  3. [SOLVED] Timers and Interrupts not being triggered
19 Posts 4 Posters 7.3k Views 4 Watching
    Mike Cayouette
    I'm making an AC (mains) dimmer using a circuit from this website https://arduinodiy.wordpress.com/2012/10/19/dimmer-arduino/. I basically uses interrupts to detect when the sine wave crosses zero and then triggers a triac. To achieve this I'm using this sketch:
    /*AC Light Control
     Updated by Robert Twomey
     Changed zero-crossing detection to look for RISING edge rather
     than falling.  (originally it was only chopping the negative half
     of the AC wave form).
     Also changed the dim_check() to turn on the Triac, leaving it on
     until the zero_cross_detect() turn's it off.
     Adapted from sketch by Ryan McLaughlin
     http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1230333861/30
    #include  <TimerOne.h>          // Avaiable from http://www.arduino.cc/playground/Code/Timer1
    volatile int i=0;               // Variable to use as a counter volatile as it is in an interrupt
    volatile boolean zero_cross=0;  // Boolean to store a "switch" to tell us if we have crossed zero
    int AC_pin = 11;                // Output to Opto Triac
    int dim = 0;                    // Dimming level (0-128)  0 = on, 128 = 0ff
    int inc=1;                      // counting up or down, 1=up, -1=down
    int freqStep = 75;    // This is the delay-per-brightness step in microseconds.
                          // For 60 Hz it should be 65
    // It is calculated based on the frequency of your voltage supply (50Hz or 60Hz)
    // and the number of brightness steps you want.
    // Realize that there are 2 zerocrossing per cycle. This means
    // zero crossing happens at 120Hz for a 60Hz supply or 100Hz for a 50Hz supply.
    // To calculate freqStep divide the length of one full half-wave of the power
    // cycle (in microseconds) by the number of brightness steps.
    // (120 Hz=8333uS) / 128 brightness steps = 65 uS / brightness step
    // (100Hz=10000uS) / 128 steps = 75uS/step
    void setup() {                                      // Begin setup
      pinMode(AC_pin, OUTPUT);                          // Set the Triac pin as output
      attachInterrupt(0, zero_cross_detect, RISING);    // Attach an Interupt to Pin 2 (interupt 0) for Zero Cross Detection
      Timer1.initialize(freqStep);                      // Initialize TimerOne library for the freq we need
      Timer1.attachInterrupt(dim_check, freqStep);
      // Use the TimerOne Library to attach an interrupt
      // to the function we use to check to see if it is
      // the right time to fire the triac.  This function
      // will now run every freqStep in microseconds.
    void zero_cross_detect() {
      zero_cross = true;               // set the boolean to true to tell our dimming function that a zero cross has occured
      i=0;
      digitalWrite(AC_pin, LOW);       // turn off TRIAC (and AC)
    // Turn on the TRIAC at the appropriate time
    void dim_check() {
      if(zero_cross == true) {
        if(i>=dim) {
          digitalWrite(AC_pin, HIGH); // turn on light
          i=0;  // reset time step counter
          zero_cross = false; //reset zero cross detection
        else {
          i++; // increment time step counter
      dim+=inc;
      if((dim>=128) || (dim<=0))
        inc*=-1;
      delay(18);
    The circuit and the sketch works fine until I introduce the mysensors library and a radio. When I do that the interrupt never detects the zero crossing and therefore the triac never triggers. I have not changed anything in my sketch except to include the mysensors library. My modified sketch looks like this:
    /*AC Light Control
    #define MY_NODE_ID 300
    #define SN "ACDimmer"
    #define SV "1.0"
    #define AC1_ID 1
    int AC_pin = 4;                // Output to Opto Triac
    int freqStep = 65;    // This is the delay-per-brightness step in microseconds.
    MyMessage dimmerMsg(AC1_ID, V_DIMMER);
      attachInterrupt(1, zero_cross_detect, RISING);    // Attach an Interupt to Pin 2 (interupt 0) for Zero Cross Detection
    void presentation() {
      present( AC1_ID, S_DIMMER );
      sendSketchInfo(SN, SV);
      i=0;
    void dim_check() {
        if(i>=dim) {
        else {
      dim+=inc;
        inc*=-1;
      delay(18);
    My node registers with my gateway and all seems fine. Is the mysensors library using the same timer?
