  2. Announcements
    @Richard-van-der-Plas what version are you using?
    Richard van der PlasR
    @gohan the latest stable version i guess. Where can i check?
    gohanG 1 Reply Last reply
    • Richard van der PlasR Richard van der Plas
      @Richard-van-der-Plas try the 2.2 beta, it usually works better
      Richard van der PlasR 1 Reply Last reply
        @gohan just checked it's 2.1.1, is it easy to upgrade?
          @Richard-van-der-Plas just clone the 2.2 dev instead of the stable, the rest is the same
            @gohan fatal: destination path 'MySensors' already exists and is not an empty directory. It goes wrong with the first command, could you please give me some pointers ?
              you need to either delete or rename the Mysensors folder :)
              • llegoffL
                llegoffL
                llegoff
                I designed a PCB for rfm or nrf -> raspberry pi
                https://www.openhardware.io/view/470/MySensors-Gateway-for-Raspberry-PI
                  I am trying to get the gateway to run the RFM69W radio but when I issue the "make" command I get this
                  In file included from ./MySensors.h:318:0,
                                   from examples_linux/mysgw.cpp:83:
                  ./drivers/RFM69/new/RFM69_new.cpp:658:12: warning: ‘void RFM69_ATCmode(bool, int16_t)’ defined but not used [-Wunused-function]
                   LOCAL void RFM69_ATCmode(const bool onOff, const int16_t targetRSSI)
                  It is latest beta.
                    It is latest beta.
                    #629
                    @gohan what configure command did you use? Knowing that would make it easier to reproduce the problem...
                    Does this warning cause any problem?
                      Just simple rfm69w 433 with default options. It compiles but I get no communication with nodes and 100% processor, but maybe I did a bad wiring
                        @gohan debug output could be useful ;-)
                          wrote on last edited by gohan
                          #632
                          I would have posted it but it just shows as no nodes are trying to connect and nodes are unable to find a parent of course. I'm using the rfm2nrf pcb in order to have the pins to connect to the raspberry.
                          PS here is the log of the startup
                           __  __       ____
                                  |___/                      2.2.0-beta
                          mysgw: MCO:BGN:INIT GW,CP=RPNG----,VER=2.2.0-beta
                          mysgw: TSF:LRT:OK
                          mysgw: TSM:INIT
                          mysgw: TSF:WUR:MS=0
                          mysgw: TSM:INIT:TSP OK
                          mysgw: TSM:INIT:GW MODE
                          mysgw: MCO:REG:NOT NEEDED
                          mysgw: Listening for connections on 0.0.0.0:5003
                          mysgw: MCO:BGN:STP
                          mysgw: MCO:BGN:INIT OK,TSP=1
                          mysgw: New connection from 127.0.0.1
                          mysgw: Client 0 connected
                          mysgw: Client 0: 0;0;3;0;2;
                          mysgw: Client 0: 0;0;3;0;2;Get Version
                          mysgw: Client 0: 0;0;3;0;18;PING
                            On my test RPI3 it is working.... I have to double check the other one.
                              @gohan Hi there updated to the latest dev, but i still have to restart the service after a few days, this is the message in the log:
                              Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] Closing socket at ('192.168.1.115', 5003).#033[0m
                              Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] Socket closed at ('192.168.1.115', 5003).#033[0m
                              Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] No response. Disconnected.#033[0m
                              Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] Trying to connect to ('192.168.1.115', 5003)#033[0m
                              checking with top, i see high CPU utilization:
                              20921 root      20   0   20036    872    784 R  CPU ->99,5  0,1 682:53.59 mysgw
                              • C ccy
                                @Grubstake: Thanks. I have tried to follow "NRF24L01+ Radio" pin out connection. I have double / triple check my wiring is correct. But I still get the same fail message in mysgw debug mode:
                                [root@alarmpi bin]# ./mysgw -d
                                mysgw: Starting gateway...
                                mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1
                                mysgw: TSM:INIT
                                mysgw: TSF:WUR:MS=0
                                mysgw: !TSM:INIT:TSP FAIL
                                mysgw: TSM:FAIL:CNT=1
                                mysgw: TSM:FAIL:PDT
                                mysgw: TSM:FAIL:RE-INIT
                                mysgw: TSM:INIT
                                mysgw: TSM:FAIL:CNT=2
                                mysgw: TSM:FAIL:PDT
                                mysgw: TSM:INIT
                                mysgw: TSM:FAIL:CNT=3
                                mysgw: TSM:FAIL:PDT
                                mysgw: Received SIGINT
                                Here is my /boot/config.txt:
                                gpu_mem=64
                                initramfs initramfs-linux.img followkernel
                                dtparam=spi=on
                                and the spi dev:
                                # ls /dev/spidev0.*
                                /dev/spidev0.0  /dev/spidev0.1
                                I am using ArchLinuxARM:
                                # uname -a
                                Linux alarmpi 4.9.13-3-ARCH #1 SMP Fri Mar 3 18:45:16 MST 2017 armv7l GNU/Linux
                                I only wiring 7 pins (1-7) on NRF24l01+.
                                Raspberry Pi 2 hardware information:
                                # cat /proc/cpuinfo
                                processor       : 0
                                model name      : ARMv7 Processor rev 5 (v7l)
                                BogoMIPS        : 38.40
                                Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
                                CPU implementer : 0x41
                                CPU architecture: 7
                                CPU variant     : 0x0
                                CPU part        : 0xc07
                                CPU revision    : 5
                                processor       : 1
                                BogoMIPS        : 38.40
                                CPU architecture: 7
                                CPU variant     : 0x0
                                CPU part        : 0xc07
                                CPU revision    : 5
                                processor       : 2
                                BogoMIPS        : 38.40
                                CPU architecture: 7
                                CPU variant     : 0x0
                                CPU part        : 0xc07
                                CPU revision    : 5
                                processor       : 3
                                BogoMIPS        : 38.40
                                CPU architecture: 7
                                CPU variant     : 0x0
                                CPU part        : 0xc07
                                CPU revision    : 5
                                Hardware        : BCM2835
                                Revision        : a21041
                                Serial          : 00000000475d18a4
                                # cat /sys/firmware/devicetree/base/model
                                Raspberry Pi 2 Model B Rev 1.1
                                Output from MySensors configure:
                                # ./configure
                                [SECTION] Detecting target machine.
