  3. Vera
  4. Arduino Uno R3 Ethernet Gateway + 4 Relay + Motion + Magnetic Switch
10 Posts 3 Posters 4.5k Views 5 Watching
    mlg
    Hello ,
    I'm trying to build the gateway with all attached sensors
    But when I inclusion, only appears the 4 relays in Vera , what is wrong with the code?
    not appear --> motion and Magnetic Switch
    Setup:
    Arduino Uno R3
    W5100 Shield
    4 Relay - pin 5,6,7,8
    1 motion - pin 3
    1 magnetic switch - pin 4
    #define MY_GATEWAY_W5100
    #define MY_IP_ADDRESS 192,168,1,169   // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5003
    // Enable inclusion mode
    // #define MY_INCLUSION_BUTTON_FEATURE
    // #define MY_INCLUSION_MODE_BUTTON_PIN  4
    #include <Ethernet.h>
    #include <Bounce2.h>
    #define RELAY_1  5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define NUMBER_OF_RELAYS 4 // Total number of attached relays
    #define CHILD_ID 3   // Id of the sensor child
    #define ID 4
    #define OPEN 1
    #define CLOSE 0
    #define BUTTON_PIN  4  // Arduino Digital I/O pin for button/reed switc
    boolean lastTripped = 0;
    Bounce debouncer = Bounce();
    int oldValue=-1;
    // Initialize motion message
    MyMessage msgdoor(ID,V_TRIPPED);
    void before() {
        pinMode(pin, OUTPUT);
      pinMode(BUTTON_PIN,INPUT_PULLUP);
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      present(ID, S_LIGHT); // S_DOOR
        present(sensor, S_LIGHT);
      present(CHILD_ID, S_MOTION);
        // Read digital motion value
        if (lastTripped != tripped ) {
          send(msg.set(tripped?"1":"0")); // Send new state and request ack back
          Serial.println(tripped);
          lastTripped=tripped;
    debouncer.update();
      int value = debouncer.read();
      if (value != oldValue) {
         Serial.print("Door value: ");
         Serial.println(value);
         send(msgdoor.set(value==HIGH ? 1 : 0));
         oldValue = value;
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
      Your child ids are overlapping.
        mlg
        wrote on last edited by mlg
        @hek tks, motion sensor now appear but magnetic switch no :( need resistor ?
        Update code
        #define CHILD_ID 69   // Id of the sensor child
        #define ID 70
        #define OPEN 1
        #define CLOSE 0
        int oldValue=-1;
        void before() {
          present(ID, S_DOOR); // S_DOOR
        debouncer.update();
             oldValue = value;
          mlg
          Any ideia plz?
            If the presentation fails to be received by the controller, you could introduce a small delay (to let radio "re-change") between the transmits to the controller.
            wait(200); at the top of the loop should be enough.
            M 1 Reply Last reply
              mlg
              @hek
              Still not working :\
                 wait(200);
              debouncer.update();
                   oldValue = value;
                When doing the presentation...
                  mlg
                  @hek
                  Working!!!! Tks
                  I only have one more problem, with simple button switch ( like that ) simulate door open/close , I receive message "Door value:0 and 1" and status in vera changed, but with reed switch ( like that ) door status no change with magnetic , I bought 5 reed switch and any works :(
                  Reed switch problem right ?
                  AWIA 1 Reply Last reply
                  • M mlg
                    @hek
                    Working!!!! Tks
                    AWIA
                    AWIA
                    AWI
                    @mlg Probably the reed switch. It is just a mechanical device. You can try with an ohm meter (or with battery and light/ led)
                      mlg
                      Update
                      Finally after changing reed switch all works !
                      However , sometimes mysensors gateway stop responding (few weeks works fine), I try to ping Ip of the gateway and no have any reply, solution is power off gateway .
                      It is possible to place the gateway (mysensors) to ping a network address and if it does not answer automatically make a restart and wait/limit to a restart every 20 minutes? (to prevent the restart loop)