    Any help would be appreciated.
    Thank you,
    Mike
    YveauxY 1 Reply Last reply
    • M Mike Cayouette
      /*AC Light Control
        i=0;
      void dim_check() {
          if(i>=dim) {
          else {
        dim+=inc;
          inc*=-1;
        delay(18);
      /*AC Light Control
      #define SV "1.0"
      #define AC1_ID 1
        i=0;
      void dim_check() {
          if(i>=dim) {
          else {
        dim+=inc;
          inc*=-1;
        delay(18);
      Thank you,
      Mike
      YveauxY
      YveauxY
      @Mike-Cayouette you changed the interrupt number to attach to from 0 to 1, which is probably causing the issue.
      Hardcoding the number is bad coding practice; see https://www.arduino.cc/en/Reference/AttachInterrupt
      Use the digitalPinToInterrupt() function instead to convert pin number to interrupt number.
        Mike Cayouette
        @Yveaux Sorry for the confusion. In my testing I did in fact change the original sketch to use interrupt 1 as I have in my modified sketch and it worked. I did this knowing the radio was going to be connected to 0. I understand your comment about hard coding the interrupt and agree it is not best practice, however, that does not take away from the fact that the sketch did not work when I added the mysensors library in my changes. I believe, even with it hard coded, it should have worked or am I missing something?
        Thank you,
        Mike
          Mike Cayouette
          wrote on last edited by Mike Cayouette
          Just to be clear, below is the exact sketch that I used, i added the digitalPinToInterrupt() to the sketch.
          /*AC Light Control
          int interruptPin = 3;
            attachInterrupt(digitalPinToInterrupt(interruptPin), zero_cross_detect, RISING);    // Attach an Interupt to Pin 2 (interupt 0) for Zero Cross Detection
            i=0;
          void dim_check() {
              if(i>=dim) {
              else {
            dim+=inc;
              inc*=-1;
            delay(18);
          The above sketch works as intended. When I add the mysensors library to the sketch, as I did below, the triac never gets triggered.
          /*AC Light Control
          #define SV "1.0"
          #define AC1_ID 1
            i=0;
          void dim_check() {
              if(i>=dim) {
              else {
            dim+=inc;
              inc*=-1;
            delay(18);
          What would be preventing the interrupt from triggering?
          Thank you,
          Mike
          • M Mike Cayouette
            /*AC Light Control
              i=0;
            void dim_check() {
                if(i>=dim) {
                else {
              dim+=inc;
                inc*=-1;
              delay(18);
            /*AC Light Control
            #define SV "1.0"
            #define AC1_ID 1
              i=0;
            void dim_check() {
                if(i>=dim) {
                else {
              dim+=inc;
                inc*=-1;
              delay(18);
            Thank you,
            Mike
            YveauxY
            YveauxY
            @Mike-Cayouette then I guess dim_check never gets called. Can you check if the timer works as expected?
              Mike Cayouette
              @Yveaux How can I get Serial.println to work? I'm using the new 2.0 library and I have a few Serail.println() command in various places, including in void setup(), but I am not getting any output on the serial monitor except for all the debug data.
              Sketch with serial output:
              /*AC Light Control
              #define SV "1.0"
              #define AC1_ID 1
                Serial.println("Dim Sketch started");
                Serial.println("Zero Cross");
                i=0;
              void dim_check() {
                Serial.println("Dim Check");
                  if(i>=dim) {
                  else {
                Serial.print("Dim value: ");
                Serial.println(String(dim));
                dim+=inc;
                  inc*=-1;
                delay(18);
              • M Mike Cayouette
                /*AC Light Control
                #define SV "1.0"
                #define AC1_ID 1
                  i=0;
                void dim_check() {
                    if(i>=dim) {
                    else {
                  dim+=inc;
                    inc*=-1;
                  delay(18);
                YveauxY
                YveauxY
                @Mike-Cayouette if you don't have MY_DEBUG defined you should call Serial.begin() with the Baudelaire yourself.
                  Mike Cayouette
                  @Yveaux There is something wrong with the Serial print command. I have the most basic of sketches below but I see none on the Serial.println() output, but I get all the debug output.