                                ./configure: line 111: warning: command substitution: ignored null byte in input
                                  [OK] machine detected: SoC=unknown, Type=unknown, CPU=armv7l.
                                [SECTION] Checking GPIO Sysfs.
                                  [OK] /sys/class/gpio/export found
                                [SECTION] Detecting SPI driver.
                                  [OK] SPI driver detected:SPIDEV.
                                [SECTION] Detecting init system.
                                  [OK] init system detected: systemd.
                                [SECTION] Saving configuration.
                                [SECTION] Cleaning previous builds.
                                [OK] Finished.
                                I finally find out my raspberry pi board isn't detected properly in configure. I change the function detect_machine:
                                function detect_machine {
                                    case $hardware in
                                    BCM2835)
                                        soc="BCM2835"
                                        if [[ $machine == "Raspberry"* ]]; then
                                            local rev=($(detect_rpi_revision))
                                            if [[ $rev == "a02082" || $rev == "a22082" ]]; then
                                                tp="RPi3"
                                            else
                                                tp="Rpi2"
                                            fi
                                        fi
                                make mysgw again, and I get this finally:
                                # ./mysgw -d
                                mysgw: TSF:LRT:OK
                                mysgw: TSM:INIT
                                mysgw: TSF:WUR:MS=0
                                mysgw: MCO:BGN:STP
                                J
                                J
                                jacikaas
                                @ccy
                                Hello, I'm also have issue with this question. My Raspberry Pi 2 type is a01041, but by the original "configure" file it is not recognized:
                                Maybe someone could explain why it is not recognized?
                                "Configure" file lines:
                                    case $hardware in
                                    BCM2835)
                                        soc="BCM2835"
                                                tp="RPi3"
                                            else
                                                tp="Rpi2"
                                            fi
                                        fi
                                My Raspberry Pi 2 info:
                                processor       : 0
                                BogoMIPS        : 38.40
                                CPU architecture: 7
                                CPU variant     : 0x0
                                CPU part        : 0xc07
                                CPU revision    : 5
                                processor       : 1
                                BogoMIPS        : 38.40
                                CPU architecture: 7
                                CPU variant     : 0x0
                                CPU part        : 0xc07
                                CPU revision    : 5
                                processor       : 2
                                BogoMIPS        : 38.40
                                CPU architecture: 7
                                CPU variant     : 0x0
                                CPU part        : 0xc07
                                CPU revision    : 5
                                processor       : 3
                                BogoMIPS        : 38.40
                                CPU architecture: 7
                                CPU variant     : 0x0
                                CPU part        : 0xc07
                                CPU revision    : 5
                                Hardware        : BCM2835
                                Revision        : a01041
                                Serial          : 0000000049a14619
                                • TriXwooDT
                                  TriXwooDT
                                  TriXwooD
                                  Double radio or alternative pin for spi1:
                                  https://forum.mysensors.org/topic/7702/double-spi-radio-raspberry-pi/2
                                  • A
                                    A
                                    arraWX
                                    I followed the instructions carefully. However I get an error. Can someone help?
                                    git clone https://github.com/mysensors/MySensors.git --branch master
                                    cd MySensors
                                    ./configure --my-transport=nrf24 --my-gateway=ethernet
                                    This results in a warning:
                                      [WARNING] No supported SPI driver detected.
                                    When I run make I get the follwing error:
                                    In file included from examples_linux/mysgw.cpp:74:0:
                                    ./MySensors.h:254:2: error: #error No support for nRF24 radio on this platform
                                    In file included from ./drivers/RF24/RF24.cpp:23:0,
                                                     from ./MySensors.h:290,
                                    ./drivers/RF24/RF24.h:52:17: fatal error: SPI.h: No such file or directory
                                    compilation terminated.
                                    Makefile:114: recipe for target 'build/examples_linux/mysgw.o' failed
                                    make: *** [build/examples_linux/mysgw.o] Error 1
                                    Hope someone can help. Thanks.
                                    • skywatchS
                                      skywatchS
                                      skywatch
                                      Maybe you didn't enable SPI on the pi.
                                      From command prompt type 'sudo raspi-config', then select option 5 from the menu. This takes you to where you can enable the SPI bus on the pi. Then try again.
                                      S>
                                      • A
                                        A
                                        arraWX
                                        @skywatch Thank you! That solved my problem.
                                        • Sefi NinioS
                                          Sefi NinioS
                                          Sefi Ninio
                                          wrote on last edited by Sefi Ninio
                                          #640
                                          Hello friends,
                                          Reading the instructions for building a RaspberryPi Gateway using RFM69, it states that one should use the development branch and not master, since the Pi is using a different version of the driver.
                                          Anyone knows when this will be merged to master branch?
                                          Also, since this forces all nodes to use development branch as well to be able to communicate with the gateway, assuming I use the development branch now and it is later on merged into master, is there an easy way to upgrade nodes remotely to the new code?
                                          I am planning to use Wall Switch Insertable Node, and Mini Relay Mode - Both support OTA updates, am I correct to assume this will allow upgrading without taking the nodes out of where they are located?
                                          Thanks!
                                          Sefi
