  3. Domoticz
  4. Problem sending the RGB state, brightness and color to Domoticz
3 Posts 2 Posters 1.6k Views 3 Watching
  • T Offline
    T Offline
    TheoL
    wrote on last edited by TheoL
    So I've created an RGB node using some neopixels. Domoticz sees this node and I'm able to control the node. But when I report the node's state to Domoticz, Domoticz doesn't do anything with the message.
    Here's the code I use. I've found a full sketch on the Domoticz forum, but had to adjust it, because Fastled.h apparently can't run on a pro mini 3.3V.
    void SendLastColorStatus() {
      char buf[20];
      uint32_t val;
      sprintf(buf, "%02X%02X%02X", (uint8_t)red, (uint8_t)green, (uint8_t)blue );
      String cStatus=buf+String("&")+String(actRGBbrightness)+String("&")+String(actRGBonoff);
      gw.send(lastColorStatusMsg.set( cStatus.c_str() ) );
    I've added a moodlight mode child to this node, so when ever I turn on the moodlight, I'd be expecting the above code to turn off the rgb light in Domoticz. But hmmm it doesn't.
    All help is welcome. Maybe @AWI can point me in the right direction, since he created the original sketch.
    A 1 Reply Last reply
    • T TheoL
        char buf[20];
        uint32_t val;
      A Offline
      A Offline
      AWI
      wrote on last edited by AWI
      @TheoL I have to get the latest status but I am pretty sure that domoticz does not handle RGB input. Off topic: also try to avoid the String class in Arduino c++ but use char array instead. The String class creates a lot of overhead and is not well suites for real time purposes (hear say..:blush: )
      T 1 Reply Last reply
      • A AWI
        T Offline
        T Offline
        TheoL
        @AWI Thanx for your quick reply. I already had a gut feeling that Domoticz doesn''t handle it. nd you're right the String in Arduino C++ isn't the best option. But since Domoticz ignores it I can leave it out anyway.
        12.2k
