  3. MH-Z19 CO2 sensor
MH-Z19 CO2 sensor
23 Posts 10 Posters 27.0k Views 9 Watching
  • alowhumA
    alowhumA
    alowhum
    I couldn't find a thread about this specific sensor, even though it seems to be the most popular one currently.
    I found some perhaps useful pieces of code:
    • The MH-Z14 thread on MySensors. I suspect code for the MH-Z14 can be re-used?
    • Code for a ESP8266
    • And this is a lovely project that also has some arduino code, but it just seems to be code to run the display?
    Does anyone have working code they could share?
    parachutesjP 1 Reply Last reply
    • alowhumA alowhum
      parachutesjP
      parachutesjP
      parachutesj
      @alowhum what about that:https://www.mysensors.org/build/gas ?
      • alowhumA
        alowhumA
        alowhum
        If you mean the MG811 on that list: it's pretty bad.
        • Long warmup times (24 hours..)
        • Needs 6v
        • Doesn't really measure CO2, but responds to all kinds of other gasses too.
        • Loses callibration. It's mostly a chemical proces.
        The cool thing about the MH-Z14 and the even better MH-Z19 is that they use light spectrum analysis. They send infrared light, and measure how much of that light is absorbed in the spectrum that CO2 absorbs in.
        While not very accurate, they are very precise.
        precise vs accurate
        So they are not very good in giving absolute values, but they are very good in measuring relative changes.
        These sensors have a function where you can set the baseline by sending them a specific command. For example, you could take the sensor outside, and then set the outside value as the zero mark. Or you could just use the value they put in at the factory.
        • alowhumA
          alowhumA
          alowhum
          Some more useful code sources I found:
          http://electronics.stackexchange.com/questions/262473/mh-z19-co2-sensor-giving-diferent-values-using-uart-and-pwm
          http://forum.arduino.cc/index.php?topic=445938.0
          Russian snippets:
          http://www.2150692.ru/faq/87-co2-mhz19-arduino
          I've learnt that you can get data form this sensor in three ways.
          • Serial (uart)
          • Analog
          • PWM
          The datasheet can be found here. There seem to be 2 version of the sensor (the manual refers to 'v2'). And you can set it to give a reading between 0 and 2000ppm or between 0 and 5000ppm. You send it a code to switch these two modes.
          This seems a useable code:
          int readCO2()
            byte cmd[9] = {0xFF, 0x01, 0x86, 0x00, 0x00, 0x00, 0x00, 0x00, 0x79};
            // command to ask for data
            char response[9]; // for answer
            mySerial.write(cmd, 9); //request PPM CO2
            mySerial.readBytes(response, 9);
            if (response[0] != 0xFF)
              Serial.println("Wrong starting byte from co2 sensor!");
              return -1;
            if (response[1] != 0x86)
              Serial.println("Wrong command from co2 sensor!");
              return -1;
            int responseHigh = (int) response[2];
            int responseLow = (int) response[3];
            int ppm = (256 * responseHigh) + responseLow;
            return ppm;
          Just be sure not to call that function too often, the sensor has to warm up.
          The SenseAir S8 sensor also looks good. It auto-callibrates apparently, and it comes with an arduino library. But it's about $60 at the moment.
          • alowhumA
            alowhumA
            alowhum
            I received the device, and have a mySensor working. I'll share the code here after a little clean-up.
            • alowhumA
              alowhumA
              alowhum
              The code:
               *  DESCRIPTION
               *  MH-Z19 CO2 sensor
               *  It communicates with your board over serial at 9600 speed.
              // if you uncomment this, you can get test and debug updates about the sensor' wireless connection by using the serial monitor tool.
              #define MY_RADIO_NRF24                            // A 2.4Ghz transmitter and receiver, often used with MySensors.
              // #define MY_RF24_PA_LEVEL RF24_PA_MIN           // This sets a low-power mode for the radio. Useful if you use the verison with the bigger antenna, but don't want to power that from a separate power source. It can also fix problems with fake Chinese versions of the radio.
              // #define MY_RADIO_RFM69                         // 433Mhz transmitter and reveiver.
              // Choose if you want this sensor to also be a repeater.
              // #define MY_REPEATER_FEATURE                    // Just remove the two slashes at the beginning of this line to also enable this sensor to act as a repeater for other sensors. If this node is on battery power, you probably shouldn't enable this.
