  3. Is it possible to add a Sensor to a Gateway directly?
5 Posts 2 Posters 2.4k Views 2 Watching
  • F
    F
    free118
    Hello all,
    just a question.
    Is it possible to add a Sensor (Analog In) directly to a Gateway (arduino) and comunicate this value over USB?
    What I want to do is the following:
    I've one Sensor which communicate over the Gateway to my Pimatic (over serial USB)
    Now I want to add a second Sensor, which is physicaly very close to the Gateway.
    So i want to add it there, and it should communicate to Pimatic as well.
    Kind of an internal "Sensor" device.
    So is this possible? If yes how?
    Free
    • F free118
      Hello all,
      just a question.
      Free
      @free118 Welcome to the MySensors community!
      Yes it is possible. Just add it to the gateway sketch, just as if you were adding it to a normal sensor node sketch.
      • F
        F
        free118
        wrote on last edited by free118
        Ok great,
        that's what I've done.
        But which Node and Child ID is needed for this. So that the Input will communicate as a "Sensor" to the gateway.
        Because the Pimatic plugin need to know where to look.
        // Enable serial gateway
        #define MY_GATEWAY_SERIAL
        // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
        #if F_CPU == 8000000L
        #define MY_BAUD_RATE 115200
        // Enable inclusion mode
        // Set blinking period
        // Flash leds on rx/tx/err
        #define ArrayLenth 10
        #define PH_SENSOR_ANALOG_PIN A0
        unsigned long lastSend = 0;
        static const unsigned long SEND_FREQUENCY = 5000;
        float lastPhValue;
        static const float deltaPhValue = 0.5;
        #define MY_NODE_ID 10
        #define CHILD_ID_PH_LOCAL 1
        MyMessage msg(0, V_PH);
        double analogReadAverage(uint8_t pin, unsigned long ms)
            return average;
        float getPH()
            if (sendTime || abs(PhValue - lastPhValue) > deltaPhValue)
                Serial.print("pH:");
                Serial.print(PhValue, 2);
               // Serial.println(" ");
                lastPhValue = PhValue;
                //send(msg.set(PhValue, 1));
                send(msg.set(PhValue, 51));
          return lastPhValue;
        	sendSketchInfo("PH Local","1.1");
          present(CHILD_ID_PH_LOCAL,S_WATER_QUALITY);
          float ph = getPH();
        Here the working Pimatic config for a Sensor through a gateway.
              "plugin": "mysensors",
              "driver": "serialport",
              "protocols": "1.5.1",
              "startingNodeId": 1,
              "driverOptions": {
                "//": "'/dev/ttyUSB0' if using serial Gateway",
                "serialDevice": "/dev/ttyUSB1",
                "baudrate": 115200
              "id": "phmeter",
              "name": "pHmeter",
              "class": "MySensorsPH",
              "nodeid": 9,
              "sensorid": 0,
              "xAttributeOptions": []
        • F free118
          Ok great,
          float lastPhValue;
              return average;
          float getPH()
            return lastPhValue;
            float ph = getPH();
                "driverOptions": {
                  "baudrate": 115200
                "id": "phmeter",
                "name": "pHmeter",
                "nodeid": 9,
                "sensorid": 0,
          I have no experience with Pimatic, but the child ID will be CHILD_ID_PH_LOCAL and the node ID will be 0 (gateways always have node ID=0).
          • F
            F
            free118
            Thanks for the answer. I tried this and it didn't work. I've started a thread in pimatic forum as well. Maybe they know how to do this.
