  3. nRF5 action!
nRF5 action!
  • NeverDieN
    NeverDieN
    #1561
    Is the main (only?) advantage of the BMP that you have a single USB connection from your PC to your project instead of two (e.g. J-link plus an FTDI)? Or is there more to it that that?
    T 1 Reply Last reply
    • Nca78N Nca78
      @toyman said in nRF5 Bluetooth action!:
      @alowhum just buy a real Blue Pill (around $2) and convert it into BMP.
      Then you''ll get both a programmer and an USB-serial that you can use to get data from NRF52 UART
      Thank you for this idea, I didn't receive my STM32 (got lost somewhere in transit) but I have 2 unused blue pills, I'll try that tomorrow.
      "Conversion" process is easy to find: https://medium.com/@paramaggarwal/converting-an-stm32f103-board-to-a-black-magic-probe-c013cf2cc38c
      Toyman
      @nca78 I used exactly this guide. Works like a charm.
      • NeverDieN NeverDie
        Toyman
        wrote on last edited by Toyman
        #1563
        @neverdie for us - yes. For other folks, I think the advantage is the number of targets it supports and the license. Equivalent Segger costs hundreds of $
        BTW, Sandeep added BMP support into his core after I raised the issue :-)
        • T
          Toyman
          This post is deleted!
          • Nca78N Nca78
            @korttoma said in nRF5 Bluetooth action!:
            @nca78 still not getting anywhere with this. Would you mind ziping your sketch folder, then I should have all the correct files (right?). If I still have issues to compile I must be missing some library or are using the wrong version of something.
            Sure, but unfortunately I cannot upload a zip file here, please send me your email by private message.
            Ok here is a google drive link, it should be easier:
            https://drive.google.com/open?id=1IhLIx0nHd5KZR9dJ9qA0-_SMGmjEpbKj
            korttomaK
            korttomaK
            korttoma
            @nca78 I have now measured the current consumption of the small bluetooth beacon device (N51822 QFABC0) using your code and the results are encouraging.
            With your code I get around 4uA sleep current compared to 800-4000uA with my old code :D
            Measurements done with an Micro (nano) ampere meter (double) that has not been calibrated against a reliable meter so do not take the measured values so seriously but more as a comparison.
            Device
            • Tomas
            Nca78N 1 Reply Last reply
            • korttomaK korttoma
              Device
              Nca78N
              Nca78N
              @korttoma I was going to ask you for some news. This is great news as it confirms the problem is solved even with older versions of the chip.
              Time to start work on a clean library...
              PS: I think you will have a reliable measurement with a simple multimeter, as the nrf51 by default is using an internal LDO, whether you feed it with 3.3V or (3.3V - burden voltage) in the end the chip will run at the same 1.8V voltage and use the same current. Of course it won't be the case if you have extra sensors on the board but it's not the case here.
              • Nca78N Nca78
                Toyman
                @nca78 BTW, HolyIoT makes a similar beacon but nrf52 based. Should be much more energy efficient. The price is about $7
                • Mars WarriorM
                  Mars WarriorM
                  Mars Warrior
                  I see a lot of nice assembled PCB's on this forum, and just out of curiosity, but do you guys do your own SMT assembly?
                  I looked at the PCBA options, but just a small batch of 10 PCB's starts somewhere around $140 excluding components.
                  It would save me I think a lot of work, but on the other hand it feels expensive...
                  My ebyte modules & STM32 programmers are on there way from AliExpress, so no problem in that area.
                  T 2 Replies Last reply
                  • Mars WarriorM Mars Warrior
                    Toyman
                    @mars-warrior it depends on quantities of both PCBs and components on the PCBs.
                    If you have lets say 10 pcbs with 20 components and potentially will have to do it again, the best bet is get a small oven (kitchen type) with PID regulator.
                    If you just need 2-3 pcbs with 5-6 componets, hot air gun is your choice.
                    In my current project, I solder ebyte module by hand (very easy) and then LED, resisttors and capacitors with hot air and solder paste.
                    Looks pretty neat.
                    Mars WarriorM 1 Reply Last reply
                    • T Toyman
                      Looks pretty neat.
                      Mars WarriorM
                      Mars WarriorM
                      Mars Warrior
                      @toyman Thanx for that info!
                      Never worked (yet) with a hot air station/pencil.
                      Found some reviews here: https://wiki.ezvid.com/best-soldering-stations. Both the Kendal 853D and the Ayyue 968+ are stations I can afford to buy. I assume the cheaper ones ($50) are the ones to avoid...
                      Looking at some youtube vids about this subject, it seems doable, even for a novice like me ;-)
                      Of course, any recomendations about hot air stations are appreciated!
                        Toyman
                        @mars-warrior
                        something like this:
                        https://store.reflowster.com/products/reflowster
                          140$ it is quite expensive compared with a simple small oven
                          https://www.youtube.com/watch?v=mjfnpjvw9jY
                            Toyman
                            @gohan I am not telling you to buy this. Just a direction.
                            I've created a PID sous vide machine. It's relatively easy project. SMD oven is absolutely the same. All you need is Arduino, thermoprobe and a relay.
                            • alowhumA
                              alowhumA
                              alowhum
                              Quick question: when programming the eByte module (or any module really):
                              Should I select "reset enable or not? What does that do exactly?
                              Should I select clock: "Crystal oscillator" for the eByte module?
                              • alowhumA alowhum
                                NeverDieN
                                NeverDieN
                                @alowhum "Reset enable" determines whether pin21 acts as a reset pin or not.
                                • alowhumA alowhum
                                  NeverDieN
                                  NeverDieN
                                  #1576
                                  @alowhum IIRC, the crystal oscillator is only required by Bluetooth. For everything else, the internal resonator is sufficient.
                                  S 1 Reply Last reply
                                  • alowhumA
                                    alowhumA
                                    alowhum
                                    Thanks!
                                    I received two new eByte modules. I can't even connect to either one, both with BMP or ST-Link V2. Very strange. I'm going to try not powering them from the USB stick but from a second 3.3v source.
                                    • alowhumA alowhum
                                      Thanks!
                                      Toyman
                                      @alowhum did you manage to flash them?
                                      NeverDieN 1 Reply Last reply
                                      • alowhumA
                                        alowhumA
                                        alowhum
                                        #1579
                                        @toyman No. I don't understand what's going on, as I was able to flash one succesfully before. I did find [this a bit unnerving].(https://devzone.nordicsemi.com/f/nordic-q-a/19943/nrf52832-unable-to-connect-to-the-target).
                                        Could it be that the EByte chips need the DCDC stuff before they can be connected to? Or that the exact moment on power-on (reset) matters?
                                        One thing I have found is that I had installed OpenOCD on my laptop to turn a ST-Link V2 into a Black Magic Probe. That version of OpenOCD was overruling the hacked version that Sandeep Mistry had created for the NRF5.
                                        But even with that removed, the problem remains this:
                                        "TARGET: nrf52.cpu - Not halted".
                                        Apparently this is a sign that the chips are protected. I was able to remove that protection before (by selecting "Burn Bootloader"), but it doesn't work now.
                                        • T Toyman
                                          NeverDieN
                                          NeverDieN
                                          #1580
                                          @alowhum said in nRF5 Bluetooth action!:
                                          No.
