  3. MyHwESP8266.cpp:21:20: fatal error: EEPROM.h: No such file or directory #include <EEPROM.h>
3 Posts 2 Posters 2.2k Views 2 Watching
  • DinnocD
    DinnocD
    Dinnoc
    I am trying to compile the MockMySensors on arduino 1.6.4 for ESP8266
    I keep getting the error below.
    Strangely when i compile the GatewayESP8266 module which has an #include <EEPROM.h>, it compiles and runs just fine.
    Can anyone help???
    Verbose errors
    Arduino: 1.6.4 (Windows 8), Board: "Generic ESP8266 Module, 80 MHz, 40MHz, DIO, 115200, 512K (64K SPIFFS), ck, Disabled, None"
    Build options changed, rebuilding all
    Using library SPI in folder: C:\Users\dinnissj\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI
    Using library MySensors in folder: C:\Users\dinnissj\Documents\Arduino\libraries\MySensors
    C:\Users\dinnissj\AppData\Roaming\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -IC:\Users\dinnissj\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include -IC:\Users\dinnissj\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include -IC:\Users\dinnissj\AppData\Local\Temp\build6451806607044567628.tmp/core -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10604 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP01" -DESP8266 -IC:\Users\dinnissj\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266 -IC:\Users\dinnissj\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\generic -IC:\Users\dinnissj\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI -IC:\Users\dinnissj\Documents\Arduino\libraries\MySensors C:\Users\dinnissj\AppData\Local\Temp\build6451806607044567628.tmp\MockMySensors.cpp -o C:\Users\dinnissj\AppData\Local\Temp\build6451806607044567628.tmp\MockMySensors.cpp.o
    In file included from C:\Users\dinnissj\Documents\Arduino\libraries\MySensors/MySensors.h:67:0,
    from MockMySensors.ino:19:
    C:\Users\dinnissj\Documents\Arduino\libraries\MySensors/core/MyHwESP8266.cpp:21:20: fatal error: EEPROM.h: No such file or directory
    #include <EEPROM.h>
    compilation terminated.
    Error compiling.
      You should be able to remove that include.
      https://github.com/mysensors/MySensors/pull/555
      • DinnocD
        DinnocD
        Dinnoc
        i actually just reinstalled arduino from version 1.6.4 to current version 1.6.9 i think and it seemed to fix the issue.
        I do still have an error with the mymocksensors example sketch though that it doesnt compile with a series of 'function xx is ambiguous' looks like a duplicate reference somewhere. Ill generate the error and post the information
        Cheers
        James