              // Libraries
              #include <SoftwareSerial.h>
              // This can be changed:
              unsigned long co2MeasurementInterval = 30000;     // Time to wait between reads (in milliseconds).
              SoftwareSerial mySerial(10, 11);                  // RX, TX . You can choose other pins if you prefer.
              // Mysensors settings
              #define CHILD_ID_CO2 0                            // The Co2 sensor' ID on this node.
              MyMessage msgCo2(CHILD_ID_CO2, V_LEVEL);
              MyMessage msgCo2b(CHILD_ID_CO2, V_UNIT_PREFIX);
                sendSketchInfo("AIQ Sensor CO2 MH-Z19", "1.1");
                // Register attached sensor(s) to gateway
                present(CHILD_ID_CO2, S_AIR_QUALITY);
                send(msgCo2b.set("ppm"));
                delay(1000);
                Serial.begin(115200);
                delay(1000);
                mySerial.begin(9600);
                delay(2000);
                while (mySerial.read()!=-1) {};  //clear Co2 buffer.
                Serial.println("hello world, I am a sensor.");
                 // You should not change these variables:
                 static unsigned long previousCo2Millis = 0;       // Used to remember the time of the last temperature measurement.
                 unsigned long currentMillis = millis(); // The time since the sensor started, counted in milliseconds. This script tries to avoid using the Sleep function, so that it could at the same time be a MySensors repeater.
                if (currentMillis - previousCo2Millis >= co2MeasurementInterval) { // this only gets triggered when enough time has passed.
                  Serial.println("CO2 - Sending data request to sensor.");
                  previousCo2Millis = currentMillis;
                  long co2ppm = readCO2();
                  Serial.println("Co2 - PPM = " + String(co2ppm));
                  send(msgCo2.set((long)ceil(co2ppm)));
                  Serial.print("Co2 - zzzzZZZZzzzzZZZZzzzz\n");
              // Main function that gets the Co2 data
              int readCO2()
                while (mySerial.read()!=-1) {};  //clear serial buffer
                  Serial.print(response[0], HEX);
                  Serial.print(" - ");
                  Serial.print(response[1], HEX);
                  Serial.print(response[2], HEX);
                  Serial.print(response[3], HEX);
                  Serial.print(response[4], HEX);
                  Serial.print(response[5], HEX);
                  Serial.print(response[6], HEX);
                  Serial.print(response[7], HEX);
                  Serial.print(response[8], HEX);
                  Serial.println(" - END");
                  Serial.println("Wrong starting byte from co2 sensor! (should be FF)");
                  return -1;
                  Serial.println("Wrong command from co2 sensor! (should be 86)");
                  return -1;
                return ppm;
              • Daniel OliveiraD
                Daniel OliveiraD
                Daniel Oliveira
                Hi!
                Thank you for sharing, can you please point me out how do I wire this thing up? :)
                MySensors rules my home :)
                • Daniel OliveiraD Daniel Oliveira
                  Hi!
                  @daniel-oliveira isn't this sufficient? If not, what is missing?
                   *  MH-Z19 CO2 sensor
                  • Daniel OliveiraD
                    Daniel OliveiraD
                    Daniel Oliveira
                    @mfalkvidd said in MH-Z19 CO2 sensor:
                     *  MH-Z19 CO2 sensor
                    Missed that one, got confused due to the multiple possible ways to connect this sensor. (UART, PWM, etc)
                    So TX, RX, GND and Vin sould be enough?
                       *  MH-Z19 CO2 sensor
                      @daniel-oliveira I haven't tried myself, but I think so.
                      • R
                        R
                        ristomatti
                        @daniel-oliveira said in MH-Z19 CO2 sensor:
                        TX, RX, GND and Vin
                        I can confirm only TX, RX, GND and Vin are needed. I've setup the device with a Wemos D1 Mini using the code found here https://github.com/jehy/arduino-esp8266-mh-z19-serial/
                        It's not MySensors related though, I've yet to try MySensors myself but registered to this forum to reply as I found this conversation while looking for code samples for the sensor. :)
                        • R ristomatti
                          TX, RX, GND and Vin
                          Thanks for confirming @ristomatti, and welcome to the forum :)
                          • alowhumA
                            alowhumA
                            alowhum
                            I just tried using this code on an different board and got some weird output from the sensor (FFFFFF instead of FF as the starting byte). I found some mumbo-jumbo explanations of what Arduino is doing here. But the short of it is, is that this code fixes that issue (by wrapping the output in byte() functions).