                  #define SV "1.0"
                  int AC1_ID = 1;
                    Serial.println("Loop");
                  what am I doing wrong?
                  Mike
                  TheoLT 1 Reply Last reply
                  • M Mike Cayouette
                    #define SV "1.0"
                    int AC1_ID = 1;
                    Mike
                    TheoLT
                    TheoLT
                    TheoL
                    @Mike-Cayouette Maybe this helps
                      Serial.begin( 115200 );
                    M 1 Reply Last reply
                    • TheoLT TheoL
                      Mike Cayouette
                      @TheoL I tried that also but I thought that was not needed if MY_DEBUG was defined. In any case, event with Serial.begin( 115200 ) it still does not work.
                      I did notice the following 2 errors in the debug output, one after the other.
                      TSP:CHKUPL:FAIL (hops=255)
                      !TSM:UPL:FAIL
                      but I see my sensor registered on my MQTT server.
                      Thank you,
                      Mike
                      TheoLT YveauxY 2 Replies Last reply
                      • M Mike Cayouette
                        !TSM:UPL:FAIL
                        Thank you,
                        Mike
                        TheoLT
                        TheoLT
                        TheoL
                        @Mike-Cayouette I think you won't be getting any serial output from the println's because the node cannot get a handshake with the gateway. But I'm still not familiar with the new debug output.
                        • M Mike Cayouette
                          !TSM:UPL:FAIL
                          Thank you,
                          Mike
                          YveauxY
                          YveauxY
                          @Mike-Cayouette try putting the code suggested by @theol in the before() method instead of in setup()
                          • YveauxY Yveaux
                            Mike Cayouette
                            @Yveaux There is still something odd happening. This is now my basic sketch
                            //#define MY_DEBUG
                            //#define MY_NODE_ID 300
                            #define SV "1.0"
                            unsigned long previousMillis = 0;
                            unsigned long currentMillis = 0;
                            int AC1_ID = 1;
                            int SET_DELAY = 300;
                            void before() {
                             if (currentMillis - previousMillis > SET_DELAY) {
                                send( dimmerMsg.set("Message From Dimmer") );
                                previousMillis = millis();
                                currentMillis = millis();
                            I get the output that is in the before() method, but what I have in the loop is not output at all. Its as if loop is not running at all.
                            Mike
                            • M Mike Cayouette
                              //#define MY_DEBUG
                              #define SV "1.0"
                              int AC1_ID = 1;
                              void before() {
                              Mike
                              YveauxY
                              YveauxY
                              @Mike-Cayouette that's because the mysensors stack doesn't start (e.g radio fails to initialize, or parent can not be found)
                              That is probably also causing setup() not to be called and your timer not being registered!
                              • YveauxY Yveaux
                                Mike Cayouette
                                @Yveaux I find it hard to believe that the radio is not initialized. My MQTT server receives the following when I have the node running:
                                mymqtt-out/44/255/3/0/24
                                I modified the sketch and add the following receive method
                                  Serial.print("Message: ");
                                  Serial.println(message.type);
                                  Serial.print("Message Data: ");
                                  Serial.println(message.data);
                                when I send a payload of 50 to mymqtt-in/44/1/1/0/3, the serial output shows the following:
                                Dim Sketch started
                                Message: 3
                                Message Data: 50
                                I would think if the radio is not initialized this would not be possible.
                                My debug output is below:
                                Dim Sketch started
                                TSM:INIT
                                TSM:RADIO:OK
                                TSP:ASSIGNID:OK (ID=44)
                                TSM:FPAR
                                TSP:MSG:SEND 44-44-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                TSP:MSG:READ 0-0-44 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                TSP:MSG:PAR OK (ID=0, dist=1)
                                TSM:FPAR:OK
                                TSM:ID
                                TSM:CHKID:OK (ID=44)
                                TSM:UPL
                                TSP:PING:SEND (dest=0)
                                TSP:MSG:SEND 44-44-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                !TSM:UPL:FAIL
                                TSM:FPAR
                                TSM:FPAR:OK
                                TSM:ID
                                I remember in the past when the radio would not initialize it said radio init failed or something like that.
                                Thank you,
                                Mike
                                  Mike Cayouette
                                  @Yveaux I solved the problem.
