  3. Easy arduino with 5v sensors and 3.3v radio?
3 Posts 3 Posters 1.6k Views 3 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    I need to build a node which uses 5v sensors only (Ultrasonic and PIR) and want to know what the easiest way to connect a radio is.
    I know that there is a adapter for the "old" through hole NRF2401+ which can be powered using 5v. But I would like to use RFM69 or smd version of NRF2401+. Is there any existing shields or adapters that could be used with a mini pro 5v or a arduino nano.
    Or maybe any premade arduinos with the same features?
      wrote on last edited by gohan
      pir can be adapted to work at lower voltage, and there are also pir sensors working below 3 volts.
      Also for ultrasonic there are some work around to make it work https://sheldondwill.wordpress.com/2014/02/04/using-an-ultrasonic-sensor-hc-sr04-with-a-3-3v-micro-controller-tiva-c-series/
      If you can make it to work at 3.3 volts there are some boards in openhardware you can use with pro mini 3.3v
      • dbemowskD
        dbemowskD
        I use the Easy Newbie boards for most of my projects. It is designed for the nRF24L01+, and it has space for the needed 3.3v regulator if you are running it at 5V. I don't know if he has a way of using it with the RFM69 radios, but you could check. Plus it has a small proto-board area for wiring your sensors. Kudos to @sundberg84 for the design.
