  3. Serial Gateway mystery
gatewayserial
3 Posts 3 Posters 2.5k Views 1 Watching
  • C
    C
    cribben
    wrote on last edited by cribben
    I use Arduino Nano as serial gateway and after some initial problem it now works ok. I also have one node with two DS18B20 up and go.
    The mystery is that I have a red banner saying "Can't Detect Device" beneath the MySensors Plugin description in Devices. Also in Dashboard I have a message "1 Device no longer connected".
    I have try to delete the plugin and reinstall everything but with same result.
    I use UI7.
    Pls help, I don't want this allert.
    • greglG
      greglG
      gregl
      Reading the micasaverde forums, apparently this "error" is quite common for many plugins
      See:
      http://forum.micasaverde.com/index.php/topic,13697.msg198461.html#msg198461
      Despite the error message - does the Mysensors plugin work?
      • 5546dug5
        5546dug5
        5546dug
        Thanks for all the info all
        But still have the problem with vera3 on ui7
        Cribben, I follow the instructions on the my sensor vera plugin and it comes up with ver 1.3 and no lib #
        how did you get the new plugin to load
        Any help at all would be welcome as ui7 is not too smooth yet.
