  3. Ethernet gateway not willing to accept IP number
6 Posts 2 Posters 2.7k Views 2 Watching
  • Maurizio ColluM
    Maurizio ColluM
    Maurizio Collu
    Dear all,
    I tried to use an ethernet gateway, following exactly the instructions here:
    https://www.mysensors.org/build/ethernet_gateway
    and using the WizNET (W5100) Ethernet module.
    I got the followinf messages from the arduino monitor:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 255.255.255.255
    0;255;3;0;9;TSP:SANCHK:OK
    I used the code provided in the mysensors package (2.0) from the arduino program, where it specifies as IP address
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 97
    I cannot find this gateway with my controller - not at 192.168.1.97 nor at 255.255.255.255
    Can anyone explain me why?
    Thanks a lot
    • Maurizio ColluM Maurizio Collu
      Dear all,
      IP: 255.255.255.255
      Thanks a lot
      @Maurizio-Collu could you describe what do you do when you try to find the controller, and what happens?
      Is the ip address define line before the MySensors include?
      Is the ip address in the same adress range as your local network?
      255.255.255.255 is a broadcast address. You will probably not get a useful reply from there.
      • Maurizio ColluM
        Maurizio ColluM
        Maurizio Collu
        Thanks @mfalkvidd
        Yes, it is defined before the MySensors include
        And yes, it is defined in the same address range
        Here it is the code
        #define MY_GATEWAY_W5100
        //#define MY_W5100_SPI_EN 4
        // radio on the same spi bus.
          #define MY_SOFTSPI
        #ifndef MY_RF24_CE_PIN
          #define MY_RF24_CE_PIN 5
        #ifndef MY_RF24_CS_PIN
          #define MY_RF24_CS_PIN 6
        // Enable to UDP
        //#define MY_USE_UDP
        #define MY_IP_ADDRESS 192,168,1,66   // If this is disabled, DHCP is used to retrieve address
        #define MY_PORT 5003
        // Flash leds on rx/tx/err
        #define MY_LEDS_BLINKING_FEATURE
        // Set blinking period
        // Enable inclusion mode
        //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
        //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
        //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
        #if defined(MY_USE_UDP)
          #include <EthernetUdp.h>
        #include <Ethernet.h>
          Looks like you've confused the gateway with the controller. The gateway is defined to use 192.168.1.66.
          See https://www.mysensors.org/about/network for details on which component does what.
          Maurizio ColluM 1 Reply Last reply
            Maurizio ColluM
            Maurizio ColluM
            Maurizio Collu
            Thanks @mfalkvidd
            I'm not sure I understood your observation - probably I am missing something quite basic.
            I have a RasPi with Home Assistant installed (controller), with IP address 192.168.1.97, and I have connected to this RasPi an Arduino with the radio module - this is my serial controller.
            I would like to use also an ethernet gateway (in home assistant you can have more than one fateway), to receive signals of sensors in some remote rooms, and therefore I am using a W5100, NRF24L01, and an arduino (nano). I am asking through the code that this should have the IP address 192.168.1.66.
            What is wrong with this setup?
              Thanks @mfalkvidd
              @Maurizio-Collu I don't see anything wrong with that. You're the one saying something is wrong :-)
              Could you describe what you do when you try to find the W5100 gateway, what you expected to happen when you tried that, and what you experienced instead?
