  3. Including new sensor problem
13 Posts 3 Posters 4.3k Views 1 Watching
  • miroM
    miroM
    miro
    Sorry, but I`m a newbie of this. What do I do wrong?
    I made a new BinarySwitchSleep sensor that I trying to include to my Vera. I go to My Sensors plugin and start the including but right away it says "0 devices found".
    Could someone please explain exactly how this process should be done.
    I saw on the site about it and found this "Start inclusion mode on the Arduino Vera device by pressing the "Start" button. Inclusion mode is normally active for 1 minute."
    What start button???
    • miroM miro
      @miro - Hello!
      When you are building a gateway you can add a "Inclusion mode button"
      See here: https://www.mysensors.org/build/advanced_gateway
      Im not sure about Vera, but my guess it should work without and/or you can manually start inclusion mode from vera GUI.
      • miroM
        miroM
        miro
        Now when I trying to verify the BinarySwitchSleepSensor sketch it says "Error compiling for board Arduino Pro or Pro Mini."
        Strange?
        • miroM miro
          Strange?
          @miro - then you have made a coding error. Maybe a typo somewhere.
          • miroM
            miroM
            miro
            Then I think there is a bug on this sketch. Because I just downloaded the new version and tried to upload.
            • miroM miro
              @miro - maybe you should upload the code and error message and im sure we can help you out.
              • miroM
                miroM
                miro
                Sorry for late answer
                 * Interrupt driven binary switch example with dual interrupts
                 * Author: Patrick 'Anticimex' Fallberg
                 * Connect one button or door/window reed switch between
                 * digitial I/O pin 3 (BUTTON_PIN below) and GND and the other
                 * one in similar fashion on digital I/O pin 2.
                 * This example is designed to fit Arduino Nano/Pro Mini
                #define SKETCH_NAME "Binary Sensor"
                #define SKETCH_MAJOR_VER "1"
                #define SKETCH_MINOR_VER "0"
                #define PRIMARY_CHILD_ID 3
                #define SECONDARY_CHILD_ID 4
                #define PRIMARY_BUTTON_PIN 2   // Arduino Digital I/O pin for button/reed switch
                #define SECONDARY_BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch
                #if (PRIMARY_BUTTON_PIN < 2 || PRIMARY_BUTTON_PIN > 3)
                #error PRIMARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
                #if (SECONDARY_BUTTON_PIN < 2 || SECONDARY_BUTTON_PIN > 3)
                #error SECONDARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
                #if (PRIMARY_BUTTON_PIN == SECONDARY_BUTTON_PIN)
                #error PRIMARY_BUTTON_PIN and BUTTON_PIN2 cannot be the same
                #if (PRIMARY_CHILD_ID == SECONDARY_CHILD_ID)
                #error PRIMARY_CHILD_ID and SECONDARY_CHILD_ID cannot be the same
                MyMessage msg(PRIMARY_CHILD_ID, V_TRIPPED);
                MyMessage msg2(SECONDARY_CHILD_ID, V_TRIPPED);
                  // Setup the buttons
                  pinMode(PRIMARY_BUTTON_PIN, INPUT);
                  pinMode(SECONDARY_BUTTON_PIN, INPUT);
                  // Activate internal pull-ups
                  digitalWrite(PRIMARY_BUTTON_PIN, HIGH);
                  digitalWrite(SECONDARY_BUTTON_PIN, HIGH);
                void presentation() {
                  sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER);
                  // Register binary input sensor to sensor_node (they will be created as child devices)
                  present(PRIMARY_CHILD_ID, S_DOOR);
                  present(SECONDARY_CHILD_ID, S_DOOR);
                  uint8_t value;
                  static uint8_t sentValue=2;
                  static uint8_t sentValue2=2;
                  sleep(5);
                  value = digitalRead(PRIMARY_BUTTON_PIN);
                  if (value != sentValue) {
                     // Value has changed from last transmission, send the updated value
                     send(msg.set(value==HIGH ? 1 : 0));
                     sentValue = value;
                  value = digitalRead(SECONDARY_BUTTON_PIN);
                  if (value != sentValue2) {
                     send(msg2.set(value==HIGH ? 1 : 0));
                     sentValue2 = value;
                  // Sleep until something happens with the sensor
                  sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, 0);
                And error message
                Arduino:1.6.11 (Windows 10), Kort:"Arduino Pro or Pro Mini, ATmega328 (3.3V, 8 MHz)"
                C:\Program Files (x86)\Arduino\libraries\MySensors\examples\BinarySwitchSleepSensor\BinarySwitchSleepSensor.ino:41:23: fatal error: MySensors.h: No such file or directory
                compilation terminated.
                exit status 1
                option enabled in File -> Preferences.
                • miroM miro
                    uint8_t value;
                    sleep(5);
                       sentValue = value;
                       sentValue2 = value;
                  And error message
                  exit status 1
                  @miro seems like the Arduino IDE is unable to find the MySensors library. How did you install the library? Which version did you install?
                  Instructions for installing the library are available at https://www.mysensors.org/about/arduino#installing-the-sensor-libraries if you need them.
                  • miroM
                    miroM
                    miro
                    @mfalkvidd You were right. My mistake.
                    Now there is a new error message when try to upload the scetch. Any ideas?
                    Using Port                    : COM6
                    Using Programmer              : arduino
                    Overriding Baud Rate          : 57600
                    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x6a
                    avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x15
                    avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x44
                    avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x12
                    avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x61
                    avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xaa
                    avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x6c
                    avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xef
                    avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x38
                    avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x50
                    avrdude done.  Thank you.
                    An error occurred while uploading the sketch```
                    • miroM miro
                      Using Port                    : COM6
                      @miro - check your connection/wiring from the programmer to your board.
                      • miroM
                        miroM
                        miro
                        There was something wrong on the sensor so I made a new one. Now it looks ok in the serial monitor "I THINK"?
                        But I still can`t get it included in Vera Edge UI7?
                        I did a test with the button that was written here before, but that function I have in Vera so not nessecary.
                        (When I activated the button on pin 3, it activated the vera UI button)
                        When I click on START to include the sensor it just says "0 devices found" and nothing happends. What is the problem?
                        Now I have no clue.
                        TSM:INIT
                        TSM:RADIO:OK
                        TSP:ASSIGNID:OK (ID=1)
                        TSM:FPAR
                        TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                        TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                        TSP:MSG:PAR OK (ID=0, dist=1)
                        TSM:FPAR:OK
                        TSM:ID
                        TSM:CHKID:OK (ID=1)
                        TSM:UPL
                        TSP:PING:SEND (dest=0)
                        TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                        • miroM
                          miroM
                          miro
                          I tried to include a different motion sensor and that workt on the first try. This is strange.
                          • miroM
                            miroM
                            miro
                            wrote on last edited by miro
                            The only thing I changed in parts is that I use a NRF24L01+ with antenna. But I don`t think I need to change anything in the code for that?
                            And I use a Arduino Pro mini 3.3V with two AA Batteries.
