  3. Domoticz
  4. Serial Gateway not recognized
5 Posts 3 Posters 2.4k Views 3 Watching
  • E Offline
    E Offline
    edsteve
    wrote on last edited by edsteve
    Domoticz is running on a NanoPi Linux. I just started with Domoticz. The gateway was recognized 2 days ago, but after i accidentally removed the sdcard while running it won't recognize the gateway any more. Made a fresh Domoticz installation. But no entry in the Hardware section :(
    So my gateway is connected to ttyUSB0 according to dmesg. Correct?
    [  400.935722] ch341 6-1:1.0: device disconnected
    [  406.871835] ehci_irq: highspeed device connect
    [  407.080056] ehci_irq: highspeed device disconnect
    [  407.080087] ohci_irq: fullspeed or lowspeed device connect
    [  407.510120] usb 8-1: new full-speed USB device number 2 using sunxi-ohci
    [  407.731631] ch341 8-1:1.0: ch341-uart converter detected
    [  407.772934] usb 8-1: ch341-uart converter now attached to ttyUSB0
    This is the only thing that happens after starting Domoticz:
    2016-10-10 20:22:52.046 Domoticz V3.5744 (c)2012-2016 GizMoCuz
    2016-10-10 20:22:52.047 Build Hash: 289b09a, Date: 2016-10-09 15:14:57
    2016-10-10 20:22:52.047 Startup Path: /root/domoticz/
    2016-10-10 20:22:52.133 Sunrise: 07:12:00 SunSet:19:10:00
    2016-10-10 20:22:52.133 EventSystem: reset all events...
    2016-10-10 20:22:52.163 Active notification subsystems: (0/12)
    2016-10-10 20:22:52.195 WebServer(HTTP) started on address: :: with port 8080
    2016-10-10 20:22:52.220 WebServer(SSL) started on address: :: with port 443
    2016-10-10 20:22:52.222 Proxymanager started.
    2016-10-10 20:22:52.225 Starting shared server on: :::6144
    2016-10-10 20:22:52.225 TCPServer: shared server started...
    2016-10-10 20:22:52.226 RxQueue: queue worker started...
    2016-10-10 20:22:54.229 EventSystem: reset all events...
    2016-10-10 20:22:54.230 EventSystem: reset all device statuses...
    2016-10-10 20:22:54.232 EventSystem: Started
    2016-10-10 20:22:54.950 Incoming connection from: 192.168.1.155
    So. No gateway found. :(
    This is my Gateway sketch from Arduini IDE examples:
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Flash leds on rx/tx/err
    #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // Enable inclusion mode
    void presentation() {
    When i connect the Gateway to my windows PC the serial monior shows this:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    0;255;0;0;18;2.0.0
    I don't see what can be wrong. What else can i check or change?
    Cheeers from Sumatra
    ED
    • F Offline
      F Offline
      flopp
      What are your settings in Domoticz, hardware?
      • E Offline
        E Offline
        edsteve
        I am not sure what you mean by "settings"? Where can i do hardware settings?
        Here is how my Hardware section looks like:
        0_1476105855079_upload-f4fdbfa2-7027-44ab-bf78-172eb678a976
        • E Offline
          E Offline
          edsteve
          Wow.
          Proof of beeing a real noob:
          I thought it will recognize the gateway automatically. But seems i must add it manual.
          Stupid me. Sorry wasting time and space.
          • E edsteve
            Wow.
            @edsteve no waste at all. Someone else might make the same mistake and now they'll be able to find the solution if they search. Thanks for reporting back :)
            12.2k
