  3. 2 Reed Switches 1 Arduino Nano
6 Posts 3 Posters 3.1k Views 3 Watching
  • DdawmeD
    DdawmeD
    Ddawme
    Hoping for some help from the MySensors experts. Im running a home automation system using Domoticz as my controller and MySensors 2.0 Library for my nodes. I noticed the close proximity of my front door and my garage door and wanted to save a microcontroller and radio by having it handle the reed switches for both doors. First off I do not consider myself a coder Im much more of a hardware kind of guy. I ended up cobbling this sketch together by looking at an example I found in the forums and looking at the included binary switch sketch.
    My issue is when I open the front door, both the garage door and front door indicators on my Domoticz dashboard change state. When I open and close the garage door only the garage door indicator changes state. I suspect it has something to do with how the pin ID's are assigned but I just am not very strong in that department. Any help would be appreciated.
    • The MySensors Arduino library handles the wireless radio link and protocol
    • between your home built sensors/actuators and HA controller of choice.
    • The sensors forms a self healing radio network with optional repeaters. Each
    • repeater and gateway builds a routing tables in EEPROM which keeps track of the
    • network topology allowing messages to be routed to nodes.
    • Created by Henrik Ekblad henrik.ekblad@mysensors.org
    • Copyright (C) 2013-2015 Sensnology AB
    • Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
    • Documentation: http://www.mysensors.org
    • Support Forum: http://forum.mysensors.org
    • This program is free software; you can redistribute it and/or
    • modify it under the terms of the GNU General Public License
    • version 2 as published by the Free Software Foundation.
    • DESCRIPTION
    • Simple binary switch example
    • Connect button or door/window reed switch between
    • digitial I/O pin 3 (BUTTON_PIN below) and GND.
    • http://www.mysensors.org/build/binary
    #include <Bounce2.h>
    #define CHILD_ID_1 3
    #define BUTTON_PIN_1 3 // Arduino Digital I/O pin for button/reed switch
    #define CHILD_ID_2 4
    #define BUTTON_PIN_2 4 // Arduino Digital I/O pin for button/reed switch
    Bounce debouncer1 = Bounce();
    Bounce debouncer2 = Bounce();
    int oldValue1=-1;
    int oldValue2=-1;
    MyMessage msg1(CHILD_ID_1,V_TRIPPED);
    MyMessage msg2(CHILD_ID_2,V_TRIPPED);
    // Setup the button
    pinMode(BUTTON_PIN_1,INPUT);
    pinMode(BUTTON_PIN_2,INPUT);
    // Activate internal pull-up
    digitalWrite(BUTTON_PIN_1,HIGH);
    digitalWrite(BUTTON_PIN_2,HIGH);
    debouncer1.attach(BUTTON_PIN_1);
    debouncer1.interval(5);
    debouncer2.attach(BUTTON_PIN_2);
    debouncer2.interval(5);
    void presentation() {
    present(CHILD_ID_1, S_DOOR);
    present(CHILD_ID_2, S_DOOR);
    // Check if digital input has changed and send in new value
    debouncer1.update();
    // Get the update value
    int value1 = debouncer1.read();
    if (value1 != oldValue1) {
      // Send in the new value
      send(msg1.set(value1==HIGH ? 1 : 0));
      oldValue1 = value1;
    debouncer2.update();
    int value2 = debouncer2.read();
    if (value2 != oldValue2) {
      send(msg2.set(value2==HIGH ? 1 : 0));
      oldValue2 = value2;
    • DickD
      DickD
      Dick
      The compiler is unable to find out what "value" is, since it has not been used before.
      Try this
      gw.send(msg.set(HIGH));
      • DdawmeD Ddawme
        • DESCRIPTION
        int oldValue1=-1;
        int oldValue2=-1;
        // Setup the button
          oldValue1 = value1;
          oldValue2 = value2;
        @Ddawme the code looks good, except that it is hard to read. Use the auto format tool in the Arduino IDE to format it, that will make it much readable. Use the code button in the forum to mark the code as code.
        How is your wiring? Are both switches connected to ground? Does the same problem appear if you physically disconnect the garage door switch and open the front door?
        Next step could be to enable debug on the node to get information on what it does. You can also add Serial.println statements to see which parts of the code is executed and what values the variables have.
        Here is the code in a tidier presentation:
            DESCRIPTION
        int oldValue1 = -1;
        int oldValue2 = -1;
        MyMessage msg1(CHILD_ID_1, V_TRIPPED);
        MyMessage msg2(CHILD_ID_2, V_TRIPPED);
          // Setup the button
          pinMode(BUTTON_PIN_1, INPUT);
          pinMode(BUTTON_PIN_2, INPUT);
          digitalWrite(BUTTON_PIN_1, HIGH);
          digitalWrite(BUTTON_PIN_2, HIGH);
            send(msg1.set(value1 == HIGH ? 1 : 0));
            oldValue1 = value1;
            send(msg2.set(value2 == HIGH ? 1 : 0));
            oldValue2 = value2;
        DdawmeD 2 Replies Last reply
              DESCRIPTION
          int oldValue1 = -1;
          int oldValue2 = -1;
            // Setup the button
              oldValue1 = value1;
              oldValue2 = value2;
          DdawmeD
          DdawmeD
          Ddawme
          @mfalkvidd thank you. I was disappointed when I sat how it formatted. I will check your suggestions today.
                DESCRIPTION
            int oldValue1 = -1;
            int oldValue2 = -1;
              // Setup the button
                oldValue1 = value1;
                oldValue2 = value2;
            DdawmeD
            DdawmeD
            Ddawme
            @mfalkvidd
            Sorry to leave you hanging for so long. Was finally able to start my troubleshooting of the node today. Turns out it did end up being a wiring issue, filed as "Technician Error". Rather than having both the reed switches share a common ground, I had one sensor grounding to the data pin of the other.
            • DdawmeD Ddawme
              @mfalkvidd
              @Ddawme great that you found the problem. Thanks for reporting back!
              Need to keep an extra eye on those pesky technicians ;-)
