  3. New in Mysensors
New in Mysensors
7 Posts 3 Posters 2.0k Views 2 Watching
  • edybahiaE
    edybahiaE
    edybahia
    wrote on last edited by edybahia
    Hi guys , I'm new in the world of mysensores . And I'm sure of that really need to promote communication between the following hardware.
    sensors .:
    Arduino , NRF24L01 + and I am using the logical name of IDE : linght sensor.
    gateway .:
    Arduino , NRF24L01 + with serial interface.
    Running serial Gateway code.
    My doubt and if I need to add anything else to work as descriptions
    • sundberg84S
      @edybahia - welcome!
      You also need some sort of controller to handle the data.
      • edybahiaE
        edybahiaE
        edybahia
        OK thanks.
        But I can use the Arduino as this driver? For example when I am with the data with a serial gateway, I can see the value that comes from sensors linght module.
        I have experience in using the mesh with the TMRH20 library (RF24). And in it there is a specific controller.
        My big question of mysensor and creating (Sensor + gateway + controller). Would have some tutorial to be followed?
        • edybahiaE edybahia
          OK thanks.
          @edybahia do you mean something like the getting started pages?
          • edybahiaE
            edybahiaE
            edybahia
            No, already researched enough on this page
            I believe that now I understood the concept.
            It is then necessary to have a hardware sensor data (Arduino nRF24L01 + + ldr). This hardware will send to the gateway (Arduino + nRF24L01 +).
            For the user to view the measurement it must have a "controller" installed on your computer or on a Socs (Raspberry).
            Am I correct in my understanding?.
              @edybahia - yes, you are correct. You need 1 controller with 1 gateway connected. And then as many sensors as you want. Have fun!
              • edybahiaE
                edybahiaE
                edybahia
                yes, trank you.
                I now know
