  3. 💬 In Wall AC/DC Pcb (with Relay) for MySensors (SMD)
switchin-wallrelayacdchlk-pm01
89 Posts 27 Posters 34.7k Views 29 Watching
  • ragflyerR ragflyer
    Cool design! Could you post the dimensions including box and relay?
    I understand one can update firmware through the MYSX connector?
    #21
    @ragflyer - Thank you!
    I suggest using the ISCP to update firmware. There isnt any DTR (to reset) on the MysX (this design - its coming next revision).
    The box is 56mm wide and 43mm deep and the height is 24.6mm
    Uncluding the SSR relay sticking out its 29mm height.
    • fra290F
      fra290F
      fra290
      Hi sundberg84,
      what's the status of this great project? can I produce the PCB? I want use this for sopstitute my current X10 plant based on around 20 micro module.
      only one question, I need to control light also by a traditional switch (momentary button) where a can connect the normal switch, A1 or A2 to GND is OK? in my case can be lot of distance from the node to switch, in some case more them 4 meters and the wire for control switch run in a same pipe to grid linee, can this plant create interference? what do you think to insert one optical cupolaed?
      Thanks..
      MArco
      • fra290F fra290
        Hi sundberg84,
        Thanks..
        MArco
        @fra290 - Hi!
        Status is that I have just received the updated new PCB and are planning to test them... but havent had the time.
        I have updated openhardware.io with 7.1 which is the latest and the one im testing.
        You can download the gerber or eagles files and manufacture.
        I have also made a request for the pcbhouses to add 7.1 so you can buy them from openhardware.io
        Its small revisions and I dont think there should be any major issues with 7.1
        • proddyP
          proddyP
          proddy
          @sundberg84 Thanks for sharing this. I'm gathering the components and plan to build it soon when the PCB v7.1 is available.
          I do have a few questions if I may
          • with the Relay, is it important to have one that has zero crossover? E.g the difference between getting the G3MC-202PL over a G3MC-202P
          • what were you planning to use the 16Mhz oscillator for eventually?
          • do you see any issues if I build the first prototype using an ESP-12 (ESP8266 with onboard Serial WiFi running at 3.3v)?
          • proddyP proddy
            @Paul-Derbyshire
            1. It must depend on what you are planning to connect to the relay
            2. The oscillator is for the MCU - you can program a bootloader without it and use the internal.
            3. No issue - please do! Im glad i can make stuff that gets the community forward. Best of luck!
            proddyP 1 Reply Last reply
            • sundberg84S sundberg84
              @Paul-Derbyshire
              proddyP
              proddyP
              proddy
              It would use it to switch on and off an external mounted lamp - so with a fixed Watt & Voltage. Probably an LED 220V Lamp. Should I avoid zero-crossover as I've read somewhere that zero-crossover can cause a surge current of perhaps 10 to 40 times the steady state current when switched on.
              • proddyP proddy
                @Paul-Derbyshire - sorry, to be hones i missunderstood you.
                Most SSR sold for arduino are P and not PL it seems.
                "The light from the diode is beamed into a light-sensitive semiconductor that, in the case of zero-voltage crossover relays, conditions the control circuit to turn on the output solid-state switch at the next zero-voltage crossover. In the case of nonzero-voltage crossover relays, the output solid-state switch is turned on at the precise voltage occurring at the time."
                • Jose SimoesJ
                  Jose SimoesJ
                  Jose Simoes
                  hi, just an idea, do you think it is possible to add a current sensor to the PCB in order to add a power meter function to the node to monitor power consumption? say up to 20A
                  • Jose SimoesJ Jose Simoes
                    @Jose-Simoes - no clue about current sensors... sorry I just cant answer that at the moment.
                    Jose SimoesJ 1 Reply Last reply
                    • Jose SimoesJ
                      Jose SimoesJ
                      Jose Simoes
                      This post is deleted!
                        Jose SimoesJ
                        Jose SimoesJ
                        Jose Simoes
                        @sundberg84 -hey, i was meaning something like the ACS712 Module, but add the ic to the PCB for better integration.
                          @Jose-Simoes said in 💬 In Wall AC/DC Pcb (with Relay) for MySensors (SMD):
                          ACS712
                          Well, to safe space and meet my goal to be able to have it so small so it fits inside a wallsocket i have excluded all sensors and included the MysX connector. This way every user can add their own sensor.
                          • J
                            J
                            Justas
                            Hi, @sundberg84
                            I'm really interested in this module. Maybe stupid question, but I'm very new with openhardware and would like to understand: if I will go and buy through the link provided (10xPCB for 15$), will I receive already assembled unit with all the parts, or I have to go and buy parts and assemble it myself?
                            Thanks & Regards
                            tonnerre33T gohanG 2 Replies Last reply
                            • J Justas
                              Hi, @sundberg84
                              Thanks & Regards
                              tonnerre33T
                              tonnerre33T
                              tonnerre33
                              wrote on last edited by tonnerre33
                              #34
                              @Justas Hello,
                              yes you have to buy parts and assemble them yourself. 1.5$ by PCB is cheap, you can't have the components for this price ;)
                              • J Justas
                                Hi, @sundberg84
                                Thanks & Regards
                                @Justas
                                you get the PCB only, then you have to buy all the components and solder them on the pcb :)
                                If you aren't a lot familiar with soldering you could also evaluate Sonoff wifi relays ;)
                                • J
                                  J
                                  Justas
                                  Thanks, I also checked the parts list and found that total price is more than $14, so now I see how stupid my questions was ;)
                                  • proddyP
                                    proddyP
                                    proddy
                                    and building it is 99% of the fun !
                                    • H
                                      H
                                      hugch
                                      wrote on last edited by hugch
                                      #38
                                      Very nice project. And it is so nice that you thought about the fuses for the power supply and the relais. :-)
                                      I have two additional ideas:
                                      • adding the ATSHA204 fo secure signing
                                      • I could be to big to integrate but something like this (https://www.aliexpress.com/item/1Bit-AC-220V-Optocoupler-Isolation-Module-Testing-Board-Adaptive-for-PLC/32754734564.html) would be great to detect the in wall switch state.
                                      • E
                                        E
                                        exilit
                                        Great project, thank you for sharing. Searching for a power supply i found your project which seems to fit my needs pretty well. What do you think are the main differences to the AC/DC/Double SSD Relay by Aproxx (https://www.mysensors.org/hardware/ac-dc-ssd-relay). I am mainly interested in the AC/DC conversion part.Would like to hear your opinion on that.
                                        • E exilit
                                          @exilit - sorry my friend, I have not studied the AC/DC/Double SSD Relay by Aproxx very closely.
                                          Mine is a bit smaller instead of 50x50 but he got 2 relays.
