  3. [SOLVED] Unable to write data to serial port on pi3
3 Posts 2 Posters 1.1k Views 2 Watching
    A Former User
    Hello everyone,
    I'm trying to create a custom controller on a pi 3. I have some really specific need.
    I have build MySensors using the following command :
    ./configure —my-debug=enable —my-gateway=serial --my-serial-pty=/dev/ttyGateway --my-serial-is-pty --my-rf24-ce-pin=22 --my-rf24-cs-pin=24 --my-rf24-irq-pin=13
    Everything is working fine, the radio is working and I can receive data from nodes with a static ID.
    What I want to do is to handle ID request from nodes and to simply send data to nodes. The issue is that I can't write to the serial port.
    When I try to do :
    sudo echo "255;0;3;0;4;4" > /dev/ttyGateway
    I get : "Permission not granted"
    When I do : ls -l /dev/ttyGateway
    lrwxrwxrwx 1 root root 10 mars   4 13:51 /dev/ttyGateway -> /dev/pts/5
    In principle it should work with no issue, right ?
    My question is : How can I send data by writing to the serial port ?
    YveauxY 1 Reply Last reply
    • ? A Former User
      Hello everyone,
      When I try to do :
      YveauxY
      YveauxY
      @sapher said in Unable to write data to serial port on pi3:
      Try
      sudo echo "255;0;3;0;4;4" | sudo tee /dev/ttyGateway > /dev/null
      or make yourself superuser:
      sudo su
        A Former User
        @Yveaux said in Unable to write data to serial port on pi3:
        Thank you dear Sir, both of your solution work. Amazing.
        I hope this will help others. Cause I can sense that this is pretty basic Linux stuff. But I was stuck for days on that. Thank you :+1:
