  3. Guide for connecting several small RGB 5050 ledstrips?
7 Posts 3 Posters 2.4k Views 3 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    I tried searching the forums but did not find any description of how to connect a 5050 led strip to an arduino and "Mysensorize" it.
    I would like to know how to connect four small 5050 strips to one arduino to be able to control all four led strips individualy.
    BartEB 1 Reply Last reply
      BartEB
      BartEB
      BartE
      wrote on last edited by BartE
      @Cliff-Karlsson using the search feature and searching for RGB gave me this hit (#8)
      https://forum.mysensors.org/topic/4871/fire-pit-rgb-striplight-controller
      looking at the examnples gave this link: https://www.mysensors.org/build/dimmer
      You can combine the two of them...
      And there is a very recent post https://forum.mysensors.org/topic/4938/rgbw-setup
      • Cliff KarlssonC
        Cliff KarlssonC
        Cliff Karlsson
        @BartE said:
        Yes I have already looked at those links and the first link has an sketch. The second link is for a white-only strip and I guess you have to connect them diferantly to be able to control the colors.
        The last link I also looked at but found the pictures pretty hard to follow how all copnnections was made.
          BartEB
          BartEB
          BartE
          @Cliff-Karlsson it is basically 4 times this https://www.mysensors.org/build/dimmer wiring. These LED strips share the ground
          • Cliff KarlssonC
            Cliff KarlssonC
            Cliff Karlsson
            Ok, thanks for clearing that up for me. What would the smartest way to connect four induvidally controlable short strips? Can I use one mini pro to control 16 mosfets? (I want to be able to light up four shelves in a bookcase)
              BartEB
              BartEB
              BartE
              @Cliff-Karlsson if you want to dim the strips it requires PWM (pulse width modulation) pens and the nano only has 6 of them (D3, D5, D6, D9, D10 and D11)
              D11 and D10 are occupied by the MySensors radio leaving 4 to controll the LED strip.
              So you will requires either:
              • list itema different Arduino (the MEGA has 15 PWM's)
              • or using ShiftPWM (http://www.elcojacobs.com/shiftpwm/)
              • or use 4 Arduinos
              • L
                L
                LastSamurai
                I am using my RGBW controller like that. I have some of these nodes controlling multiple strips. Although if you want to controll them individually you need a controller for each one. (or build one that has more mosfets, then you are only limited by the number of pwm pins on the arduino you are using).
