  3. My best nRF24L01+PA+LNa node (gateway/ repeater) so far
14 Posts 7 Posters 10.3k Views 10 Watching
  • AWIA
    AWIA
    AWI
    wrote on last edited by AWI
    After spending (a lot of) time in finding ways to extend the range of nodes I (by accident ;-) ) ordered a cheap metal enclosure. Pictures speak for themselves....
    0_1465744032042_upload-aa38d27e-b299-4a79-82a3-4868797230ac
    Finally found a drill for perfect (large) round holes (after 30 years of "square" ones)
    0_1465744105582_upload-6977f6f5-b62a-4a28-bc26-8033dccc3ed2
    just before assembly (hard to beat duct tape)
    0_1465744196914_upload-c6da29ce-fd74-4517-8be0-b3c1b9bd83ea
    and the final result. This is only a repeater node.. can't find a spot in the street without reception.
    0_1465744544197_upload-6862ec67-c5f3-420b-bb24-da8eeec783fb
    0_1465744322334_upload-126a9cda-3f83-4514-8c6e-40110fc7cf27
    F 1 Reply Last reply
    • AWIA AWI
      F
      F
      flopp
      @AWI
      Nice product.
      • OitzuO
        OitzuO
        Oitzu
        @AWI nice finnish :+1:
        I wonder if the nrf24 shielding is still necessary in a metal enclosure.
        AWIA 1 Reply Last reply
        • alexsh1A
          alexsh1A
          alexsh1
          Very neat case in the photo!
          After accidentally burning the Nano in a metal enclosure due to several pins shorted, this is a no go for me personally. Obviously, enclosure can be isolated inside. Meantime, I'll stick to 3D printed ones.
          • OitzuO Oitzu
            AWIA
            AWIA
            AWI
            @Oitzu the shielding in the case is not needed but I already wrapped this one. It needs electric isolation though :wink:
            • alexsh1A alexsh1
              AWIA
              AWIA
              AWI
              @alexsh1 The whole purpose of this case was shielding... but I agree it has the looks :eyes:
              • D
                D
                drock1985
                Nice case @AWI
                Any tips for getting a repeater working? Tried the example sketch from 1.5.4 but the repeater seems to freeze when trying to boot. Using a nano with normal NRF radio.
                My Projects
                2 Door Chime Sensor
                Washing Machine Monitor
                • sundberg84S
                  I just want to add how important i just experienced this is! I upgrade my GW and 2 repeaters to 2.0 and added a metalic case. Nothing more. The reception has improved VERY MUCH! In one repeater, I just coated a plastic case on the inside with aluminium foil - works great. All my garden nodes (which maybe had uptime of 90-95% before and went red in Domoticz from time to time is 100% upp since this.
                  So we should not underestimate this - the radio makes alot of noice which interfere with tha radiowaves.
                  Thank you @AWI for this.
                  • F
                    F
                    flopp
                    wrote on last edited by flopp
                    Today I took time to check why my node didn't work for more than 1 hour.
                    If I have the antenna like this it doesn't work
                    If I have it like this it works
                    • F flopp
                      @flopp yep, I also get better reception pointing it vertical. I have one repeater under a bed and the antenna was pushed to a horizontal position and it was almost useless.
                      • Boots33B
                        Boots33B
                        Boots33
                        Not a radio expert but i think all your antennas should be on the same plane to work properly. So if your gateway antenna is vertical then you should try and setup your nodes the same way.
                        • F
                          F
                          flopp
                          I had I running for 4 days now with serial monitor I had 9 failures during this time.
                          One sensor sending data every 30 minutes and 2 other sensors sending every 2 hour.
                          • F
                            F
                            flopp
                            above was not the solution, after a few days it stopped working again and since then I have been trying to get it to work.
                            I change the direction for the antennas and it worked a few days, I change the location for my controller, wrapped the PCB with metal folie, I bought a nRF with metal case, nothing helped until I change the repeaters nRF, now it has been working for 96 hours without problem :smile:
                            So my suggestion to you is, buy at least 2-3 nRF from different sellers, to avoid problem with batches. If you buy 3 nRF at the same time from same seller, maybe that batch is a bad one.
                            • F
                              F
                              flopp
                              Now it is working extremely much better, I have 8 days in a row without any errors.
                              I think this is how it should be.
