  3. RFM69 In Wall Light Switch
light switch rfm69
4 Posts 2 Posters 2.3k Views 3 Watching
  • S
    Shaun Storbakken
    I have been searching the forums for quite some time, but might be missing something as I am very new here. Has anyone developed in-wall mains powered light switch with an RFM69 radio? I am thinking of something similar to https://www.mysensors.org/hardware/ac-dc-ssd-relay but where I live the 2.4ghz frequency is extremely crowded. Another alternative I have considered (but know nothing about) is sending the communication down the powerline itself; is this a viable option?
    My end goal is to construct a bunch of light switch nodes within my home that can be controlled either by the standard North American switch already there, or remotely. Because I plan to make a bunch of these, I am trying to be very budget conscious. Along the same lines, is the RFM69 implementation within RPI reliable enough for this kind of application at this time? I noticed it is in the development branch.
    Thanks!
    YveauxY 1 Reply Last reply
    • S Shaun Storbakken
      Thanks!
      YveauxY
      YveauxY
      @Shaun-Storbakken Hi Shaun, and welcome to the forum!
      Here you can find an rfm69 in wall switch: https://www.openhardware.io/view/101/Wall-Socket-Insertable-Node
      And why do you say 2.4ghz band is very crowded? The nrf24 uses a much wider band than the overcrowded wifi band. You can probably use the high channels without WiFi interference.
      • S
        Shaun Storbakken
        Thanks for the quick reply! I didn't realize that NRF24 uses a wider band. Perhaps the link I mentioned in my first post is adequate. I am new to IOT and using the RF already supported might be more realistic.
        Thanks again!
          Thanks again!
          YveauxY
          YveauxY
          @Shaun-Storbakken rfm69 is also supported by the library ;-)
          Pick the one that suits you best!