                             *  DESCRIPTION
                             *  MH-Z19 CO2 sensor
                            //#define MY_DEBUG
                            // Libraries
                            SoftwareSerial mySerial(3, 4);                    // RX, TX . You can choose other pins if you prefer. Remember: TX (transmit) on the sensor must be connected to RX (receive) on the Arduino.
                              delay(1000);
                              Serial.begin(9600);
                              delay(1000);
                              delay(2000);
                              // You should not change this variable:
                            int readCO2()
                                Serial.print(byte(response[0]), HEX) ;
                                Serial.print(byte(response[1]), HEX) ;
                                Serial.print(byte(response[2]), HEX);
                                Serial.print(byte(response[3]), HEX);
                                Serial.print(byte(response[4]), HEX);
                                Serial.print(byte(response[5]), HEX);
                                Serial.print(byte(response[6]), HEX);
                                Serial.print(byte(response[7]), HEX);
                                Serial.print(byte(response[8]), HEX);
                              if (byte(response[0]) != 0xFF)
                                return -1;
                              if (byte(response[1]) != 0x86)
                                return -1;
                              int responseHigh = (int) byte(response[2]);
                              int responseLow = (int) byte(response[3]);
                              return ppm;
                            • Daniel OliveiraD
                              Daniel OliveiraD
                              Daniel Oliveira
                              I finally got this sensor to work but instead I use this lib: https://github.com/nara256/mhz19_uart
                              Another very useful source of information is this: https://revspace.nl/MHZ19#command_0x62_.28device_name_.2F_id.29
                              Take note that is the MH-Z19B the methods isWarming() and getStatus() do not work.
                              Can you please share the values that you are getting? I'm getting around 1500ppm and it is alarming by these website standards:
                              https://www.engineeringtoolbox.com/co2-comfort-level-d_1024.html
                              https://www.kane.co.uk/knowledge-centre/what-are-safe-levels-of-co-and-co2-in-rooms
                              I didn't have the opportunity yet to get the sensor outdoors.
                              Thank you in advance
                              • alowhumA
                                alowhumA
                                alowhum
                                I get values between 300 and 1500 I believe.
                                • noliN
                                  noliN
                                  noli
                                  wrote on last edited by noli
                                  Hi there,
                                  I'm currently trying to make it work (on an arduino pro mini 3.3), but won't succeed.
                                  I keep having the following output :
                                  1 - 40 - 1 - 0 - 1 - 21 - 3 - 15 - 0 - END
                                  Co2 - PPM = -1
                                  Sometimes the second value is different but the first one is always 1. And obviously 1 is not FF :) . However I don't understand what's wrong in there.
                                  I have to mention I'm using the MH-Z19B, and powering it with 5V, as opposed to the 3.3v of the arduino.
                                  I also tried with the mhz19_uart lib, but didn't go further with it as the samples where not working out of the box with the z19B. Will probably give it another try, though...
                                  • noliN
                                    noliN
                                    noli
                                    Hmm, tried wiht the uart lib, after removing the unsupported parts, no luck either.
                                    skywatchS 1 Reply Last reply
                                    • noliN noli
                                      skywatchS
                                      skywatchS
                                      skywatch
                                      @alowhum
                                      Thank you for posting this..... I tried it today and it works well! :)
                                      To test it I wondered where to get a source of co2 from, then an idea hit me......So I opened a beer :)
                                      I tipped it into a pint glass and drank most of it. Then, when I remembered the reason for opening the beer, I dangled the sensor into the glass, well above the liquid, placed my hand on top to seal it and swirled the beer around to release the co2 that makes it fizzy - result?
                                      Well in the room I was getting a constant reading of 395, but in the beer glass it went to 1711, 3055, 5000 !!! - So it works!
                                      Removing the sensor back to normal room air and it dropped back to 396 within 90 seconds.
                                      So quite impressed at the moment. So far this it the most expensive sensor I have used. About $18 for the 'B' version.
                                      • alowhumA
                                        alowhumA
                                        alowhum
                                        @skywatch you're welcome. Did you use a 5v or 3.3v Arduino? I still have to figure out if this sensor's serial port is 5v tolerant. The MH-Z14 is.
                                        Nca78N 1 Reply Last reply
                                        • alowhumA alowhum
                                          Nca78N
                                          Nca78N
                                          @alowhum said in MH-Z19 CO2 sensor:
                                          Datasheet (for model B) says "3.3 V(Compatible with 5V)"
