Connect Serial Gateway to Openwrt routers TX RX pins
found some thing - How to terminate console on serial port (UART)
am i on right direction? -
It is possible to connect Serial Gateway to router's TX RX pins?
Will be nice not using router's usb port, and leave it for someone else.
Would like to use MySensors wit Domoticz installed on router.
Right now WiFi Gateway used.This post is deleted! -
it works, but now i see it unstable. a lot of garbage received
2;5;1;0;35;184.367 ;0.13;1;1;013;6;1;0;16;1 ;4;1;0;24;121056 2;4;1;0;35;121.056```Did you try it with a lower baud rate? 9600?
I tried 57600. Right now i tried on Padavan firmware on Xiaomi router 3.
And i can't compile firmware with lower than 57600But I start domoticz with -verbose 0 -loglevel 0, and it working better. Need to test more.
Are you sure you need to set the rate in the code and recompile? Shouldn't it be enough to change it in config.h and domoticz? The uart of the router should be able to change the speed at runtime like other Linux devices, right?
I tried set rate in domoticz and by
stty -F /dev/ttyS0 9600 clocal cread cs8 -cstopb -parenb
but after a time it come back to rate what set incat /proc/cmdline console=ttyS0,115200n8 root=/dev/mtdblock4 rootfstype=squashfsit looks like i need to recompile firmware.
The console paramter needs to be removed completely. You cannot use the uart for domoticz and as serial console at the same time.
https://wiki.openwrt.org/doc/recipes/terminate.console.on.serial
