  3. Defective pro mini and the solution
2 Posts 2 Posters 1.1k Views 2 Watching
  • F
    F
    fleinze
    Hi!
    I had a pro mini which stopped working with the following symptoms:
    • No communication
    • not even a flicker on Pin 13 LED
    • not responding to programming attempts, not even with ISP.
    • RST pin has a voltage of ca. 100mV
    The pro mini started working again without me doing anything and then after a few months stopped working again.
    After a lot of soldering (replacing most components including the atmega) it turned out that the board had a ca. 100 Ohm short between RST and GND...
    So if you experience the above symptoms just measure resistance between RST and GND.
    • F fleinze
      Hi!
      • No communication
      @fleinze interesting experience. Thanks for sharing.
