  3. Dallas DS18B20 compiling error
3 Posts 2 Posters 2.1k Views 2 Watching
  • JohanRCJ
    JohanRCJ
    JohanRC
    Hi All,
    I am having a problem with compiling the code for 3 Dallas DS18B20 temperature sensors.
    I am using the IDE 1.6.12 with fresh library's imported as per these instructions.
    The errors are in this piece of code:
      sleep(conversionTime);
    The errors I am getting are as follows:
    In file included from C:\Users\johan\Documents\Arduino\examples\DallasTemperatureSensor\DallasTemperatureSensor.ino:37:0:
    C:\Users\johan\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h: In function 'void loop()':
    C:\Users\johan\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h:252:13: error: 'int16_t DallasTemperature::millisToWaitForConversion(uint8_t)' is private
         int16_t millisToWaitForConversion(uint8_t);
    DallasTemperatureSensor:85: error: within this context
    exit status 1
    within this context
    At this moment I am completely clueless on how to continue.
    Thanx in advance!
    Best regards Johan
    RaspberryPi Domoticz - Serial gateway - 12 nodes and counting
    • JohanRCJ JohanRC
      Hi All,
      exit status 1
      within this context
      Thanx in advance!
      Best regards Johan
      @JohanRC you need to install the dallas library available in https://github.com/mysensors/MySensorsArduinoExamples
      See also
      https://forum.mysensors.org/topic/2902/dallas-temp-failure-to-compile/21
      https://forum.mysensors.org/topic/4828/temperature-sensor/3
      https://forum.mysensors.org/topic/2434/dallas-temperature-sensor-compiling-error/18
      • JohanRCJ
        JohanRCJ
        JohanRC
        wrote on last edited by JohanRC
        Thanx 😀
        The compiling errors are now solved!
        Unfortunately the problem is not solved yet, the led L flashes a couple of times when starting and after that it starts to burn softly.
        It looks like it stops working after this.
        The Nano and Dallas sensors are connected OK, when I check it with a simple sketch I can reed the temperatures through the serial connection.
