                                    nNoUpdatesHum++;
                                  sleep(digitalPinToInterrupt(MOTION_DATA_PIN), CHANGE, UPDATE_INTERVAL);
                                Morkin.
                                • McPostalM Offline
                                  McPostalM Offline
                                  McPostal
                                  Nice! I realized the motion was being updated every cycle after I posted my code. I also left out references to metric temperature readings. I fixed the motion part in my code but didn't post it yet because I had already added a second motion sensor. What I did different was not forcing the motion update. I want the time stamp to reflect the last time someone was in the room.
                                  • stockenS Offline
                                    stockenS Offline
                                    stocken
                                    I took your updated code for 2.0 and tried to add a relay.
                                    The code looks like this:
                                    #include <DHT.h>
                                    #define CHILD_ID_HUM 10
                                    #define CHILD_ID_TEMP 11
                                    #define CHILD_ID_MOT 12 //motion sensor
                                    #define RELAY_1  7  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                                    #define CHILD_ID 5
                                    DHT dht;
                                    float lastTemp;
                                    float lastHum;
                                    void before()
                                    		pinMode(pin, OUTPUT);
                                      sendSketchInfo("4-1 Sensor", "1.0");
                                    	present(sensor, S_BINARY);
                                          #ifdef MY_DEBUG
                                        if (!metric) {
                                        #ifdef MY_DEBUG
                                          lastHum = humidity;
                                          #ifdef MY_DEBUG
                                    	if (message.type==V_STATUS) {
                                    		// Change relay state
                                    		// Store state in eeprom
                                    		// Write some debug info
                                    		Serial.print(message.sensor);
                                    However, when i look in domoticz the relay isnt presented as a child.
                                    Plus, the motion sensor is called "S_LIGHT_LEVEL" and not "S_MOTION" as it does in my other device (that only have temp, hum motion and not a relay in the sketch).
                                    temp/hum sensor and motion sensor works as intended in domoticz.
                                    My first though is that the motion and relay somehow is a bit mixed up by the sketch, but im kinda new to this so im not sure.
                                    Would really appreciate if someone can look at the sketch and see if there is any obvious problem :)
                                    McPostalM 1 Reply Last reply
                                    • stockenS stocken
                                      #include <DHT.h>
                                      #define CHILD_ID 5
                                      DHT dht;
                                      float lastTemp;
                                      float lastHum;
                                      void before()
                                            #ifdef MY_DEBUG
                                          if (!metric) {
                                          #ifdef MY_DEBUG
                                            lastHum = humidity;
                                            #ifdef MY_DEBUG
                                      McPostalM Offline
                                      McPostalM Offline
                                      McPostal
                                      #38
                                      @stocken
                                      Under "void presentation()" , present(CHILD_ID_MOT, V_TRIPPED); //me should be
                                      present(CHILD_ID_MOT, S_MOTION); //me
                                      that should fix the light level problem.
                                      I haven't done a relay yet. If no one else responds I look at it later tonight. I also have a relay but haven't had time to try and implement it yet.
                                      • K Offline
                                        K Offline
                                        Komaandy
                                        wrote on last edited by Komaandy
                                        #39
                                        Hello everybody,
                                        first off all a big thank you for creating this awsome sketch. It works perfect for me !!
                                        But, as you might already have guessed I have a little problem.
                                        I built 2 exact same nodes and flashed the exact same sketch ( only thing I changed is the child ID´s) but one node works just like a charm ( MSPIRAndy) but the other one (MYSENSOR_106) doesnt transmit its readings (?)
                                        Via the serial monitor the readings do exist and work perfect.
                                        Thanks a lot, all help is appreciated
                                        KOmaandy
                                          Have you tried swapping radio between the 2 sensors? Just to exclude any radio issue
