  3. Two pulse power meters on one Arduino
3 Posts 2 Posters 882 Views 2 Watching
  • P
    P
    Pewh
    wrote on last edited by Pewh
    I use MySensors 2.0 and trying to set up a pulse power meter. If I use the default sketch everything works fine but my mission is to have two pulse meters connected to one Arduino.I have duplicated all variables. The sketch presents two childs to the controller (Domoticz).
    What I don´t really understand is the use of the "receive" function.
      Serial.print("Receive.....");
      if (message.type==V_VAR1) {
        Serial.println(pulseCount);
        pcReceived = true;
    How should I get the pulsecount from child 2?
    Here is the entire sketch.
    // Enable debug prints
    #define DIGITAL_INPUT_SENSOR 2  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
    #define DIGITAL_INPUT_SENSOR2 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
    #define PULSE_FACTOR 1000       // Nummber of blinks per KWH of your meeter
    #define PULSE_FACTOR2 2000       // Nummber of blinks per KWH of your meeter
    #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
    #define MAX_WATT 25000          // Max watt value to report. This filetrs outliers.
    #define MAX_WATT2 25000
    #define CHILD_ID 1              // Id of the sensor child
    #define CHILD_ID2 2              // Id of the sensor child
    unsigned long SEND_FREQUENCY = 5000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
    double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
    double ppwh2 = ((double)PULSE_FACTOR2)/1000; // Pulses per watt hour
    boolean pcReceived = false;
    boolean pcReceived2 = false;
    volatile unsigned long pulseCount2 = 0;
    volatile unsigned long lastBlink2 = 0;
    volatile unsigned long watt = 0;
    volatile unsigned long watt2 = 0;
    unsigned long oldPulseCount2 = 0;
    unsigned long oldWatt = 0;
    unsigned long oldWatt2 = 0;
    double oldKwh;
    double oldKwh2;
    unsigned long lastSend;
    unsigned long lastSend2;
    MyMessage wattMsg(CHILD_ID,V_WATT);
    MyMessage kwhMsg(CHILD_ID,V_KWH);
    MyMessage wattMsg2(CHILD_ID2,V_WATT);
    MyMessage kwhMsg2(CHILD_ID2,V_KWH);
    MyMessage pcMsg2(CHILD_ID2,V_VAR1);
      request(CHILD_ID, V_VAR1);
      request(CHILD_ID2, V_VAR1);
      // Use the internal pullup to be able to hook up this sketch directly to an energy meter with S0 output
      // If no pullup is used, the reported usage will be too high because of the floating pin
      pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
      pinMode(DIGITAL_INPUT_SENSOR2,INPUT_PULLUP);
      attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
      attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR2), onPulse2, RISING);
      lastSend=millis();
    void presentation() {
      sendSketchInfo("Energy Meter", "1.1");
      present(CHILD_ID, S_POWER);
      present(CHILD_ID2, S_POWER);
      unsigned long now = millis();
      bool sendTime = now - lastSend > SEND_FREQUENCY;
      if (pcReceived && (SLEEP_MODE || sendTime)) {
        // New watt value has been calculated
        if (!SLEEP_MODE && watt != oldWatt) {
          // Check that we dont get unresonable large watt value.
          // could hapen when long wraps or false interrupt triggered
          if (watt<((unsigned long)MAX_WATT)) {
            send(wattMsg.set(watt));  // Send watt value to gw
          Serial.print("Watt huset:");
          Serial.println(watt);
          oldWatt = watt;
    if (!SLEEP_MODE && watt2 != oldWatt2) {
          if (watt2<((unsigned long)MAX_WATT2)) {
            send(wattMsg2.set(watt2));  // Send watt value to gw
          Serial.print("Watt varmepump:");
          Serial.println(watt2);
          oldWatt2 = watt2;
        // Pulse count has changed
        if (pulseCount != oldPulseCount) {
          send(pcMsg.set(pulseCount));  // Send pulse count value to gw
          double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
          oldPulseCount = pulseCount;
          if (kwh != oldKwh) {
            send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
            oldKwh = kwh;
            Serial.print("kWh huset:");
            Serial.println(kwh);
        // Pulse count2 has changed
        if (pulseCount2 != oldPulseCount2) {
          send(pcMsg2.set(pulseCount2));  // Send pulse count2 value to gw
          double kwh2 = ((double)pulseCount2/((double)PULSE_FACTOR2));
          oldPulseCount2 = pulseCount2;
          if (kwh2 != oldKwh2) {
            send(kwhMsg2.set(kwh2, 4));  // Send kwh value to gw
            oldKwh2 = kwh2;
            Serial.print("kWh varmepump:");
            Serial.println(kwh2);
        lastSend = now;
      } else if (sendTime && !pcReceived) {
        // No count received. Try requesting it again
        lastSend=now;
      if (SLEEP_MODE) {
        sleep(SEND_FREQUENCY);
    } //End loop
        pcReceived = true;
    void onPulse()
      if (!SLEEP_MODE) {
        unsigned long interval = newBlink-lastBlink;
        if (interval<10000L) { // Sometimes we get interrupt on RISING
          return;
        watt = (3600000000.0 /interval) / ppwh;
        lastBlink = newBlink;
      pulseCount++;
    void onPulse2()
      if (!SLEEP_MODE) {
        unsigned long newBlink2 = micros();
        unsigned long interval2 = newBlink2-lastBlink2;
        if (interval2<10000L) { // Sometimes we get interrupt on RISING
          return;
        watt2 = (3600000000.0 /interval2) / ppwh2;
        lastBlink2 = newBlink2;
      pulseCount2++;
    • P
      P
      Pewh
      I think I solved it myself after some searching on this forum.
      if (message.type == V_VAR1) {
            if (message.sensor == 1) {
              Serial.println("Received data from child 1: ");
            else if (message.sensor == 2) {
              pulseCount2 = oldPulseCount2 = message.getLong();
              Serial.println("Received data from child 2: ");
              Serial.println(pulseCount2);
        pcReceived = true;
      • P Pewh
          pcReceived = true;
        @Pewh yes, that's the way. Great work, and thanks for posting the solution!