                                  The issue was not my sketch, but rather my ESP8266 MQTT Gateway. I was using an older development version. After upgrading to version 2.0 everything started working. Thankfully my older nodes, using the older development version, are still working, I will upgrade them over time.
                                  This is my final sketch:
                                  #define SV "1.0"
                                  #define AC1_ID 1
                                  #define FADE_DELAY 18      // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
                                  int intPin = 3;
                                  unsigned long previousMillis = 0;        // will store last time LED was updated
                                  int currentLevel =  0;
                                  int requestedLevel = 0;
                                  void before() {
                                    #ifdef MY_DEBUG
                                    Serial.println("Dimmer Node Starting");
                                    attachInterrupt(digitalPinToInterrupt(intPin), zero_cross_detect, RISING);    // Attach an Interupt to Pin 2 (interupt 0) for Zero Cross Detection
                                    i=0;
                                  void dim_check() {
                                      if(i>=currentLevel) {
                                      else {
                                    #ifdef MY_DEBUG
                                    if (message.type == 3) {
                                      int requestedLevel = map(atoi( message.data ), 0, 100, 128, 0); //128 = off | 0 = ON
                                      while (currentLevel != requestedLevel) {
                                        if(currentLevel<=requestedLevel) inc=1;
                                        if(currentLevel>=requestedLevel) inc=-1;
                                        currentLevel+=inc;
                                        #ifdef MY_DEBUG
                                        Serial.print("Current Level:");
                                        Serial.println(String(currentLevel));
                                        //delay
                                        currentMillis = previousMillis = millis();
                                        while (currentMillis - previousMillis < FADE_DELAY) {
                                  There is still one error though. When I try to set my own node id using #define MY_NODE_ID 300, I get the following error:
                                  In file included from /home/sketchbook/libraries/MySensors/MySensors.h:253:0,
                                                   from /home/sketchbook/ACDimmer_Test/ACDimmer_Test.ino:11:
                                  /home/sketchbook/libraries/MySensors/core/MyTransport.cpp: In function 'void stInitTransition()':
                                  /home/sketchbook/libraries/MySensors/core/MyTransport.cpp:74:16: warning: large integer implicitly truncated to unsigned type [-Woverflow]
                                       _nc.nodeId = MY_NODE_ID;
                                  In file included from /home/sketchbook/libraries/MySensors/core/MyHwATMega328.cpp:22:0,
                                                   from /home/sketchbook/libraries/MySensors/MySensors.h:69,
                                  /home/sketchbook/libraries/MySensors/core/MyHwATMega328.h:69:88: warning: large integer implicitly truncated to unsigned type [-Woverflow]
                                    #define hwWriteConfig(__pos, __value) (eeprom_update_byte((uint8_t*)(__pos), (__value)))
                                  /home/sketchbook/libraries/MySensors/core/MyTransport.cpp:76:5: note: in expansion of macro 'hwWriteConfig'
                                       hwWriteConfig(EEPROM_NODE_ID_ADDRESS, MY_NODE_ID);
                                  I was able to set my own node id's in the older development version but it does not seem to work now.
                                  Thank you for all your help.
                                  Mike
                                  • M Mike Cayouette
                                    #define SV "1.0"
                                    #define AC1_ID 1
                                    int intPin = 3;
                                    void before() {
                                      #ifdef MY_DEBUG
                                      i=0;
                                    void dim_check() {
                                        else {
                                      #ifdef MY_DEBUG
                                          currentLevel+=inc;
                                          #ifdef MY_DEBUG
                                          //delay
                                    Mike
                                    @Mike-Cayouette node id needs to be in the range of 1..254.
                                    • M Mike Cayouette
                                      Dim Sketch started
                                      Message: 3
                                      Message Data: 50
                                      Dim Sketch started
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSM:FPAR
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSM:UPL
                                      !TSM:UPL:FAIL
                                      TSM:FPAR
                                      TSM:FPAR:OK
                                      TSM:ID
                                      Thank you,
                                      Mike
                                      YveauxY
                                      YveauxY
                                      @Mike-Cayouette well, suggesting the radio fails was just one of the many possible failures as I indicated.
                                      Great to hear you finally nailed it!
                                        Mike Cayouette
                                        @mfalkvidd Node id's work now.
                                        Thank you everyone for your help.
                                        Mike
